Hi guys need help
Started the car this morning got a loud warning/ flash engine oil light beeping and before i could pull off i heard the engine knocking (sounds like valves /pistons as if they want to jumping out the engine . (MP9 fuel injection )
please advise ?
first timing went then this happened golf sound like a trackter on a dosage of caugh medicine
Please help what to do stripping and replacing with new rings /pistons /valves /doing complete timing ? taking head to engineers /compression test ?
Vw 1.4 engine noise (knocking sound) and oil light
- Darrien
- Car Model: Mk2 Jetta
Re: Vw 1.4 engine noise (knocking sound) and oil light
well it sounds like your oil pump has failed - and due to low oil pressure - you now have a bearing knock
How much do you think its going to cost to fix
- Car Model: Caddy AGG 2L Carb
does a engine get a bearing knock that quick, didn't think it will happened that quick after a pump failure, thought you could still drive the car like a couple of km's
Caddy Club AGG 2L Carb 1998 model
It does start and drive but it will mess up even more coz it feels like the valves and pistons are nocking around
It is screwed seconds after the oil light goes on. You don't have minutes and km's
what do u surguest i do now eish stress already .
- THANAS
- Forum Advertiser
- Car Model: AW Polo GTi
- Membership No: 2035
Start pulling things apart if you are capable or ask the guys for recommendations to find a trusted mech in your area.
was thinking of doing whole engine over instead
respray the car and do the whole interior
work hard on the car to get results i want make it my project its going to cost me thou but is it worth it ?
