16V or 20V "Race" Motor
- AlexTDi
- Car Model: '15 Polo GTI
- Membership No: 1724
So after struggling basically the whole year trying to make enough power out of an 8v and failed multiple times I have decided to buy a 16v or 20v non-fsi motor and build that up to compete with next year.
Main goal is a stock ABF with cams on throttles but parts are hard to find and pricing is insane, Cams are only to deliver the power at 5000-7000rpm if it does it with stock cams then it will stay stock.
I've already bought a complete set 43mm Toyota throttles, with TPS, injectors, fuel rail, vacuum lines etc.
Can I use them as is just buy the adapter plate/trumpets from 8v performance, buy the injector plugs, wire it all in and bobs your uncle?
Can I remove all the vacuum lines and block the ports off?
what is the benefit of running 60-2 vs MAP? I already have Dicktator standard installed in the car which runs either map or tps but would need to replace it to run 60-2
Are 16v and 20v NA exhaust branches the same as in port width spacing, location, etc?
Who has first hand experience with a 20V non-fsi race motor? Since they are cheaper and parts are available is this a reliable option in stock form?
Alex
VWCSA Member No. 1724
Race Car: Polo Vivo GT
Daily:
'15 6C Polo GTI DSG
'06 1.9 TDI Sportline
'06 BMW 320D M-Sport
Weekend Toy: '84 Golf MK 1 GT
Race Car: Golf MK1 2 Door
Daily:
'15 6C Polo GTI DSG
Re: 16V or 20V "Race" Motor
Hi Alex,
See you in JHB, why don't you give Shawn (I will see if I can find his number for you if interested) a call from (F&S) in the west rand they very good with 16v and 20v n/a motors
Hope you come right with project
- dubz-on-drugz
Hi Alex,
If you do decide to go 20v n/a , make a write up , as much as I'd love the power being boosted with all those sweet noises i have been thinking about the same setup you just mentioned .
I'm stuck with ...
Can the 20v head be modified to mate with a 2e bottom end ?
Gud luck bud
I'm stuck with ...
Gud luck bud
Exactly what I did. I'm using the Toyota rail and everything.AlexTDi wrote:I've already bought a complete set 43mm Toyota throttles, with TPS, injectors, fuel rail, vacuum lines etc.
That vaccum box type thing on top fouls, so I had to cut it up a bit.
But using the 8V Performance adapter plate, you're going to run into some clearance issues with the bonnet and alternator.
See my responses here
Huh? 60-2 and MAP/TPS have nothing to do with each other.AlexTDi wrote:what is the benefit of running 60-2 vs MAP? I already have Dicktator standard installed in the car which runs either map or tps but would need to replace it to run 60-2
60-2 (or stock dizzy) is what you use to tell the motor where/when to fire the coil(s). TPS or MAP is how the management determines load.
- AlexTDi
TDIFlava wrote:Hi Alex,
Please send me the details
Alex
Daily:
'15 6C Polo GTI DSG
Daily:
'15 6C Polo GTI DSG
- AlexTDi
I don't run a booster so could I blank it all off or is it required for something?BlueBlob wrote:Exactly what I did. I'm using the Toyota rail and everything.AlexTDi wrote:I've already bought a complete set 43mm Toyota throttles, with TPS, injectors, fuel rail, vacuum lines etc.
I don't think so, remember it's a Polo, check the pic below the 8V looks lost in there but yea I might need to run smaller trumpets.
Alex
Daily:
'15 6C Polo GTI DSG
Daily:
'15 6C Polo GTI DSG
- AlexTDi
Yea only thought of this afterwards, 60-2 or dizzy, I spoke to Wikus yesterday and he explained how 60-2 works and why it is way better to run it.BlueBlob wrote:Huh? 60-2 and MAP/TPS have nothing to do with each other.AlexTDi wrote:what is the benefit of running 60-2 vs MAP? I already have Dicktator standard installed in the car which runs either map or tps but would need to replace it to run 60-2
so I just need to buy a Dicktator 60-2 with the harness, I'll run the golf 4 coilpack with it.
Alex
Daily:
'15 6C Polo GTI DSG
Daily:
'15 6C Polo GTI DSG
Only vacuum you're going to need, is to go to the ECU if you run it on MAP.AlexTDi wrote:I don't run a booster so could I blank it all off or is it required for something?
Right. Forgot you're in a Polo now.AlexTDi wrote:I don't think so, remember it's a Polo, check the pic below the 8V looks lost in there but yea I might need to run smaller trumpets.
- AlexTDi
Ya I'll run it on MAP, TPS gives issues apparently well that's on single throttle not sure about itbs?
I also need to figure out which pipe is the return and feed on that rail, haven't really looked into it.
Do you still run the idle control valve? how does that get wired in to a dicktator or how does it work?
Alex
Daily:
'15 6C Polo GTI DSG
Daily:
'15 6C Polo GTI DSG
No, that is not true.AlexTDi wrote:Ya I'll run it on MAP, TPS gives issues apparently well that's on single throttle not sure about itbs?
But also, you can't really run ITB's on MAP alone. They don't make enough vacuum, unless you try and build some kind of balance chamber across the 4 intakes. You *might* be able to use the standard one on those throttles, but like I mentioned, I had to cut that bit off to make it fit (it caught on the tappet cover).
