1.8 16v throttle project
- Car Model: 18 Polo Vivo
- Membership No: 1691
Re: 1.8 16v throttle project
Golf 3 alternator clears, or get a polo 1 1.4 alternator setup, but they scarce
The Events Toy
Project Louise Drag Car
The Daily
Project CTi
The Daily
Project CTi
Specially since we never got polo 1 in south africa. But you are actually talking polo 6n aren't you
- General
- Registered for: 18 years
- Car Model: Golf GT
- Membership No: 1464
I'm running modified ABF alternator brackets with shorter belts in both my 16V throttle cars, gives plenty of clearance but also hard to come by...
Current rides:
Hyundai - 1.4 Getz (daily)
- Car Model: Mk 2 jetta
Hi
Last time i mentioned my vw 1.8 16v throttle setup... We managed to sort out the water housing problem... Our current issue is regarding the 20v tps wiring.
My buddy and i are not to sure what goes for what when it comes to linking up the tps wires, we hav googled and searched were wr could but to no luck....
Please help? What colour wire goes for what?
Use ohm meter. Find two wires over which the resistance climbs or falls when you move the throttle.
The management's 5v output and tps signal wires goes onto those two. The other one is a SIGNAL ground. Not body earth. Signal ve-
- Donavan
download an old standard gotech version 5/6/7 manual from the gotech website.
Inside the manual they have the tps pin out for Toyota 20v
Audi A4 B8 2.0T - Daily
Hi Guys
Once again thank you guys for all the advise and help you wouldn't believe how much it helped with the success of my 16v throttle project.
Well with success one seems to pick up may faults and failures which i believe is a learning curve.
Anyhow, let me jump right into it need some help trying to put the wire back as it seems to have come out when we removed the dickator(pics attached).
i would also like to ask what the black is in the plug, we thought it was burnt but it doesnt have any burnt smell, lol, please note i am not electrically included... so hence im come to all you experts here to advise a layman like myself to diy the problem myself.
Below are pictures of the wire plug and also some pictures of the 16v project. Please note see is stock standard no cams, no high pressure fuel pump or any exotic modifications .. however, after having a little fun in her i do feel cams would be a good fit just to give that little more when downing the throttle... (advise would be much appreciated)
Where are the pictures? Not seeing them when using my mobile phone on forum.
Black wire or black/red stripe or black/yellow stripe is normally switched 12v.
