16V or 20V "Race" Motor
BlueBlob
Re: 16V or 20V "Race" Motor
Postby BlueBlob » Mon Sep 04, 2017 2:21 pm
These bottom-ends are as reliable as the tides.
You guys are missing something.
dubz-on-drugz
Postby dubz-on-drugz » Mon Sep 04, 2017 3:16 pm
Semi solid lifter.. my apologies for asking what may be a silly question ,but how does it work ?
Alex if u wana get rid of that 298 cam .il am interested .
AlexTDi
Car Model: '15 Polo GTI
Membership No: 1724
Postby AlexTDi » Mon Sep 04, 2017 4:01 pm
BlueBlob wrote:These bottom-ends are as reliable as the tides.
I honestly think the oil pump was on it's way out and I didn't notice it, I have all the gauges in the world to tell me there's an issue but stupid me didn't check mid race.
dubz-on-drugz wrote:Semi solid lifter.. my apologies for asking what may be a silly question ,but how does it work ?
No idea, I think the lifters are shimmed or something from what I was told. If you have a 288 estas I might consider it.
Alex
VWCSA Member No. 1724
Race Car: Polo Vivo GT
Daily:
'15 6C Polo GTI DSG
'06 1.9 TDI Sportline
'06 BMW 320D M-Sport
Weekend Toy: '84 Golf MK 1 GT
Race Car: Golf MK1 2 Door
BlueBlob
Postby BlueBlob » Mon Sep 04, 2017 4:03 pm
Ha ha. Yeah having them <> checking them.
I do the same.
My dash literally removes all info (lap times, temps, EVERYTHING), and puts up massive flashing warnings, if pressure falls away. R50 says I'll still miss it. Lol.
nd_s
Car Model: 89 Jetta 2 , 03 Polo 05 Polo
Membership No: 1691
Postby nd_s » Mon Sep 04, 2017 8:03 pm
16v.. just saying makes funky noises, I wanted to do a 20v on throttles for my ex Jetta, but never got that far
PaKiMoNSTeR
Car Model: Mk3 Jetta
Postby PaKiMoNSTeR » Tue Sep 05, 2017 2:18 pm
That's bad luck. We have had our fair share of that this year as well... Not fun.
Track Toy
AlexTDi
Membership No: 1724
Postby AlexTDi » Tue Sep 05, 2017 4:25 pm
So the sump was dropped yesterday, the oil pump has some wear on the gears, might have been bearing fillings that killed it or it was already damaged. cylinder one bearing turned so the conrod and crank is definitely damaged, the rest looks fine from the bottom but it will all be stripped soon to check bores and pistons.
Alex
Daily:
'15 6C Polo GTI DSG
BlueBlob
Postby BlueBlob » Tue Sep 05, 2017 4:31 pm
What oil are you using (not blaming it, just curious)?
Also, my oil pumps have pretty much all had those score marks after some running, so I don't think that's your problem at all.
AlexTDi
Membership No: 1724
Postby AlexTDi » Tue Sep 05, 2017 5:12 pm
Fuchs Titan GT1 5w40 been running it for years, in the previous race car too, it came out ok and didn't smell burnt either but It is going in for analysis so that should give a pointer or two.
Could it be the oil pressure release valve that got stuck?
Alex
Daily:
'15 6C Polo GTI DSG
BlueBlob
Postby BlueBlob » Tue Sep 05, 2017 6:08 pm
AlexTDi wrote:Fuchs Titan GT1 5w40 been running it for years, in the previous race car too, it came out ok and didn't smell burnt either but It is going in for analysis so that should give a pointer or two.
That really doesn't happen as often as people think. But obviously not impossible.
From the comments I've heard about your pics, they agree with me, pump looks fine.
How is your sump baffled? Using the Norbrake sump, or something else?
AlexTDi
Membership No: 1724
Postby AlexTDi » Wed Sep 06, 2017 11:22 am
I don't have pics right now but it was done by 8v performance, split in 3 sections with little flap doors.
One of the guys I race with said I should have probably run with more oil as in overfilled for Redstar probably lap after lap the oil was all on the pickup side in certain sections so it starved cylinder 1 bearing until it gave in.
Alex
Daily:
'15 6C Polo GTI DSG
alfaquad
Car Model: Golf 2.0 8v Race Car
Postby alfaquad » Wed Sep 06, 2017 12:59 pm
AlexTDi wrote:I don't have pics right now but it was done by 8v performance, split in 3 sections with little flap doors.
Don't think that is the case. If sump was baffled correctly the pickup would have had enough oil to pump. Also doubt it would affect cyl 1 if pump was working properly.
Sucks that it had to happen now. But like we said at the track, just go straight to 16v now, even if it means you miss a race. This year is not a championship year for you. Sort out the 16v's teething problems out now so you can get a good shot off the bat next year.
Sent from my hi6210sft using Tapatalk
2008 Honda FR-V 1.8 (Daily)
1966 Austin Mini 1000 / 1958 Porsche 718 RSK Replica
VW Golf 2.0 8V Race Car
markfish888
Car Model: B7 A4 AUDI & JETTA2
Membership No: 1787
Postby markfish888 » Mon Sep 25, 2017 9:29 am
What about an 2.0l ALT Audi/Passat 20valve motor, cheaper than abf...
MK2's dont die, they just get lower & faster!!
Return to “N/A Engines”
Users browsing this forum: thepot, VAG Fan and 19 guests