So on something like Dicktator, you're going to get better results using TPS. On XMS, like what we use, you use both TPS and MAP, but mainly TPS.
Looking at the pics I posted in that other thread, so looking at them from the front of the car, feed is on the left, return on the right (where the regulator sits).AlexTDi wrote:I also need to figure out which pipe is the return and feed on that rail, haven't really looked into it.
Nope, I just made an adjustment screw on the linkage that makes the idle adjustable.AlexTDi wrote:Do you still run the idle control valve? how does that get wired in to a dicktator or how does it work?
- AlexTDi
Ah ok simple solutions which will work perfectly, thanks bud
Alex
Daily:
'15 6C Polo GTI DSG
Daily:
'15 6C Polo GTI DSG
Eish so many questions almost all of which has been answered before.
stock 16v cams will make power to 6000 rpm. From there it is downhill in Gauteng.
You can mate a 20V head to a 2l block yes has been done many times before. 20v cams are very expensive though.
Most of the other stuff has been answered - can't run MAP on ITBS - not enough vacuum and even worse on long cams so you run TPS.
60-2 is a timing setup and nothing to do with fuelling. Advantage is better accuracy. Mainly used to be able to use wasted spark coils which give you better spark at high RPM.
No idle control valve. Manual throttle stop and low idle when cold.
I have a second hand 60-2 dictator. make an offer. You will probably want to buy a new harnass.
- WeirdSteam
- Car Model: A3 Sportback 1.8 TFSI
Alex if you decide to Sell the STD Dictator i might be interested in it..
- AlexTDi
Thanks Panic will be in touch after the weekend, Can I use my wiring I installed for the Dicktator standard unit? I didn't cut out any wires I didn't use.panic-mechanic wrote:Eish so many questions almost all of which has been answered before.
Alex
Daily:
'15 6C Polo GTI DSG
Daily:
'15 6C Polo GTI DSG
- AlexTDi
I will sell it but only after my last race at the end of November, still going to run the 2.0 8v until then.WeirdSteam wrote:Alex if you decide to Sell the STD Dictator i might be interested in it..
Alex
Daily:
'15 6C Polo GTI DSG
Daily:
'15 6C Polo GTI DSG
Should be able to. The difference is essentially in the firmware.AlexTDi wrote:Thanks Panic will be in touch after the weekend, Can I use my wiring I installed for the Dicktator standard unit? I didn't cut out any wires I didn't use.panic-mechanic wrote:Eish so many questions almost all of which has been answered before.
Just as an aside, you can also run that motor on a STD Dicktator (I wouldn't, but its technically possible)..
Had a quick look at the diagrams. Three wires are different. Can use your existing loom, yes. Will just rewire the pickup.
- dubz-on-drugz
Polo ? Share pix budBlueBlob wrote:Only vacuum you're going to need, is to go to the ECU if you run it on MAP.AlexTDi wrote:I don't run a booster so could I blank it all off or is it required for something?
- AlexTDi
Ok awesome that will make things better then.BlueBlob wrote:Had a quick look at the diagrams. Three wires are different. Can use your existing loom, yes. Will just rewire the pickup.
Have a rides thread here: http://www.vwclub.co.za/forum/viewtopic ... 1&t=201214 but since photobucket wants me to pay I've given up on updating it.dubz-on-drugz wrote:Polo ? Share pix bud
you can follow my FB page https://www.facebook.com/AMRacing89 or website if you don't have FB www.amracing.co.za
Alex
Daily:
'15 6C Polo GTI DSG
Daily:
'15 6C Polo GTI DSG
- AlexTDi
Just an update, I raced at Redstar this weekend and the 8v went tits up
last lap in race 1 it ran bearings and subsequently seized up so will need to strip the sub assembly and check what all went wrong. I suspect either the oil pump or baffled sump baffles got stuck for some or other reason, This is really not something I wanted at the moment.
Alex
Daily:
'15 6C Polo GTI DSG
Daily:
'15 6C Polo GTI DSG
- WeirdSteam
Man that Sucks, hope its something that you can sort out.AlexTDi wrote:Just an update, I raced at Redstar this weekend and the 8v went tits up
- dubz-on-drugz
Damn dude , hope all works out .
What work is done to the car ?
- AlexTDi
I'm pretty sure I need an entire new sub assembly but we'll see later in the week, for now I'm going to drain some oil and send it in for analysis.WeirdSteam wrote:Man that Sucks, hope its something that you can sort out.AlexTDi wrote:Just an update, I raced at Redstar this weekend and the 8v went tits up
Alex
Daily:
'15 6C Polo GTI DSG
Daily:
'15 6C Polo GTI DSG
- AlexTDi
car or engine?dubz-on-drugz wrote:Damn dude , hope all works out .
If you mean engine it's a 8v Performance stage 3 gasflow head, 298 estas cam, high rev kit, semi solid lifters, port matched exhaust and intake mani, 4-1 branch, 11.4 compression ratio, Dicktator management.
Alex
Daily:
'15 6C Polo GTI DSG
Daily:
'15 6C Polo GTI DSG
