The machine of a Dream!
kylebassani
Car Model: MK3 Jetta 1.8 CSX, 1976 Beetle
Post by kylebassani » Wed Aug 16, 2017 11:44 am
Hi guys,
I need some help.
Here is some background
I recently purchased a mk2 jetta cli with the 1.8 16v kr motor for a very good deal :hurray: knowing there would be some work to be done on the car.
So after getting the car home, I started doing the major assessments on the condition of the car and ultimately decided to pull out the motor, clean up the engine bay, strip the motor and replace all the seals and gaskets and assess the internals.
So after pulling out the motor I noticed there is a crack on the block :bang: :bang: :bang:
I proceeded to strip the motor to find that the internals are in great condition, new pistons, new oil pump, new water pump, seals look great, head gasket was still good etc.
So for my issue, I want to know can I get the block repaired and where can I find a trusted workshop/engineering shop to do this?
With finding all the internals in such a great state I really do not want to risk buying another block to now have to bore it out due to condition, meaning pistons will need to be replaced.
If sourcing another block is the only option, can I look for any block ex. a block from a 8v 1.8 motor etc.
Thanks in advance for the help.
VW Jetta mk2 16V
1978 Beetle 1600 8V
VW Jetta mk3 CSX
BlueBlob
Re: Nasty surprise!!
Post by BlueBlob » Wed Aug 16, 2017 11:52 am
How/where is it cracked?
Post by panic-mechanic » Wed Aug 16, 2017 12:25 pm
Picture yes but any proper engineering or welding specialist should be able to sort that out. Down th road from you is east rand automotive engineering or if younwant a welder then spartan area try aero tig
East rand auto 0118235882
Aero tig 0119757618
'07 Audi S6 V10 - beast !!!!!
'09 Audi Q5 3l tdi
'95 Audi 90 coupe quattro
kylebassani
Post by kylebassani » Wed Aug 16, 2017 6:24 pm
Thanks guys appreciate the help
Here are the pictures, you can see that the PO did try to fix it.
Here is the inside, looks like a conrod hit it
Here is the outside
Also you can see it hit the oil nozzle, not to sure what the correct term for this is...still need to check if it is clear.
VW Jetta mk2 16V
1978 Beetle 1600 8V
VW Jetta mk3 CSX
THANAS
Car Model: MkV Jetta TFSI Sportline
Membership No: 2035
Post by THANAS » Wed Aug 16, 2017 6:33 pm
Rod through the block for sure. It took out an oil squirter on the way out as well.
__THANAS
__Image
__@thvnvs
__Daily:
__Jet-Li
__Project:
__BoostCreep
__ManilaMoo
__Ex Project:
__PikaPika
__20VTerror
__Rodney the BT Jetta 4
__CCBB ADY Citi
BlueBlob
Post by BlueBlob » Wed Aug 16, 2017 6:57 pm
Is that squirter glued/epoxied in there? :0
That's going to make honing it properly oodles of fun
PapaJo
Post by PapaJo » Thu Aug 17, 2017 2:39 am
Wow, that is a nasty surprise!!!
Car Make: Fiat
Car Model: Uno
Post by Unobeat » Thu Aug 17, 2017 7:18 am
Ouch
That is not a good surprise, tooo nasty.
Just the thought of buying and only to find that you need to drop the motor cause something did not feel right and then boom there is a nasty surprise.
Sent from my SM-A500F using Tapatalk
kylebassani
Post by kylebassani » Thu Aug 17, 2017 10:42 am
BlueBlob wrote:Is that squirter glued/epoxied in there? :0
Not sure what was used, going to try and see if I can figure it out this weekend and also check if it is clear and working...as for honing it, the sleeves look quite good...
VW Jetta mk2 16V
1978 Beetle 1600 8V
VW Jetta mk3 CSX
kylebassani
Post by kylebassani » Thu Aug 17, 2017 10:51 am
PapaJo wrote:Wow, that is a nasty surprise!!!
Yeah, definitely not something I'd wish for anyone...
Unobeat wrote:Ouch
It was definitely a motivation killer, found a few other issues as well like only 3 to 4 bolts holding each driveshaft in place!! :fear: :bang:
Agh and I still drove the car home when I went to collect it
VW Jetta mk2 16V
1978 Beetle 1600 8V
VW Jetta mk3 CSX
Post by panic-mechanic » Thu Aug 17, 2017 11:20 am
Even though the bores look good you cannot remove a piston and put it back in without a hone. The rings need to reseat.
'09 Audi Q5 3l tdi
kylebassani
Post by kylebassani » Thu Aug 17, 2017 11:46 am
panic-mechanic wrote:Even though the bores look good you cannot remove a piston and put it back in without a hone. The rings need to reseat.
Thanks Panic, appreciate it. I was not aware of this, glad I mentioned it...
