mk1 golf 85 1600 carb not idleing
- rabbit'85
- Car Model: mk1 golf
hi ive recently joined the forum because I have a series of questions that I cannot find anywhere. I have a mk1 golf 85 1600 carb that im busy converting to euro rabbit. last nite the car was fine concerning engine, after I came from work my gf picked me up in my car, when I got in and started, the car would refuse to idle. it starts and everything as long as I keep the revs up. but dies once I let go off accelerator pedal. any thoughts?
- AlexTDi
- Car Model: '15 Polo GTI
- Membership No: 1724
Re: mk1 golf 85 1600 carb not idleing
If you pull the choke does it make any difference?
Alex
VWCSA Member No. 1724
Race Car: Polo Vivo GT
Daily:
'15 6C Polo GTI DSG
'06 1.9 TDI Sportline
'06 BMW 320D M-Sport
Weekend Toy: '84 Golf MK 1 GT
Race Car: Golf MK1 2 Door
Daily:
'15 6C Polo GTI DSG
- rabbit'85
Thats it my choke messed up. It wont come out if I pull
- AlexTDi
Manually pull it on the carb, Not sure how cause I've never owned a carb motor but it should be simple.rabbit'85 wrote:Thats it my choke messed up. It wont come out if I pull
Check here: http://www.vwclub.co.za/forum/search.ph ... mit=Search
Alex
Daily:
'15 6C Polo GTI DSG
Daily:
'15 6C Polo GTI DSG
- rabbit'85
If I can spot it on wer to pull it by then engine then I would do so.
- Wave
- Fuel Additive Specialist
- Car Model: Polo TSI HL
I had the same problem on a 99 Chico 1.6
In the end got a Goldwagen "pirate" carb and slapped it on (well I got the workshop up the road to do it)
R2000 later all in and she runs like a dream, even starting better
If you want the most out, put the best in!
2017 VW Caddy Crew Bus 1.6 - NF's delivery van
2009 Toyota Fortuner 3.0 D-4D 4x4 (M) - Mine
2014 VW Polo 1.2 TSI HL - The better half's
- General
- Registered for: 18 years
- Car Model: Golf GT
- Membership No: 1464
Does the carb come with an fuel cut-off solenoid - if it does make sure the solenoid opens when you switch the ignition on. You should hear it click...
Current rides:
Hyundai - 1.4 Getz (daily)
- Neuk
- Treasurer
- Membership No: 806
Some advice I got when I had a few random carb issues...
P.S. Euro Rabbit?
- Remove carb from engine
Throw carb away
Buy FI parts
Install FI parts
Tune
P.S. Euro Rabbit?
- Wave
If I recall you can buy MP9 head + FI, ECU, wire harness for R6000 from Bishops in Edenvale
- rabbit'85
The solenoid is fine. I hear the click. Car starts no problem just 1 swing then it take but dies if I do not keep my foot on acc pedal. Sum1 suggested that I should check the throttle response as well as the air/fuel mixture. He sed it could be adjusted on the carb by some kinda pins. Is it worth checking it out.
- rabbit'85
Was thinking of going mp9. Got cylinder head, loom, and box for 1500. And to neuk, its the 85 model the one jst after euro spec
- Neuk
- Treasurer
Check the idle and mixture screws if the cut off solenoid is fine, I can't remember what the settings are, they will differ from engine to engine...
P.S. '85 model is a CitiGolf
- rabbit'85
Lol I no its citi golf. But looks more rabbit for me. So I jst get sum1 to keep the engine on a rev then turn pins to my desired settings?
- Neuk
- Treasurer
I would rather get the stock settings, leave engine off, set the carb on the stock settings, start engine and adjust from there...
P.S. Alrighty then I have not seen a lot of Rabbits in SA, one cabriolet a few years back and there was a guy rebuilding one on this forum a while back...
- rabbit'85
The guy I bort my fenders from has a 2door. Looks beautiful. How would I get the stock settings
- Neuk
- Treasurer
I would start with Google, else check some where like here...
http://vwgolfmk1.org.uk/index.php
A Haynes manual might have it as well, I know GaVeN on this forum has a book that has all the settings that we use when we service my MkI Golf.
- rabbit'85
Thanks a mil ill check it out
- blou_poot
- Registered for: 10 years
idling jet (solenoid) Is usually the culprit. Have you checked for a leak on the base plate? Take some Carb cleaner and spray it along the base of the carb while car is running... if the revs drop then replace the base plate.
96' Chico 2.0 Carb
- rabbit'85
That was another suggestion thanks blou_poot
- blou_poot
No problem... Carbs are funny...
96' Chico 2.0 Carb
- rabbit'85
Yes starting to figure out. Still busy saving for mp9
- blou_poot
Rather go aftermarket, Doing my mp9 now... and found out to late that aftermarket would have been better for future... mp9 is expensive in Namibia.
96' Chico 2.0 Carb
- rabbit'85
What you mean by afyermarket
- Car Make: Audi, Ford
- Car Model: Audi A3 2.0T, Ford Ranger
First off nice ride,rabbit looks awesome so do it and post a lot of pics .
Aftermarket like gotech, dictator and so on engine managment systems.
Can't remember the stock carb that well but the cut-off solinoid should get its power from the coil, so you can unplug it and plug back to hear if it switches while ignition is on.
Could also be dirt in carb. You can remove filter pipes from carb, rev it a little then put your hand on the carb and take it off as the engine is about to die.
Think you can get a carb kit with correct jets from goldwagen,if you want to clean and get carb back to stock.
Stupid question but did you check that the air filter is still good?
Destroy engines for science!
Don't want to own the same model car twice!
2006 Audi a3 2.0T fsi
2005 Ford Ranger 2.5 td
1994 Toyota Conquest 1600 16v(RIP)
1989 Opel kadett 1600 gse
1998 Nissan Hardbody 3.0 v6(RIP)
2002 BMW 320i
2007 Polo classic 1.9 TDI
1986 Golf mk2 1600 8v,long list of mods with 36 DCD weber(Soon to be 1.9L 16v)http://www.vwclub.co.za/forum/viewtopic ... 1&t=174876
2002 Opel Corsa C
2002 BMW 320i
2002 Opel Corsa C
- blou_poot
last time i thought my idling jet went turned out to be the coil not giving enough power. plugged up the solenoid directly to the battery just to get her homePost Posted: Mon Jun 09, 2014 9:00 pm
96' Chico 2.0 Carb
