Golf 3 VR6 Fuel PUMP
- Wheel Hoarder
- Registered for: 17 years
- Car Make: VW / BMW
- Car Model: Golf VR6
Hi Peeps
My VR6 giving me some issues,
Saturday took it out, drove a while, went to Rosslyn Pta North and back
got home and switched off, not even 10 mins later I tried to move it into the garage
and she refused to start, swings oneway,
I cant hear my pump coming on,
I checked the fuse 18 and its fine, I need to check now the relay
but which relay is for the fuel pump,
What is the best way to diagnose to see if the pump is working or if its not getting power
I tried to google pics but vortex gives me so many different type relays
I need to know which slot is for the fuel pump relay and then go to the pump n check if it died,
any advise please
any advise please
"HaTe iT oR LoVe It"
2001 E39 M5 Antracite
1997 Golf VR6 White
1992 E30 325i Silver
2011 BMW 320d M Sport White(Yes another White one)
1991 E30 318i coupe Red
2011 BMW 320d Msport
2004 323 Mazda (Daily)
Golf 5 GTI DSG United Grey
2005 318i E46 Individual
2001 Polo Playa 1.6
200i 16v Dohc Mazda
2004 318i E46 Special Edition
2002 Polo Playa 1.6s
1997 Golf VR6 White
2001 Polo Playa 1.6
200i 16v Dohc Mazda
- Colonel
- Membership No: 1041
Re: Golf 3 VR6 Fuel PUMP
put a light tester on the pump end and test if its getting power whenever you turn the key on and off etc
Pump is in tank.
Remove tank cap under boot carpet .
Look at the plug, it will have two thin wires and two thicker wires,
Pull it off and with a voltmeter/ test light test across the thick wires, should be the outer two.
Should have power when you crank it.
If there is power there then the pump is dead.
- Wheel Hoarder
Oki cool
so a test light can work,
if the light comes on with my key on and the pump is not making a bzzz or jump out
then its definitely my pump.
Should I check the relay 1st or the pump itself,
Sweet thanks UDC And Stephan
I will update tonite
1997 Golf VR6 White
2001 Polo Playa 1.6
200i 16v Dohc Mazda
1997 Golf VR6 White
2001 Polo Playa 1.6
200i 16v Dohc Mazda
- Colonel
if the test light comes on then its definitely the pump, only bother with the relay/wiring if the test light does not come on when testing.
Also remember that the pump primes for a few seconds first then goes off when ignition is switched on but car not started, so either connect the test light to somewhere you can see it whilst turning the ignition on and off or get someone to assist you or be quick about it
- Wheel Hoarder
Oki sweet,UDC wrote:if the test light comes on then its definitely the pump, only bother with the relay/wiring if the test light does not come on when testing.
these damm pumps are like over 4k from the agents
Diesel electric in Pretoria west doesn't even list them,
Some guys say the Golfwagen pump doesn't last to long, but I spoke to the guys at GW Delarey
they reckon its a Meyle pump and meyle a good make
1997 Golf VR6 White
2001 Polo Playa 1.6
200i 16v Dohc Mazda
1997 Golf VR6 White
2001 Polo Playa 1.6
200i 16v Dohc Mazda
- Colonel
Yes Meyle is good.....but test for power at the pump end first
- Wheel Hoarder
Shot Meneer I will update tomorrowUDC wrote:Yes Meyle is good.....but test for power at the pump end first
1997 Golf VR6 White
2001 Polo Playa 1.6
200i 16v Dohc Mazda
1997 Golf VR6 White
2001 Polo Playa 1.6
200i 16v Dohc Mazda
- Wheel Hoarder
So after 13 years of ownership the pump shes dead
Will have to order one,
now should I go with bosch or a GW make,
ima try and get quotes I know the agents are crazy, almost 5k
1997 Golf VR6 White
2001 Polo Playa 1.6
200i 16v Dohc Mazda
1997 Golf VR6 White
2001 Polo Playa 1.6
200i 16v Dohc Mazda
- Colonel
