Sub assembly or re-work engine?
Mark Schmuhl
Registered for: 6 years 10 months
Post by Mark Schmuhl »
Hi guys , I have a citi golf 1.4 carb . She has been using a lot of oil and smoking too. She has also lost a bit of power. I believe it's the pistons and rings. Where can I get a sub assembly new? Labor is going to kill me on re-doing the engine so would prefer a sub assembly... Anywhere in Durbs? I'm trying to save where I can as this is Costly...
Choc07
Registered for: 7 years
Car Make: Isuzu
Car Model: KB250 LE 2006
Re: Sub assembly or re-work engine?
Post by Choc07 »
rework engine will be cheapest is my guess , 1.6 subs are pretty much everywhere these days .
:crazy:
Usually this is the point where people just stick a 2l import motor in.
Mark Schmuhl
Choc07 wrote:rework engine will be cheapest is my guess , 1.6 subs are pretty much everywhere these days .
Only place I found had a sub was available is barons. R5700 for a 1.4 .... I also tried Goldwagen but the don't stock.
That is dirt cheap. Can't even buy the parts to fully rebuild it for that price.
Mark Schmuhl
panic-mechanic wrote:That is dirt cheap. Can't even buy the parts to fully rebuild it for that price.
What if I do the sub for now and leave the head when I have more bucks, would that stop the smoking?
Abnormal
Registered for: 20 years
Membership No: 848
Post by Abnormal »
I think doing the head at the same time will not add a significant amount to the total cost, assuming that its in reasonable condition now.
\Oo) \ _w_ / (oO/
Without knowing exactly what is causing the smoking it is hard to commit to say it will stop the smoking. Head will smoke when you let it run against compression and then get on the throttle.
8VALVE-zn
Car Make: VW Golf 1
Car Model: 2.0 h8 valve
Post by 8VALVE-zn »
Contact Rino from Fastcar, he charged me very reasonable rates (labour) to freshen up my bottom end. I bought all the parts just for my own comfort of knowing exactly what was in my car. As a basis take note of the prices I paid to freshen up the bottom end.
Rings- R360 (Hastings chrome)
Bearings- R1200 (Kings racing bearing) NB. this will be a lot cheaper for you (R400-R800)
Labour- R1800 (strip bottom with engine in the car, re-ring, fit new bearings, re-assemble)
Mark Schmuhl
panic-mechanic wrote:Without knowing exactly what is causing the smoking it is hard to commit to say it will stop the smoking. Head will smoke when you let it run against compression and then get on the throttle.
When running down hill and gear down it's ok and as soon as I exhilarate she starts smoking but not black smoke.
Continously or one big puff and stops?
Mark Schmuhl
panic-mechanic wrote:Continously or one big puff and stops?
Big puff then stops yes
marzbars
Car Model: 1988 Corrado 16V
Membership No: 1316
Post by marzbars »
2E/AGG/ADY/ABF
Ok that is valve stem seals. So you should redo the head
Mark Schmuhl
panic-mechanic wrote:Ok that is valve stem seals. So you should redo the head
Thanks bud, much appreciated. What is the procedure because I can get a new head for about R4500 . Just looking at options...
You take the head off and drop it at the engineering. Askt hem to tell you what it needs - get the parts from goldwagen, let them fit it and put it back on.
Mark Schmuhl
panic-mechanic wrote:You take the head off and drop it at the engineering. Askt hem to tell you what it needs - get the parts from goldwagen, let them fit it and put it back on.
Thanks boet Image
