High comp Pistons in AGG
- Car Make: Vw golf
- Car Model: Citi golf 2.0L 8V
Hi guys I have a stock 2.0 8v AGG motor, motor is running well I'd like to up the CR abit what will be the best way?can I just drop a set of 2.6 Pistons in ,is there machining work as it already has 20thou over size in at te moment and how reliable is it to do this
- Car Make: Vw golf
Re: High comp Pistons in AGG
:driving
- chucker02
- Car Model: Citi ADY
Just skim the head a bit, easiest way
1971 VW beetle
1971 VW beetle
- Car Make: Vw golf
Ok il do that then see how it goes from there
- Unobeat
- Car Model: Uno, Auris, CX-5
I am more interested as to what you trying to achieve with increasing the compression since you mention that the motor is running very heathly?
Sent from my SM-A500F using Tapatalk
- Car Make: VW Golf 1
- Car Model: 2.0 h8 valve
Further to that...the bottom end isn't standard if you already have over sized pistons...decking the block is also an option, measurement is more important tho just keep that in mind
