my engine melting the spark plugs 2E engine
Re: my engine melting the spark plugs 2E engine
when i retarding the ignition timing i get slow acceleration and bad performance and if it was ingnition timing broblem becouse i advancing it to much why the knocking is only at the 4th gear in full throttle
- mk2-phreak
Please let someone qualified look at the vehicle. You're on course to breaking it.a1aa1992 wrote:when i retarding the ignition timing i get slow acceleration and bad performance and if it was ingnition timing broblem becouse i advancing it to much why the knocking is only at the 4th gear in full throttle
i know the temp in egypt is hot but when i run with my car at high speed and this knocking happen was at 2 am and the temp was 15cgraham savage wrote:You should also remember that the car is in Cairo, the weather is very hot there and this will contribute to a knocking condition.
I would retard the timing, you have lost lots of power by advancing it so far.
- Major-General
- Registered for: 21 years 2 months
- Car Model: MK1
Try retarding ignition timing ever so slightly, use a "7" heat range single prong NGK spark plug with a gap smaller than 0.7mm and try using higher octane. Try that for starters.
Ex '02 Citi.Com 20VT K04
'80 MK1 L 2Dr 8V Throttles
Zubair Aka Boost Junkie
ZUB-AIR-RESEARCH
Boost Developments
ZUB-AIR-RESEARCH
Boost Developments
