Fuel Pump on MP9 Caddy
- Ettos
Hi All,I just want to know if the fuel pump can be connected straight to the ignition and what repercussions that can have on my Caddy.
Whenever I start the bakkie there's black smoke coming from two exhaust pipes,one more than other.Timing is correctly set..Please assist with this,btw I do have the wiring diagram for an external pump.
- Abnormal
- Membership No: 848
Re: Fuel Pump on MP9 Caddy
Welcome
It wont cut fuel when if the engine stalls. I assume yous till intend using a relay.
What does the fuel pump being connected to the ignition have to do with the black smoke?
more smoke on one side means more exhaust gasses are flowing out of that side.
\Oo) \ _w_ / (oO/
- Ettos
Hi,
Black smoke I figured is because of unburned fuel,I am gonna connect it the way it should work. To answer your question about the black smoke and pump on the ignition,well it should run trough a relay,cause it's overfueling thats cause by the pump never switching off! Did you actually assist here or what? If you dont have informative replies,keep your arrogance to yourself please!
- Abnormal
EishEttos wrote:Hi,
Just asked a question to get more info, as I was not clear if these were related problems.
Pump not switching should not cause over fueling on an MP9, but it sounds like you know better already.
\Oo) \ _w_ / (oO/
- Unobeat
- Car Model: Uno, Auris, CX-5
Yes it should be connected like that, but i dont understand the last bit about overfueling???Ettos wrote:Hi,
Welcome newbie
- Abnormal
Do you not understand or are you just arrogant!!!Unobeat wrote:Yes it should be connected like that, but i dont understand the last bit about overfueling???Ettos wrote:Hi,
Welcome newbie
\Oo) \ _w_ / (oO/
- Unobeat
Abnormal wrote:Do you not understand or are you just arrogant!!!Unobeat wrote:Yes it should be connected like that, but i dont understand the last bit about overfueling???Ettos wrote:Hi,
Welcome newbie
Where is Neuk when you need him or Panic.......
you can let the pump run permanantly and it will not cuase overfuelling. Incorrect tuning or a failed sensor on EFI will cuase smoke. Not the way the pump is connected. But connecting the pump to ignition is a little stupid and very dangerous. The reason why it is connected to run only when the engine is turning is that when you are in an accident when the motor stops the pumps shuts off. if not and there you are knocked out and the pump is still running and a fuel line is split and it catches fire it will happily continue spraying the entire contents of your tank on the fire instead of stopping.
- Ettos
Thanks Panic,I'm actually looking for your number,I saw one of your replies and it's pretty good. The reason I say it's overfueling is the fact that it never smoked. It started just after I connected straight onto ignition,hence I'm saying it should run trough a relay on MP9.You can smell the unburned fuel,I know my Map Sensor is fine because when the car idled(roughly),I unplugged it and the car died. Also it's an Aftermarket Bosch pump and I feel it pumps too much to be connected straight. Pin 25 on ECU -Brown is for your fuel pump relay and should go to 85 on relay,86 ign power,87 + of pump and 30 straight from battery. So I'm telling you if the pump is connected like that it's overfueling no other thing there,causing misfire,and throws my spark plugs dead.It did run trough relay however it died,and I had no other way to keep my bakkie running.That is when I came to the conclusion that it shouldn't work straight from ign but you guys give me kak about what I experienced.So again if you cannot reply with insight keep your kak to yourself.Black smoke out of your exhaust is petrol,I can give you a letter on that.So if it's overfueling you'll get that at any car.
- Ettos
What is causing my spark plugs to continuously fail? I've replaced it now 3 times still the same! It can't be my injectors because it worked fine before the relay went. I still didn't manage to get the pump to cut off!
- Ettos
Bore-wash also occurred at my engine...I know that cause I smelled petrol in my engine oil,flushed the engine with diesel,put in new oil,haven't started it up yet as I don't get the pump to cut off.I know that my injectors + should also be on pin 87 on f/p relay..Two cables that's throwing me off red and yellow and black cable I haven't unscrew the whole new spec dash to see where they're coming from.
Ok so if you have all the answers why not connect a relay be sorted then.
So ECU mapping, injectors and fuel.pressure regulators have nothing to do with fueling then?
Damn...... everyone is doing it wrong then.
- Neuk
- Treasurer
- Membership No: 806
I have zero informative replies other than to say that if you're gonna be dumb, you gotta be tough.Ettos wrote:Hi,
- Ettos
Thanks for nothing than
- Abnormal
- Gielie
- Car Make: Toyota
- Car Model: Heeelooks
- Membership No: 1729
Hi EttosEttos wrote:Thanks for nothing than
It seems that you are quite new here, and having a bad time.
Reading this thread, some of our most helpful and knowledgeable users have responded to your query.
However, that being said, your tone and messages are perceived as you knowing what you are doing, and that you do not require any help, nor do you want it. You perceive them all to be arrogant or non constructive to the problem you are experiencing.
I do hope that you solve your problem, and please let us know what was wrong.
- Neuk
- Treasurer
If you dont have informative replies,keep your arrogance to yourself please!Abnormal wrote:You are welcome, actually I started with that.
*then
- Ettos
Hi there,
I re-wired everything,just want to know why my pump aren't cutting out like it used to,like I explained injectors and pump's +ve are together on pin 87 on relay,Ecu pin 25 goes to/I wired it straight from ECU to relay's pin 85,86 I bridged with 86 of wipers,ignition power and 30 is coming straight from battery. What am I doing wrong? Once again if you're gonna reply again with poo keep it to yourself.I prefer WhatsApp 0842902838 or leave your number and I'll call back thanks.
P.S- The reason I want it to work trough relay is for safety precautions and also just as I connected it straight I started having the problem that it keeps misfiring,I also haven't done any test on injectors or any sensors to say that could be the problem.I also wanted to know what does thinners do,cause I had a mechanic that threw thinners into fuel rail to start the bakkie? He said it's gonna do nothing. Isn't there rubbers that could've get damaged by this?
Test pin 25 with a multimeter. Must be open circuit untill you crank the engine and then it must be pulled to ground. If it does not do that then the mp9 box is faulty.
Have you tested the relay
