Replacement Carb
jelopymk1
Replacement Carb
Postby jelopymk1 » Wed Aug 16, 2017 1:40 pm
Hi there guys. I replaced my old carb with the replacement carb from gold wagen. my question is where do i connect all the vacuum hoses. wher do the vacuum hose from the one way valve from the brake booster go, i am so confused. it is a 1985 golf mk1 1.3
thank you in advance. :roll:
Re: Replacement Carb
Postby panic-mechanic » Wed Aug 16, 2017 6:56 pm
you did not think to just take a picture beforehand ?. how about one now with all the pipes you don't know.
distributor one goes to the back of carb and that is almost the most important one.
'07 Audi S6 V10 - beast !!!!!
'07 Audi A4 2l TDI
'95 Audi 90 coupe quattro
jelopymk1
Postby jelopymk1 » Thu Aug 17, 2017 7:51 am
I bought the car with the carb in the boot. So i couldt not take a photo. I googled the hoses and carb but there are so many photos and diagrams wich is not the same. that is why i want to find out were does the hose from the oneway valve from the brake booster go. ( where on the carb ) and also top left is the choke vacume, i think. where do the vacume come from on that. there is a vacume ball (green one) what supplys the ball with vacume. Please i need help.
sorry for spelling mistakes
Postby panic-mechanic » Thu Aug 17, 2017 8:55 am
Ok so the ball is basically supplied by the the one on the brake one way valve.
The choke vacuum should also go to the back of the carb. But these things are very hard to explain without pictures or even know which carb you have. If it is a new carb the choke vacuum should have already been plumbed.
The original carb for that engine would probably have been a pierburg which also changes th vacuum layout.
'07 Audi A4 2l TDI
caddy club
Postby caddy club » Thu Aug 17, 2017 9:34 am
what happens if you do not attach the vacuum pipe at the back, the one from the distributor one, when I unplug mine I don't see any changes
Caddy Club 1.6 carb 1998 model
Postby panic-mechanic » Thu Aug 17, 2017 10:52 am
On partial throttle the car might be surging slightly and if you measure emissions you find that you have lots of unburnt hydro carbons coming out of the exhaust.
'07 Audi A4 2l TDI
jelopymk1
Postby jelopymk1 » Thu Aug 17, 2017 11:40 am
it is a replacement carb from goldwagen, i dont now how to put the picture on.
Postby panic-mechanic » Thu Aug 17, 2017 11:46 am
Ok then there is a single line for vacuum at the back of the carb. You will take that and tee it to all the places that needs it.
The choke is manual and the second stage is directly plumbed into the carb.
You host pictures on an external host
Go to http://postimg.org and copy the link back into your post.
'07 Audi A4 2l TDI
jelopymk1
Postby jelopymk1 » Thu Aug 17, 2017 12:18 pm
https://s20.postimg.org/uep0rmbct/vw-go ... rettor.jpg
i hope this works i am not very clued up on computer. there is 3 lines at the back and 3 lines in front.
Postby panic-mechanic » Thu Aug 17, 2017 1:04 pm
'07 Audi A4 2l TDI
jelopymk1
Postby jelopymk1 » Wed Aug 23, 2017 11:50 am
so i have sorted the vacuum hoses, thanks to 7zap website. now my question is when the vehicle stand awile it starts very difficult, it sounds like there is no fuel in the carb, but when i drive there is no issues at all.
kind regards
Postby panic-mechanic » Wed Aug 23, 2017 1:00 pm
It is a phenomenon called carburettor percolation. Google it.
'07 Audi A4 2l TDI
jelopymk1
Postby jelopymk1 » Wed Aug 23, 2017 2:28 pm
if i use a colour tune spark plug what colour should it be when set corectly.
MrMazda
Postby MrMazda » Wed Aug 23, 2017 2:36 pm
Spark should be blue. Damn I did not know those things are still around. Used it to tune my rally 510 Datsun SSS Hitachi / SU carbs & later side draught Delorto carbs, with one aided by a vacuum meter (basically a little iron marble in a tube that rise with suction from the carbs to ensure suction level on both carbs are the same. Great memories.
PapaJo
Car Model: '16 Golf 7R, ´86 Caddy pick-up
Postby PapaJo » Wed Aug 23, 2017 8:49 pm
jelopymk1 wrote:if i use a colour tune spark plug what colour should it be when set corectly.
Last time, I have used a colour tune sparkplug was about 30 years ago on my first car.
MrMazda
Postby MrMazda » Thu Aug 24, 2017 4:56 pm
damn I even forgot the things name as well. I bought mine in the 70s or 80 together with the carb balancer from Wingate I think.
jelopymk1
Postby jelopymk1 » Fri Sep 01, 2017 2:26 pm
Hallo to all.
I replaced my old carb with a new one from goldwagen. just want to know how many turns for the air screw and how many turns on the top float screw.
thanx
Return to “N/A Engines”
Users browsing this forum: No registered users and 16 guests
