Car not idling
raveennaidoo3
Car not idling
Postby raveennaidoo3 » Mon Jan 02, 2017 7:37 am
Hello to all. I need advice for Mr car,It's a citigolf with 2L8v agg engine on Dictator,
Started having a problem with idling.It idles then the idle starts dropping till the engine cuts off,Advice will be highly appreciated
Sent from my E2303 using Tapatalk
dubz-on-drugz
Re: Car not idling
Postby dubz-on-drugz » Mon Jan 02, 2017 8:56 am
It will probably need tuning , my car did that on base map .
Sent from my SM-G920F
raveennaidoo3
Re: Car not idling
Postby raveennaidoo3 » Mon Jan 02, 2017 9:03 am
Just been tuned
raveennaidoo3
Re: Car not idling
Postby raveennaidoo3 » Mon Jan 02, 2017 9:04 am
Tuned using tps
chucker02
Car Model: Citi ADY
Re: Car not idling
Postby chucker02 » Mon Jan 02, 2017 9:19 am
Then take it back and tell them to fix it, simple as that
2003 Audi A3 1.8t
2007 Citi golf. ADY with Spitronics 60-2, Brospeed 4-2-1 branch, Poly mounts and coilies. CCBB Limited edition
Rides Thread: http://vwclub.co.za/forum/viewtopic.php?f=11&t=183329
2002 Citi golf. ADY engine with GW carb, Viper 4-2-1 branch, 282 estas cam, 57mm freeflow, GW delarey big brake kit and GW delarey gearbox mounting.
1971 VW beetle, my first love
raveennaidoo3
Re: Car not idling
Postby raveennaidoo3 » Mon Jan 02, 2017 9:21 am
Ok, hope they don't:-( charge me again
chucker02
Car Model: Citi ADY
Re: Car not idling
Postby chucker02 » Mon Jan 02, 2017 10:04 am
Well they tuned it so it must have idled when you got it so say that to them
2003 Audi A3 1.8t
raveennaidoo3
Re: Car not idling
Postby raveennaidoo3 » Mon Jan 02, 2017 10:07 am
Yes,it did,Chucker ,only from yesterday started giving problem
raveennaidoo3
Re: Car not idling
Postby raveennaidoo3 » Mon Jan 02, 2017 10:08 am
Contacted the tuner,said I must bring it in,thanks for your input
dubz-on-drugz
Re: Car not idling
Postby dubz-on-drugz » Mon Jan 02, 2017 11:51 pm
Did they dyno tune or just loaded a map ?
raveennaidoo3
Re: Car not idling
Postby raveennaidoo3 » Tue Jan 03, 2017 12:02 am
Dyno tune
raveennaidoo3
Re: Car not idling
Postby raveennaidoo3 » Fri Jan 06, 2017 9:06 am
Went to tuner,idle sorted out
dubz-on-drugz
Re: Car not idling
Postby dubz-on-drugz » Mon Jan 09, 2017 10:04 am
Who tuned you car ... ?
raveennaidoo3
Re: Car not idling
Postby raveennaidoo3 » Mon Jan 09, 2017 10:07 am
Autotrix, top tuner,car is tuned for economy therefore 92wkw,on performance tuning it made 100wkw
BlueBlob
Re: Car not idling
Postby BlueBlob » Mon Jan 09, 2017 10:19 am
raveennaidoo3 wrote:Autotrix, top tuner,car is tuned for economy therefore 92wkw,on performance tuning it made 100wkw
Can someone explain this to me please?
What's different between the two tunes?
Neuk
Treasurer
Treasurer
Car Model: '15 Golf R
Membership No: 806
Re: Car not idling
Postby Neuk » Mon Jan 09, 2017 10:21 am
The power, obviously.
Nic
Daily Drive: 2015 VW Golf R
Re: Car not idling
Postby panic-mechanic » Mon Jan 09, 2017 10:24 am
But you tune it so that when the driver has full throttle it makes all the power that is available. When not full throttle you tune for economy. Surely this is not hard to understand.
Nobody detunes an engine at full throttle for economy as that is also pretty bad for the engine. this is something I can never understand when people say that.......
'07 Audi S6 V10 - beast !!!!!
'07 Audi A4 2l TDI
'95 Audi 90 coupe quattro
BlueBlob
Re: Car not idling
Postby BlueBlob » Mon Jan 09, 2017 10:25 am
panic-mechanic wrote:But you tune it so that when the driver has full throttle it makes all the power that is available. When not full throttle you tune for economy. Surely this is not hard to understand.
Well, that's what you and I know.
I want to know where the missing 8kw went.
raveennaidoo3
Re: Car not idling
Postby raveennaidoo3 » Mon Jan 09, 2017 10:28 am
I told the tuner that the car was heavy on fuel and that he must tune it for economy
raveennaidoo3
Re: Car not idling
Postby raveennaidoo3 » Mon Jan 09, 2017 10:29 am
After the dyno it made 92kw
raveennaidoo3
Re: Car not idling
Postby raveennaidoo3 » Mon Jan 09, 2017 10:31 am
When it made 100kw it was done on the same dyno and by the same tuner,
raveennaidoo3
Re: Car not idling
Postby raveennaidoo3 » Mon Jan 09, 2017 10:32 am
I don't know about tuning,so do you think I should have made the same kw
raveennaidoo3
Re: Car not idling
Postby raveennaidoo3 » Mon Jan 09, 2017 10:34 am
Also I made 100kw with 15 inch rims now l have 17 inch
raveennaidoo3
Re: Car not idling
Postby raveennaidoo3 » Mon Jan 09, 2017 10:40 am
Thanks panic for your info, I learnt something new, so good to be on this forum
Car Make: Fiat
Car Model: Uno
Re: Car not idling
Postby Unobeat » Mon Jan 09, 2017 12:24 pm
So how good is it now on fuel?
What fuel consumption you getting now with the Economy tune?
Send from my SM-Umsotho via Tapatalk
Return to “N/A Engines”
Users browsing this forum: No registered users and 19 guests