VW Jetta mk2 16V
1978 Beetle 1600 8V
VW Jetta mk3 CSX
Post by panic-mechanic » Thu Aug 17, 2017 11:59 am
That last picture you posted. Can you see the reflection of the piston top in the bore? That means it has already run in and thus needs to be honed again. Although from an oblique angle you can see the markings it has already knocked the sharp peaks of the hones off.
'09 Audi Q5 3l tdi
kylebassani
Post by kylebassani » Thu Aug 17, 2017 1:15 pm
panic-mechanic wrote:That last picture you posted. Can you see the reflection of the piston top in the bore? That means it has already run in and thus needs to be honed again. Although from an oblique angle you can see the markings it has already knocked the sharp peaks of the hones off.
Ah okay now I understand, thanks for the explanation. I like being able to answer the why question to things like this.
I do not need to replace rings though?
Or should I rather do it?
VW Jetta mk2 16V
1978 Beetle 1600 8V
VW Jetta mk3 CSX
THANAS
Membership No: 2035
Post by THANAS » Thu Aug 17, 2017 1:29 pm
New rings and a hone is a must.
__THANAS
__Image
__@thvnvs
__Daily:
__Jet-Li
__Project:
__BoostCreep
__ManilaMoo
__Ex Project:
__PikaPika
__20VTerror
__CCBB ADY Citi
BlueBlob
Post by BlueBlob » Thu Aug 17, 2017 1:30 pm
At this point, you would be wasting a lot of time and effort not doing a proper rebuild. Rings, bearings, the lot.
Post by panic-mechanic » Thu Aug 17, 2017 2:04 pm
Look on a serious budget sure reuse rings that has very limited km on it but you have to hone. I Personally prefer to use new rings specially if you don't know the history.
'09 Audi Q5 3l tdi
kylebassani
Post by kylebassani » Thu Aug 17, 2017 4:31 pm
That is the intention, I want to replace all the seals, bearings, gaskets etc...just wanted to ensure I am not wasting money replacing the rings...does sound like a stupid question the more I think about it
panic-mechanic wrote:Look on a serious budget sure reuse rings that has very limited km on it but you have to hone. I Personally prefer to use new rings specially if you don't know the history.
I must admit I do have a budget but also being a project and I prefer doing something right the first time I'd rather do it now then spend more money in the long run and blowing the budget anyway and probably more so then if I were to do it from the start.
Again guys thanks for the help, it is definitely appreciated and it goes a long way
VW Jetta mk2 16V
1978 Beetle 1600 8V
VW Jetta mk3 CSX
Post by panic-mechanic » Thu Aug 17, 2017 5:37 pm
look rings on those are probably like R800. If they were R4k like on CDL motors I would consider reusing.
'09 Audi Q5 3l tdi
kylebassani
Post by kylebassani » Fri Aug 18, 2017 1:07 pm
Looks like I might have come right with some Hastings rings...FOR FREE!!! :crazy: :hurray:
And looking at sending in the block next week hopefully :troll:
VW Jetta mk2 16V
1978 Beetle 1600 8V
VW Jetta mk3 CSX
VAG Fan
Post by VAG Fan » Fri Aug 18, 2017 1:15 pm
kylebassani wrote:I recently purchased a mk2 jetta cli with the 1.8 16v kr motor for a very good deal
Now, unfortunately, you probably know why the deal was so "very good".
I hope you come right - good luck. (I hate nasty surprises, you have my sympathies.)
Donavan
Post by Donavan » Mon Aug 21, 2017 10:48 am
If it was me I would just replace the block, surely you can get a short block replacement somewhere/or from someone on this forum
Audi A3 1.8t 20V
http://www.vwclub.co.za/phpbb3/viewtopi ... 11&t=33370
Killerwatt
Car Model: S3
Post by Killerwatt » Mon Aug 21, 2017 11:02 am
I would rather get a new block as well.
Or at least see how bad the damage is to the oil squirter. If that is epoxy holding it in place then you are pretty much gona redo the motor again when it gives up.
kylebassani
Post by kylebassani » Mon Aug 21, 2017 12:26 pm
Donavan wrote:If it was me I would just replace the block, surely you can get a short block replacement somewhere/or from someone on this forum
That was my initial plan, hence the question.
I am just not 100% sure which engine blocks would work, are all the 8v 1.8 blocks the same as the KR block?
Upon initial inspection they do all look the same, I just don't want to deal with another surprise of oh wait you need to do this or that to make it work.
VW Jetta mk2 16V
1978 Beetle 1600 8V
VW Jetta mk3 CSX
kylebassani
Post by kylebassani » Mon Aug 21, 2017 12:29 pm
Killerwatt wrote:I would rather get a new block as well.
I am hoping to answer the question around the squirter soon.
I still have the block to see if I cannot maybe source another block first for a reasonable price and condition before sending the block to get it welded up.
VW Jetta mk2 16V
1978 Beetle 1600 8V
VW Jetta mk3 CSX
