mk1 golf 85 1600 carb not idleing
- Car Make: Audi, Ford
- Car Model: Audi A3 2.0T, Ford Ranger
Re: mk1 golf 85 1600 carb not idleing
I've also had some wierd problems with that solinoid. I used a relay to switch it for a while to prevent that coil problem.
Destroy engines for science!
Don't want to own the same model car twice!
2006 Audi a3 2.0T fsi
2005 Ford Ranger 2.5 td
1994 Toyota Conquest 1600 16v(RIP)
1989 Opel kadett 1600 gse
1998 Nissan Hardbody 3.0 v6(RIP)
2002 BMW 320i
2007 Polo classic 1.9 TDI
1986 Golf mk2 1600 8v,long list of mods with 36 DCD weber(Soon to be 1.9L 16v)http://www.vwclub.co.za/forum/viewtopic ... 1&t=174876
2002 Opel Corsa C
2002 BMW 320i
2002 Opel Corsa C
- rabbit'85
- Car Model: mk1 golf
It cant be dirt or wear and tear becoz the nite before it was perfect then next day jst ntn. So it has to be sumtin electicle or jst sumting in the carb not responding but ill check 2m morning. Keep up the suggestions im going to try everything
Just get a weber its so much easier!
2002 BMW 320i
2002 Opel Corsa C
2002 BMW 320i
2002 Opel Corsa C
- rabbit'85
Nd so much heavier on petrol
- blou_poot
- Car Model: Chico golf 1.3+Vat
and new problems...my2c
96' Chico 2.0 Carb
Actually lighter on petrol and less problems.
2002 BMW 320i
2002 Opel Corsa C
2002 BMW 320i
2002 Opel Corsa C
- blou_poot
Never heard of a weber being lighter on fuel...
96' Chico 2.0 Carb
Side draugths don't but makes good power. 36 DCD gets beter fuel consumption.
2002 BMW 320i
2002 Opel Corsa C
2002 BMW 320i
2002 Opel Corsa C
- rabbit'85
Yea I too havnt heard of a weber being light. Would love to get a dictator tho. How is it comparef to oem fuel injection?
- rabbit'85
Is 36 dcd a throttle rustedgolf?
36 dcd is a tipe of weber carburator. Its a very simple carb wich makes it easy to work on and has a wide variety of parts so can be converted to work with practicly any size engine.
Dictator i think will give beter performance then mp9 with chip because of all the fine tuning that can be done and will definitely cost less.
2002 BMW 320i
2002 Opel Corsa C
2002 BMW 320i
2002 Opel Corsa C
- rabbit'85
Nice tip. Will c which 1 works beter and is cost effective
I can't be the only one that likes weber carbs/conversions.
2002 BMW 320i
2002 Opel Corsa C
2002 BMW 320i
2002 Opel Corsa C
- blou_poot
@ruted_golf Webers sound great, give great power. Looks good aswell... but tuning can be a pain... and many of the times the webers lose the tuning. Dicktator will be better than mp9... also gonna sell my mp9 and get dicktator soon... If you not planning on a lot of mods, then i would suggest sticking to mp9.
96' Chico 2.0 Carb
- rabbit'85
Yes I heard of weber kicking itself out of tune on a regular basis. And im not a speed kinda guy, mb at a later stage ill consider tuning up my engine
- rabbit'85
Ok I checked my throttle response as well as air fuel mixture and prob still there so I adjusted the acceleration cable for a temp fix. Last thing to check would be base plate.
- rabbit'85
It was base plate. Just finished replacing it and wen I give petrol while car is off it actually sprays now. Thanks every1 for the help
- blou_poot
Great stuff knew that it would be the problem. lol years of driving a carb Now problem is with the mp9 learning curve is kaakIt was base plate. Just finished replacing it and wen I give petrol while car is off it actually sprays now. Thanks every1 for the help
96' Chico 2.0 Carb
- rabbit'85
Yes it is. But atleast im learning one how to fix things myself
- blou_poot
Just happy its sorted, good that you are learning aswell....
96' Chico 2.0 Carb
- rabbit'85
Always
Hi all,
I have a vw caddy bakkie 1600 carb. it seems to be doing a similar thing but starts cutting out even when accelerating. its fine in the mornings when its cold but in the afternoon it runs for a while then cuts off and won't even idle. please can you advise as I was on my way home and got stuck on the side of the highway.
