Mp9 coil dicktator and distributor setup connection
mk1strand
Re: Mp9 coil dicktator and distributor setup connection
Post by mk1strand » Wed Jul 02, 2014 9:40 am
Bump
Quik-Trix
Membership No: 3004
Post by Quik-Trix » Wed Jul 02, 2014 10:12 am
Did you calibrate the TPS on the ECU?
mk1strand
Post by mk1strand » Wed Jul 02, 2014 10:17 am
Yes its calibrated
mk1strand
Post by mk1strand » Wed Jul 02, 2014 10:18 am
It closes fully it doesnt keep that bit open to idle
Quik-Trix
Membership No: 3004
Post by Quik-Trix » Wed Jul 02, 2014 10:56 am
Drill a hole and tap a screw, or just move your accelerator cable clip 1 up
mk1strand
Post by mk1strand » Wed Jul 02, 2014 11:35 am
I moved the cable clip up car idles now but very low like on 800rpm and it sounds like its going to die but doesnt it cant move up anymore so will it be better to tap the hole or put something place that throttle doenst close the whole way i want car to idle on 1000rpm if i keep the throttle open by hand on 1000rpm it sounds 100%
mk1strand
Post by mk1strand » Tue Jul 08, 2014 12:08 pm
Sad news car standing again the ground wire from the coil burned no idea why did it today so i removed car started put it back again it didnt get hot put car off when i tried to start again it burned again must get car checked out now
mk1strand
Post by mk1strand » Tue Jul 08, 2014 1:16 pm
Anybody
Torker
Car Model: Golf GT
Membership No: 1464
Post by Torker » Tue Jul 08, 2014 1:23 pm
Sounds like the coil got fried - what did you set your dwell to (mS)?
Current rides:
Hyundai - 1.4 Getz (daily)
mk1strand
Post by mk1strand » Tue Jul 08, 2014 1:24 pm
Huh whats dwell to what sory i dont much
mk1strand
Post by mk1strand » Tue Jul 08, 2014 1:25 pm
I dont know much
VWicked
Car Model: Golf 2 GTi
Membership No: 1492
Post by VWicked » Tue Jul 08, 2014 1:28 pm
How long in milli secs the coil charges for. Its on the setup screen, should be around 2.5 to 3 on a standard coil
1992 Golf Mk2 VR6
2018 Golf Mk7.5 R
2018 Up! Beats
Torker
Car Model: Golf GT
Membership No: 1464
Post by Torker » Tue Jul 08, 2014 1:28 pm
mk1strand wrote:Huh whats dwell to what sory i dont much
If you look on the Main Setup screen on the Dicktator, on the right side of the screen will be a value for 'Charge Time'. If this value is too high you will oversaturate the coil and it will burn - value should be around 3mS or less...
Current rides:
mk1strand
Post by mk1strand » Tue Jul 08, 2014 1:29 pm
Ok will look now how do i change that
mk1strand
Post by mk1strand » Tue Jul 08, 2014 1:31 pm
Car starts fine now after i got it towed and everything was cold is it a posibility coil is maybe faulty
mk1strand
Post by mk1strand » Tue Jul 08, 2014 1:40 pm
mk1strand
Post by mk1strand » Tue Jul 08, 2014 1:41 pm
Its on 2.750 is that correct trigger angel is at 38
Torker
Car Model: Golf GT
Membership No: 1464
Post by Torker » Tue Jul 08, 2014 1:46 pm
mk1strand wrote:Its on 2.750 is that correct trigger angel is at 38
That will be fine, maybe check your wiring to see if it's not touching somewhere (to burn an earth connection it must touch +12V)
Current rides:
mk1strand
Post by mk1strand » Tue Jul 08, 2014 1:48 pm
I checked all look good i just started car and idled it no problems wire also stays cool i think its maybe a intermited coil i have no idea what else
mk1strand
Post by mk1strand » Tue Jul 08, 2014 1:49 pm
What wire must touch 12v+ for earth to burn?
Torker
Car Model: Golf GT
Membership No: 1464
Post by Torker » Tue Jul 08, 2014 1:49 pm
mk1strand wrote:What wire must touch 12v+ for earth to burn?
The earth wire that burned...
Current rides:
mk1strand
Post by mk1strand » Tue Jul 08, 2014 1:51 pm
Its from the coil directly to a eart on the motor not touching anywhere else its all closed neatly with heat shrink
Torker
Car Model: Golf GT
Membership No: 1464
Post by Torker » Tue Jul 08, 2014 1:57 pm
mk1strand wrote:Its from the coil directly to a eart on the motor not touching anywhere else its all closed neatly with heat shrink
That means that the problem existed in the coil at that moment - a short circuit through the coil.
Current rides:
mk1strand
Post by mk1strand » Tue Jul 08, 2014 2:00 pm
So i must replace the coil?
Torker
Car Model: Golf GT
Membership No: 1464
Post by Torker » Tue Jul 08, 2014 2:01 pm
mk1strand wrote:So i must replace the coil?
If it happens again, yes.
Current rides:
