Polo Playa 1.6 Cluster (Speedo)
- Membership No: 1919
Hi Guys
My Polo Playa 1.6i is giving an issue on the Speedo and Fuel Gauge. The Speedo is intermittent and does not give a reading and when it does the needle is jumping. The fuel gauge goes right down when accelerating and then when I leave the accelerator it goes back up. Please can some assist. This started since Saturday. Everything on the car is original still nothing changed engine wise.
Brat Boy
Brat Boy
Polo (9N3) GTI
Polo (9N3) GTI
- Registered for: 10 years
Re: Polo Playa 1.6 Cluster (Speedo)
Not sure if it was you or someone else also posted a fuel gauge issue with 6n polo. Its a fairly common issues but in your case it might be the float itself. Movement on the gauge as you accelerate or brake means float
Hi
It was not me. It isnt the float both the speedo and Feul gauge issue started at exactly the same time
Polo (9N3) GTI
Polo (9N3) GTI
Can be a bad earth somewhere. I have a issue with my fuel gauge also. Mine is intermittent. Problem is can be the cluster or float. I was speed reeding so didnt see the speedo part. If both having a issue can be cluster also. The facelift polo 6n model are very popular for there gauges jumping around and acting out.
Hi
Is yours the old cluster or new dash? Milenium dash
I had the exact same issue on my 1999 Polo Playa. It got worse after a while.... when i switched the car off all the gauges started to jump and would only stop when the ignition is on.
What you need to do is go to an auto electrician and he needs to check the wiring running from the back of the cluster to the fuse box, once he finds the problematic wire he needs to replace that wire with a new one. Problem solved.
It's not a major issue, its just old wires that are making contact with the body or wires in back and causing a short.
Hope this helps.
Hope this helps.
- Chris_FZ
- Car Model: 2017 Vw Golf mk7.5 R
- Membership No: 2065
This is a common problem. When the stepper packs up this happens.
Its expensive fix.
Got one sorted out at S.P.E in durban. Cost R2100
Its expensive fix.
-Vw Golf mk7.5 R Custom Tune -
- Meth / Eth / Fuel
-Onxy White & Black Trim
-Rolling on 19" Z Performance Flow Forged
-Membership No:2065
- Meth / Eth / Fuel
-Membership No:2065
HiHASSEN wrote:Hi
It is the Milenium dash
Polo (9N3) GTI
Polo (9N3) GTI
Hi
I tried the above with earthing and stuff still no luck, please any advice appreciated
Polo (9N3) GTI
Polo (9N3) GTI
- vr6zn
- Car Model: 1998 MK3 VR6 Golf
did you try changing your speedo sensor on the gearbox?
Six is always better then four!
1998 Golf VR6 (Durban Stock)
2001 Polo Playa 1.4i
1994 Jetta VR6
1992 1.3 Citi Golf
1994 Jetta VR6
1992 1.3 Citi Golf
Hi
Removed and tested on another car it works there. But when this went wrong the Petrol Guage also started going faulty.
Polo (9N3) GTI
Polo (9N3) GTI
Speed sensor on the gearbox or the wiring to the sensor. I forgot to plug mine back in when i did my motor swap. Speedo didnt work and feul gauge went dilly. My bet is on a break in the wiring, hence the jumpy speedo.
Sent from my SM-A300F using Tapatalk
thanks will try the wiring
Polo (9N3) GTI
Polo (9N3) GTI
Polo (9N3) GTI
Polo (9N3) GTI
Hi All
Problem was the speedo just didnt work on my car. replaced and everything is working again
Polo (9N3) GTI
Polo (9N3) GTI
I am currently sitting with the exact same problem, except in my case it is only the fuel gauge.
also the entire cluster goes off when the car is driving but when i switch of the ignition while the light are switched on the cluster box works but there fuel gauge never works, i checked the float as well and it seems to be in perfect working order.
Hi guys, I have a problem with my car polo playa old dash 1.4..
I change my clutch of the car and while busy stripping I forgot to take my positive head off the battery..
Then the positive wire from the starter went against the body and obviously gave a spark..
After I've finished up everything was fine just all my gauges wasn't working at all .
Any advice guys??????
Thanks.
Thanks.
Thanks.
Thanks.
- DJ7
- Car Model: MK5 2.0 TDI DSG
- Membership No: 3238
Check fuses, sounds like you might have popped a fuse.Abubakrfatima001 wrote: ↑Thu Apr 02, 2020 6:26 pm Hi guys, I have a problem with my car polo playa old dash 1.4..
Thanks.
Ex: '97 Astra Estate 200i
'00 Corsa 200 GSI 16v
'96 Astra 200i E 16v
'02 Corsa 160 GSI
'93 Ballade 160e
'95 Astra 200i E 16v
'02 Corsa 160 GSI
'93 Ballade 160e
Hi guys I have the same problem, my rev counter, temperature and fuel gauge not working. I checked the earth connections, but sill the same and fuses r fine.
Any ideas. Thanks
Any ideas. Thanks
