Good evening Please assist me.
I have a vw golf one 1.8 carb engine.The care cranks but refuses to start it my first time experiencing such an issue. I will detail what I have done so far and what I have experienced when I tried to fix the problem. The car is an 1980 model.
1. I did test the module on another golf and it worked fine.
2. I replaced the coil and still it won't start.
3. I tested with two distributors and the car still won't start.
4. The mechanic came to check the car and said the car won't because timing was out, he set the timing and check for spark we found out that the car has a weak speak. I went as far as replacing the sparks plugs.
5. Today I tired starting it after replacing the speak plugs. It as if the car wanted to start but it backfired and made an explosive noise.
what can cause a weak spark and backfiring when I attempt to start the car ?
How does one know what a good spark should look like ?
VW golf one 1.8 Carb car cranks but won't start
- Registered for: 7 years
Re: VW golf one 1.8 Carb car cranks but won't start
Good day Please assist me.
I have a vw golf one 1.8 carb engine. The car cranks but refuses to start it my first time experiencing such an issue. I will detail what I have done so far and what I have experienced when I tried to fix the problem. The car is a 1980 model.
What can cause a weak spark and backfiring when I attempt to start the car?
How does one know what a good spark should look like? Because the spark I get is blue
- Car Model: Mk2 Gti 8v
Hi,
1.Check your whether your orientation of your plug leads are correct
2. Spark is generated from the coil coupled with your ignition module. Check all wiring and earths.
3.Check if all 3 your timing marks line up.(google this)
Regards
38
Regards
38
BMW E30 325i
Jetta 6 1.4 TSI
Ex-MK2 Gti 1988 1800, 8v OEM
Ex-MK1 Gti 1985 , CTI injection.
Ex-MK3 Vr6 97exec(standard).
Ex-VFR 400(NC30) 1992, aftermarket Can.
Ex-MK1 2door- 1800 8v, 4-1 branch,powerflow 50mm(RIP)
Ex-1990 Mk2 CSL Jetta aka VR1(Sold)
Ex-1987 Toyota Corolla 1.6GL slantfront(stolen)
Rides thread : http://www.vwclub.co.za/forum/viewtopic ... 4#p2505684
Jetta 6 1.4 TSI
Check hall sender in distributor
He says he tested with a different distributor so kinda means he did. The fact that it backfires tells me the timing is out. So either the cam timing is out or the ignition timing is out. It is possible your mechanic got it out 180 degrees or simply too slow. SLOWLY turn the distributor clcokwise while somebody cranks it and see if it wants to start. rememebr there is risk of shocking so try not to hold it by the cap but rather by the distrubutor stem while doing that.
