The machine of a Dream!
PapaJo
Re: Nasty surprise - Rescued!
Post by PapaJo » Wed Sep 13, 2017 6:43 pm
Now you have a spare head and parts from motor with repaired hole in block.
DeanK
Post by DeanK » Wed Sep 13, 2017 8:05 pm
hopefully not for too long
kylebassani
Car Model: MK3 Jetta 1.8 CSX, 1976 Beetle
Post by kylebassani » Wed Sep 13, 2017 8:46 pm
PapaJo wrote:Now you have a spare head and parts from motor with repaired hole in block.
Yep, hopefully I can look at everything this weekend and then possibly decide what I want to do...decisions...decisions...
VW Jetta mk2 16V
1978 Beetle 1600 8V
VW Jetta mk3 CSX
kylebassani
DeanK wrote:hopefully not for too long
Hahaha PM sent bud
VW Jetta mk2 16V
1978 Beetle 1600 8V
VW Jetta mk3 CSX
PapaJo
Post by PapaJo » Fri Sep 15, 2017 8:57 pm
Hahaha PM sent bud
Hmmmmmm, I like the direction of this. :hurray:
kylebassani
Post by kylebassani » Sun Oct 22, 2017 10:21 pm
So this happened...(decided I was going to do things properly)
Took out the rear carpet, it's in quite a good condition just needs a clean. Any advice regarding that would be much appreciated
Found these original sound dampening pads underneath the carpetImage
A bit of the engine bay... with some much needed love and attention.
My return in the investment lol
So got this far and decided to call it a night...
Busy removing the dash, any advise on how to do this properly and also for some things to watch out for...
VW Jetta mk2 16V
1978 Beetle 1600 8V
VW Jetta mk3 CSX
PapaJo
Post by PapaJo » Sun Oct 22, 2017 10:39 pm
Look in the raintray behind the wiper arms. There are two 6mm bolts with 10mm nuts on. If you don’t remove those two nuts you will not get the dash out.
kylebassani
Post by kylebassani » Mon Oct 23, 2017 8:07 am
PapaJo wrote:Look in the raintray behind the wiper arms. There are two 6mm bolts with 10mm nuts on. If you don’t remove those two nuts you will not get the dash out.
Thanks, I'll see if I can get to it tonight
VW Jetta mk2 16V
1978 Beetle 1600 8V
VW Jetta mk3 CSX
kylebassani
Post by kylebassani » Tue Oct 24, 2017 10:42 pm
So managed to remove the dash and the front carpet
Found this in the dash some time back...
Found a lot of bad wiring methods!!
It really rubs me up the wrong way, stripping the ends of two wires joining them together by twisting them together then covering with insulation tape is not a connection!!
VW Jetta mk2 16V
1978 Beetle 1600 8V
VW Jetta mk3 CSX
kylebassani
Post by kylebassani » Wed Oct 25, 2017 9:07 am
Mods, please can you move this to the rides topic
VW Jetta mk2 16V
1978 Beetle 1600 8V
VW Jetta mk3 CSX
175SBU
Car Model: MK1 1.4i, MK2 CSi
Re: The machine of a Dream!
Post by 175SBU » Thu Oct 26, 2017 11:40 am
It would be wise to lay some rubberizer/ bakkie and van coating on the floor while you still have the carpet out, this should keep rust away for a few more years if you are planning to keep the car that long.
I did the same on mine.
PapaJo
Post by PapaJo » Thu Oct 26, 2017 2:21 pm
Doing it in a proper way. Well done on the amount of work done sofar.
Wolf Mk2 16V
Post by Wolf Mk2 16V » Thu Oct 26, 2017 2:46 pm
Best way to clean carpets is with a pressure cleaner on paving...don't worry you wont damage them
2015 VW Golf Gti Oettinger (okay okay software only!)
1990 Golf GTi 16 Valve Executive (KR Baby!)
1993 Citi Golf Designa 1800
2015 VW Move Up!
2014 VW Transporter T5 Single Cab Long Wheel base
2013 VW Transporter T5 Single Cab Long Wheel base
2002 VW Citi Golf Chico 1.3 -sold :(
kylebassani
Post by kylebassani » Thu Nov 02, 2017 2:49 pm
175SBU wrote:It would be wise to lay some rubberizer/ bakkie and van coating on the floor while you still have the carpet out, this should keep rust away for a few more years if you are planning to keep the car that long.
This is definitely on the table, saw some spray can one the other day. Will try to get the name and check if those are fine.
VW Jetta mk2 16V
1978 Beetle 1600 8V
VW Jetta mk3 CSX
kylebassani
PapaJo wrote:Doing it in a proper way. Well done on the amount of work done sofar.
Thanks, appreciate it :hurray:
VW Jetta mk2 16V
1978 Beetle 1600 8V
VW Jetta mk3 CSX
kylebassani
Post by kylebassani » Thu Nov 02, 2017 2:50 pm
Wolf Mk2 16V wrote:Best way to clean carpets is with a pressure cleaner on paving...don't worry you wont damage them
What chemicals or detergents can I consider using?
VW Jetta mk2 16V
1978 Beetle 1600 8V
VW Jetta mk3 CSX
PapaJo
Post by PapaJo » Thu Nov 02, 2017 5:36 pm
Hosehold carpet shampoo
PapaJo
Household carpet shampoo
175SBU
Post by 175SBU » Thu Nov 02, 2017 6:55 pm
This is how mine came out, i used Sunlight dishwasher. It took a few cleans.
Before
Wolf Mk2 16V
Post by Wolf Mk2 16V » Fri Nov 03, 2017 7:47 am
Jeez quite a remarkable transformation, that looks good as new!
2015 VW Move Up!
Stripes
Car Model: 1989 1600A/T FOX
Post by Stripes » Fri Nov 03, 2017 5:34 pm
Carpet looks nice and clean
1989 1600 Old Man's Transmision(Automatic) VW FOX: 57mm SAC free-flow, Mp9 Airbox and cone filter adaptor, G-Cam and Vernier Pulley, Relayed Headlights, Mk1 GTi mags, CitiRox Wheelnut-caps
and CitiRox centrecaps.
http://www.vwclub.co.za/forum/viewtopic ... 1&t=151632
1976 1600SP Beetle(Sold): Believe me, it was modded and kicked ass
1991 Ford Bantam 1600(Sold): Lightly modded
kylebassani
Post by kylebassani » Fri Nov 03, 2017 8:53 pm
Wow bud!! The carpet came out great!!!
VW Jetta mk2 16V
1978 Beetle 1600 8V
VW Jetta mk3 CSX
175SBU
Post by 175SBU » Mon Nov 06, 2017 6:25 am
Thanks guys, i also never thought it would come out this was way, i got same results on the panels.
Sent from my iPhone using TapatalkImage
kylebassani
Post by kylebassani » Sun Nov 12, 2017 10:10 pm
So unfortunately not much updates at the moment been really hectic at work.
Did manage to play around with the tapet cover though
Before: was taken while I was busy cleaning it before sanding it down a bit
After:
VW Jetta mk2 16V
1978 Beetle 1600 8V
VW Jetta mk3 CSX
175SBU
Post by 175SBU » Mon Nov 13, 2017 11:57 am
Holi mother that looks clean can i give u mine to do same please. What did you use?
