16V or 20V "Race" Motor
Re: 16V or 20V "Race" Motor
These bottom-ends are as reliable as the tides.
You guys are missing something.
- dubz-on-drugz
Semi solid lifter.. my apologies for asking what may be a silly question ,but how does it work ?
Alex if u wana get rid of that 298 cam .il am interested .
- AlexTDi
- Car Model: '15 Polo GTI
- Membership No: 1724
I honestly think the oil pump was on it's way out and I didn't notice it, I have all the gauges in the world to tell me there's an issue but stupid me didn't check mid race.BlueBlob wrote:These bottom-ends are as reliable as the tides.
No idea, I think the lifters are shimmed or something from what I was told. If you have a 288 estas I might consider it.dubz-on-drugz wrote:Semi solid lifter.. my apologies for asking what may be a silly question ,but how does it work ?
Alex
VWCSA Member No. 1724
Race Car: Polo Vivo GT
Daily:
'15 6C Polo GTI DSG
'06 1.9 TDI Sportline
'06 BMW 320D M-Sport
Weekend Toy: '84 Golf MK 1 GT
Race Car: Golf MK1 2 Door
Daily:
'15 6C Polo GTI DSG
Ha ha. Yeah having them <> checking them.AlexTDi wrote:I honestly think the oil pump was on it's way out and I didn't notice it, I have all the gauges in the world to tell me there's an issue but stupid me didn't check mid race.BlueBlob wrote:These bottom-ends are as reliable as the tides.
I do the same.
My dash literally removes all info (lap times, temps, EVERYTHING), and puts up massive flashing warnings, if pressure falls away. R50 says I'll still miss it. Lol.
- Car Model: 18 Polo Vivo
- Membership No: 1691
16v.. just saying makes funky noises, I wanted to do a 20v on throttles for my ex Jetta, but never got that far
The Events Toy
Project Louise Drag Car
The Daily
Project CTi
The Daily
Project CTi
- PaKiMoNSTeR
- Car Model: Mk3 Jetta
That's bad luck. We have had our fair share of that this year as well... Not fun.
Track Toy
- AlexTDi
So the sump was dropped yesterday, the oil pump has some wear on the gears, might have been bearing fillings that killed it or it was already damaged. cylinder one bearing turned so the conrod and crank is definitely damaged, the rest looks fine from the bottom but it will all be stripped soon to check bores and pistons.
Alex
Daily:
'15 6C Polo GTI DSG
Daily:
'15 6C Polo GTI DSG
What oil are you using (not blaming it, just curious)?
Also, my oil pumps have pretty much all had those score marks after some running, so I don't think that's your problem at all.
- AlexTDi
Fuchs Titan GT1 5w40 been running it for years, in the previous race car too, it came out ok and didn't smell burnt either but It is going in for analysis so that should give a pointer or two.
Could it be the oil pressure release valve that got stuck?
Alex
Daily:
'15 6C Polo GTI DSG
Daily:
'15 6C Polo GTI DSG
That really doesn't happen as often as people think. But obviously not impossible.AlexTDi wrote:Fuchs Titan GT1 5w40 been running it for years, in the previous race car too, it came out ok and didn't smell burnt either but It is going in for analysis so that should give a pointer or two.
From the comments I've heard about your pics, they agree with me, pump looks fine.
How is your sump baffled? Using the Norbrake sump, or something else?
- AlexTDi
I don't have pics right now but it was done by 8v performance, split in 3 sections with little flap doors.
One of the guys I race with said I should have probably run with more oil as in overfilled for Redstar probably lap after lap the oil was all on the pickup side in certain sections so it starved cylinder 1 bearing until it gave in.
Alex
Daily:
'15 6C Polo GTI DSG
Daily:
'15 6C Polo GTI DSG
- alfaquad
- Car Make: VW Touareg V6 TDI
- Car Model: Golf 2.0 8v Race Car
Don't think that is the case. If sump was baffled correctly the pickup would have had enough oil to pump. Also doubt it would affect cyl 1 if pump was working properly.AlexTDi wrote:I don't have pics right now but it was done by 8v performance, split in 3 sections with little flap doors.
Sucks that it had to happen now. But like we said at the track, just go straight to 16v now, even if it means you miss a race. This year is not a championship year for you. Sort out the 16v's teething problems out now so you can get a good shot off the bat next year.
Sent from my hi6210sft using Tapatalk
2007 Volkswagen Touareg 3.0 V6 TDI
1966 Austin Mini 1000 / 1958 Porsche 718 RSK Replica
VW Golf 2.0 8V Race Car
- markfish888
- Registered for: 13 years
- Car Model: B7A4 -JETTA Mk2
- Membership No: 1787
What about an 2.0l ALT Audi/Passat 20valve motor, cheaper than abf...
