Mp9 fuel system on a 16v kr engine?
jacquesdejager21
Re: Mp9 fuel system on a 16v kr engine?
Postby jacquesdejager21 » Mon May 29, 2017 2:19 pm
Thanks alotwill sorce a motor and see when i can get started..wich aftermarket ecu do you recomend?
jacquesdejager21
Postby jacquesdejager21 » Mon May 29, 2017 2:34 pm
We have a guy that is very good with the spitronics,his name is Jackie.The guys said i will need the basic spitronics so i spoke to him and he gave me a qoute.Supply and fit with dyno tune R5500
jacquesdejager21
Postby jacquesdejager21 » Tue May 30, 2017 7:42 am
Morning guys,so i browsed tje web and came across a 2.0 16v aal motor for a okay price.The motor is already fitted with a "maak n plan" bmw fuel rail and mp9 injectors.He ran dictator on the setup so he has done all the work,i must just fit the motor in my car and get the spitronics fitted and mapped
jacquesdejager21
Postby jacquesdejager21 » Tue May 30, 2017 7:48 am
.Image
amstel18
Car Model: Polo TSI
Postby amstel18 » Tue May 30, 2017 9:03 am
Use the management your tuner recommends. Dependant on price on the AAL, it may be a good deal or not.
But that Cambelt I would change immediately just looking at the pic.
But it is a good thing the motor is running in a car that your can test. Not something you can do with an import
2006 Seat Ibiza Cupra TDI
96 1600 Chico (sold)
jacquesdejager21
Postby jacquesdejager21 » Tue May 30, 2017 9:10 am
Once i get the motor it will be stripped,cleaned and get new ring,bearings,gaskets and seals and a good service.Motor will be sent off to engineering shop to check and make sure everything is still good,and will have them recon the head aswell so that i know once i fit the engine it hopefully wont give me any k*k
jacquesdejager21
Postby jacquesdejager21 » Tue May 30, 2017 9:16 am
amstel18 wrote:Use the management your tuner recommends. Dependant on price on the AAL, it may be a good deal or not.
7k? Is the asking price
Postby panic-mechanic » Tue May 30, 2017 9:22 am
If it's running then it is a decent enough price. Abf is 18k these day
'07 Audi S6 V10 - beast !!!!!
'07 Audi A4 2l TDI
'95 Audi 90 coupe quattro
jacquesdejager21
Postby jacquesdejager21 » Tue May 30, 2017 9:49 am
Yes,it is a running engine.And the guy says that he rebuild the motor not to long ago
8VALVE-zn
Car Make: VW Golf 1
Car Model: 2.0 h8 valve
Postby 8VALVE-zn » Wed May 31, 2017 9:30 am
Sounds like a dodge deal to me, if you are going to see this engine yourself then yes go for it...I got hit down not so long ago from a guy in the Benoni area! Guy goes by the name Ian...
2000 Golf 1 Chico- CRANKCASE [Std bottom end, head gas flowed,ported & chopped by Fastcar, 288 Estas Billet, 4-2-1 43mm Brospeed Branch, 50mm-57mm-63mm Exhaust] + THE PART (2B1 speacials) -Final power @ Autotrix 111wkw & 210wnm :drool:
2011 Jetta 5 1.6 TDI DSG - CRANKCASE Tow Services [CPI Stage 1 with DPF Delete]
jacquesdejager21
Postby jacquesdejager21 » Wed May 31, 2017 9:41 am
Hi,yes i am going down to see the motor and make sure everything is okay before i pay anything
jacquesdejager21
Postby jacquesdejager21 » Sat Jun 03, 2017 10:14 am
Morning all,ive been doing some more reading on the web..I see the guys fit the kr cams in the 9a/aal 2.0 16v motors..Does it really make that much of a difference?I am going to pick up the motor next week and found kr cams,dizzy+spare cap,intake and some other spares aswell for R1500
Postby panic-mechanic » Sat Jun 03, 2017 7:26 pm
not much diffs. I would not bother. ABF cams yes sure.
'07 Audi A4 2l TDI
Grand1
Postby Grand1 » Sun Jun 04, 2017 12:44 pm
jacquesdejager21 wrote:Morning all,ive been doing some more reading on the web..I see the guys fit the kr cams in the 9a/aal 2.0 16v motors..Does it really make that much of a difference?I am going to pick up the motor next week and found kr cams,dizzy+spare cap,intake and some other spares aswell for R1500
Good setup I made 149 whp on my aal with kr cams.
jacquesdejager21
Postby jacquesdejager21 » Sun Jun 04, 2017 5:39 pm
What other mods did you do to the motor?
Grand1
Postby Grand1 » Sun Jun 04, 2017 7:01 pm
jacquesdejager21 wrote:What other mods did you do to the motor?
Stock engine. Dictator management. Abf intake and injectors
jacquesdejager21
Postby jacquesdejager21 » Sun Jun 04, 2017 7:46 pm
Im gonig to use std intake with 20v turbo fuel rail and inj with spitronics management
Grand1
Postby Grand1 » Sun Jun 04, 2017 8:03 pm
jacquesdejager21 wrote:Im gonig to use std intake with 20v turbo fuel rail and inj with spitronics management
You will loose torque with that intake. I doubt it's a direct bolt on.
jacquesdejager21
Postby jacquesdejager21 » Sun Jun 04, 2017 8:52 pm
Sorry,what i ment to say is i will use std aal intake with the 20vt fuel rail and inj and the kr cams
jacquesdejager21
Postby jacquesdejager21 » Wed Aug 30, 2017 2:55 pm
missioner wrote:
jacquesdejager21 wrote:Also,can the mp9 ecu be mapped to 16v?
No it can't mapped to 16 valves, but you can load the 1.8R map and install a UniQ to sort out the fine tuning
Will this work on the abf engine aswell?
jacquesdejager21
Postby jacquesdejager21 » Wed Aug 30, 2017 3:58 pm
Sorry,i a **** saw now that one of the comments is where a guy ran abf engine on mp9
Return to “N/A Engines”
Users browsing this forum: thepot, VAG Fan and 20 guests
