Polo 6R 1.6 Automatic Transmission Problems
Hi. I just want some info. When my car is cold, it doesn't take drive but it take reverse, but when I idle 10-15 minutes, it take gears, but it's driving like it slips and I'm driving like it's manual with half clutch, high revs and then it goes again and sometimes it doesn't. It shifts till D5, but the car doesn't move. Can it be the input or output sensor or the torque converter? I've read that on Google
Re: Polo 6R 1.6 Automatic Transmission Problems
Inwas not aware that they came with an auto. Thought there was only manual and DSG.
I've asked a VW Expert and he said it's a DSG box, but at VW when I asked for parts the guy told me if it is DSG it must have had 7 gears, but mine only has 6 gears, so he told me it's auto and it has 2 sensors. A input sensor and a output sensor, but I only see one infront
- Car Make: Toyota
- Car Model: Corolla D4-D
- Membership No: 2016
Is a standard Automatic , torque converter unit 6 speed , afaik its a ZF unit.
DSG was only introduced to ZA in the TSi models.
2013 A3 1.6 TDi S-Tronic 8V.1
2013 Ford Focus 2.0 Sport
2011 Hyundai i20 1.4
2006 Toyota RunX
2006 Toyota RunX
I've put the car on the VCDS and on transmission it have me a code: 01166 Engine Torque Signal
013 Check DTC Memory - Intermittent
01314 Engine Control Module
Good day all
I currently own a VW Polo 1.6 Tiptronic with 140000 km on the clock (2007 Model - old shape). I recently started experiencing some trouble regarding the gearbox. Whenever i drive the car, as the gears shift up, I experience an over rev and then a "kick" when shifting between gears. It usually happens during the transition between gear 2 and 3, and gear 3 and 4. Also when engaging reverse, the car will idle for a few seconds then "kick" into reverse.I took my car to VW in Umhlanga and was told that they do not repair tiptronic gearboxes My car is out of warranty and motor-plan, hence i am open to taking it to a reputable mechanic/workshop to get a diagnostic on the gearbox.
Has any one experienced any similar problems with their automatic gearboxes? All suggestions/solutions are welcome
I am based in Durban area.
Regards
Regards
- Unobeat
- Registered for: 13 years
- Car Model: Uno, Auris, CX-5
WelcomeYoshen wrote: ↑Mon Dec 30, 2019 6:09 pm Good day all
Regards
Get in contact with TSC Garage as they are based in durban.
TSC Garage
0849991860
Have them look at the wiring connector at the top of the oil pan. The pins lose contact with age.
- Registered for: 3 years 8 months
hi guys i have the same problem with my vw polo 1.6 tiptronic on cold start i need to wait 10-15min before gearbox engage and say after 30mins driving when stopping at a stop the car stays in 5th gear and i need to put in neutral and back in to drive before driving also gears then starts to slip any advice please
You need more than advise.vw polo 1.6 bts wrote:hi guys i have the same problem with my vw polo 1.6 tiptronic on cold start i need to wait 10-15min before gearbox engage and say after 30mins driving when stopping at a stop the car stays in 5th gear and i need to put in neutral and back in to drive before driving also gears then starts to slip any advice please
You need professional help. Take the car in to a reputable VW specialist and ask them to look at the wiring connector on the top of the oil pan for possible poor connections.
Also get a look at the oil quality, if it has suffered and has signs of high heat and clutch slipping, you may end up with a gearbox overhaul being the required solution to get you back up and running.
Sent from my ***-L22 using Tapatalk
