If it will efect the timing on a 2.0l then a 1.8l timing will also be outcorney wrote:Won't it affect the firing on the dizzy?
I thought of a nother possibillity.
There is a presure valve in the filter housing as well, could that also cause low presure?
Its very seldom that the pressure valve fails but something to look at, only problem you can't test it, have to replace the housing to see if its the problem.