for Bosch try Diesel Electric.....hopefully the price is better
- Wheel Hoarder
I noticed the original unit is a VDO unitUDC wrote:for Bosch try Diesel Electric.....hopefully the price is better
will it be a problem using a Bosch or Meyle unit,
1997 Golf VR6 White
2001 Polo Playa 1.6
200i 16v Dohc Mazda
1997 Golf VR6 White
2001 Polo Playa 1.6
200i 16v Dohc Mazda
- Colonel
no...as long as its for mk3 Gti/VR6 the pump will be a plug and play setup
- Wheel Hoarder
Shot my manUDC wrote:no...as long as its for mk3 Gti/VR6 the pump will be a plug and play setup
1997 Golf VR6 White
2001 Polo Playa 1.6
200i 16v Dohc Mazda
1997 Golf VR6 White
2001 Polo Playa 1.6
200i 16v Dohc Mazda
- suli454
- Wheel Whore
- Car Model: Citi R, R32
- Membership No: 3021
Had to do a fuel pump on my E30 agents wanted a few key the most economical way out for me was a walbro pump lots of videos on YouTube to retrofit it
- AyaThatGuy
- Car Model: MK1 Golf
Mo please advise on the best price when you get one, i also need oneTHE GAME wrote:Shot my manUDC wrote:no...as long as its for mk3 Gti/VR6 the pump will be a plug and play setup
- Wheel Hoarder
Keep the Vaseline readyAyaThatGuy wrote:Mo please advise on the best price when you get one, i also need oneTHE GAME wrote:Shot my manUDC wrote:no...as long as its for mk3 Gti/VR6 the pump will be a plug and play setup
this was one item that always scared me,
13 years later it decided, so I don't feel bad
1997 Golf VR6 White
2001 Polo Playa 1.6
200i 16v Dohc Mazda
1997 Golf VR6 White
2001 Polo Playa 1.6
200i 16v Dohc Mazda
- Car Model: Mk3 Jetta VR6
THE GAME wrote:Oki sweet,UDC wrote:if the test light comes on then its definitely the pump, only bother with the relay/wiring if the test light does not come on when testing.
Meyle pumps from Goldwagen are good. I bought one for my VR6 about 5 years ago, when the original pump died, and it's still going strong.
Current:'97 Jetta VR6
- Wheel Hoarder
Thanks for thisDub Addiction wrote:THE GAME wrote:Oki sweet,UDC wrote:if the test light comes on then its definitely the pump, only bother with the relay/wiring if the test light does not come on when testing.
Im just waiting a quote for a Bosch pump then I can decide
1997 Golf VR6 White
2001 Polo Playa 1.6
200i 16v Dohc Mazda
1997 Golf VR6 White
2001 Polo Playa 1.6
200i 16v Dohc Mazda
- Wheelwore
- Car Model: MK1 Velociti 1.6i
any update?
2007 - Velociti 2.0 ABF Black Magic
2008 - Velociti 1.4i Midnight Blue
2002 - Chico 1.4i White - Chicolux
1996 - VR6 2.8 Golf
1996 - VR6 2.8 Golf
- Shadows101Fall
When I went FI on my old golf I bought one of the cheapy pumps, R295 and it lasted for a year before I sold the car, and it's probably still going strong. I should also probably mention it went through torture that not many pumps would survive while I was experimenting with the idea of an in tank pump for a mk1.
I buy broken/smashed/written off cars
Current: 2005 Alfa Romeo GT 1.9 JTDm
Ex: 2014 Nissan NP200 1.6i - meh.. Sold
Ex: 2000 Alfa Romeo GTV 3.0 Sold http://www.vwclub.co.za/forum/viewtopic ... 1&t=197077
Ex:1980 2 door mk1 build thread Sold http://www.vwclub.co.za/forum/viewtopic ... 1&t=192831
- Wheel Hoarder
Ordered a bosch pump from Diesel electricWheelwore wrote:any update?
Got one at Wynberg,
will get someone to assist me in fitting it onto my fuel sender and stuff,
R 1400+vat
1997 Golf VR6 White
2001 Polo Playa 1.6
200i 16v Dohc Mazda
1997 Golf VR6 White
2001 Polo Playa 1.6
200i 16v Dohc Mazda
- Wheel Hoarder
I am just hoping its a direct fit with no mods required
Agents complete VDO unit is R 7100 lol
1997 Golf VR6 White
2001 Polo Playa 1.6
200i 16v Dohc Mazda
1997 Golf VR6 White
2001 Polo Playa 1.6
200i 16v Dohc Mazda
