2L 8v Dicktator map wanted
- AlexTDi
- Car Model: '15 Polo GTI
- Membership No: 1724
Hi guys,
anyone have a 2L 8v Dicktator map they can email me please, it's just temporarily for my race car.
I've loaded the "startup map" that comes with the dicktator software but it seems very rough.
Alex
VWCSA Member No. 1724
Race Car: Polo Vivo GT
Daily:
'15 6C Polo GTI DSG
'06 1.9 TDI Sportline
'06 BMW 320D M-Sport
Weekend Toy: '84 Golf MK 1 GT
Race Car: Golf MK1 2 Door
Daily:
'15 6C Polo GTI DSG
- Unobeat
- Registered for: 13 years
- Car Model: Uno, Auris, CX-5
Re: 2L 8v Dicktator map wanted
How rough is the startup map, is it not drivable to get tuned.
What are the motor specs as maps are different from car to car.
- AlexTDi
It definitely needs a proper map, it's stage 3 flow, 298 cam, 10.8 compression. It will go for tuning next week but before that I need to run the motor for to get it up to temp, make sure there's no leaks and at the same time bed in the brakes. I can't get to the dyno and it starts giving issues on the dyno.
Alex
Daily:
'15 6C Polo GTI DSG
Daily:
'15 6C Polo GTI DSG
- THANAS
- Forum Advertiser
- Car Model: AW Polo GTi
- Membership No: 2035
Send me the current map if you've made any edits from the base settings and full list of specs and I'll try put something together. Have you set the base timing?
- AlexTDi
Email address?THANAS wrote:Send me the current map if you've made any edits from the base settings and full list of specs and I'll try put something together. Have you set the base timing?
It's been set by ear but that's with no branch and exhaust which is getting done now, so we'll set the timing better tonight.
Specs.
2.0 8v
298 cam
full flow port match etc, high rev springs,
standard mp9 FPR so 3bar
standard injectors
normal 3 bar map based setup, no TPS.
anything else you would need?
Alex
Daily:
'15 6C Polo GTI DSG
Daily:
'15 6C Polo GTI DSG
- THANAS
- Forum Advertiser
Hmmm, running a 298 cam on MAP will always be problematic, you really should be aiming to tune it on TPS, especially with Dicktator that can't do both simultaneously.
Why no TPS if I may ask?
- Car Model: 18 Polo Vivo
- Membership No: 1691
0nly got a 16v map from my old trumpet car. Not sure if that will help you
The Events Toy
Project Louise Drag Car
The Daily
Project CTi
The Daily
Project CTi
- AlexTDi
I'm sorted thanks guys
Alex
Daily:
'15 6C Polo GTI DSG
Daily:
'15 6C Polo GTI DSG
Hi , do you perhaps still have the map of the crossflow with 298cams?AlexTDi wrote:I'm sorted thanks guys
- AlexTDi
No sorry I didn't run a crossflow head either
Alex
Daily:
'15 6C Polo GTI DSG
Daily:
'15 6C Polo GTI DSG
- Car Model: Velociti 1.4i
this post has been removed
Tenaciti 1.4i - 79wkw
Tenaciti 2.0L ADY 95wkw
SEAT Cupra 1.9TDi - 150wkw
Velociti 1.4i - TBA
Velociti 2.0L - ....
Superior Detail - Durban - 072 695 4469
Velociti 1.4i - TBA
hi guys can someone help me with a map for a 60-2 on a 2.0 crossflow
There is a startup map on the cd you get with the ecu. Give more info if you are running wasted spark coil or 60-2 with dissy. If you don’t come right pm me you email and I can send you a map. Specify wheter you are using wasted spark coil or dissy for spark.
hi there i'm running wasted spark. the other thing is, my tps picks up backwards on the dicktator. e.g not throttle shows 100% and foot flat shows 0%
Then you load the map and on the main page you change the selection from single coil to wasted spark.
Swap the positive and negative wires on the TPS around if you can't swing the TPS 180 degrees in fitment.
