Mp9 coil dicktator and distributor setup connection
mk1strand
Registered for: 9 years 11 months
Re: Mp9 coil dicktator and distributor setup connection
Post by mk1strand »
I will rather replace it dont want my car to burn why will it go faulty now all of a sudden is it because i changed to dickator and its straining the coil ? Must i maybe earth on a difrent place?
mk1strand
Post by mk1strand »
When the earth wired burned the car swinged like it has a flat batery and in the 1st swing the wire melted
Quik-Trix
Membership No: 3004
Post by Quik-Trix »
You sure your main earth to the body is fine?
mk1strand
Post by mk1strand »
Where is that located?
mk1strand
Post by mk1strand »
THANAS
Car Model: AW Polo GTi
Membership No: 2035
Post by THANAS »
Sounds like you have a dodgy earth. its the wire that goes from the negative terminal on the battery to the body and then to the gearbox mount.
THANAS
Membership No: 2035
Post by THANAS »
Do your car and all the electronics on your car a huge favour and upgrade that. Just think what it's doing to your ecu.
mk1strand
Post by mk1strand »
mk1strand
Post by mk1strand »
I will post secknd pic now thats how ot is connected from batery negative i just started car after work now ot starts 100% i am letting it idle now sofar no problems and wire is cold
mk1strand
Post by mk1strand »
mk1strand
Post by mk1strand »
mk1strand
Post by mk1strand »
Image cleaned all the ground connections with that and made sure it all is connected properly as the one that burned from the coil was tight but i could move it with my hand so i tightend it more took car for a small drive now it seems fine will monitor and upgrade ground wires to thickers ones as well
THANAS
Membership No: 2035
Post by THANAS »
woah man. that negative wire should connect to the body too. It looks like it goes straight from the battery to the gearbox. It should connect to the body where that little brown wire connects in the first pic.
unless I'm not seeing something.
mk1strand
Post by mk1strand »
It doesnt it goes directly to gearbox from that small brown wire a wire thick wire goes to the starter the brown wire goes into loom must i get a thick cable from negative wire that goes to gearbox to that where that brown one and other thick one meets
THANAS
Membership No: 2035
Post by THANAS »
This is the OEM layout (mounting points) I've just replaced with a thicker cable.
Battery -> Body -> Gearbox. It's good to have a cable runnin from the starter to the body, but you must ensure that there is adequate ground from the body back to the negative terminal.
mk1strand
Post by mk1strand »
Will change it then so it looks that way thank you
bjbax
Registered for: 3 years 11 months
fuelinjectors not spray
Post by bjbax »
im running a tp100 and round coil on polo 1.6i classic wich wire must i use to activate fuelinjector
