Engine Jerks
- Roxsta
- Car Model: 9N3 Polo 1.6
Engine Jerks
Howzit People...
This is my first time here so please bare with me.
I have a 2006 Polo 1.6i Comfortline. I seem to be having a problem with it.
When I start or switch off the vehicle the car jerks violently(engine mainly) and when the car is at idle it gives of an irregular jerk.
I've done a full service on the car as well as cleaned the throttle body intake.
Can someone please assist me as to what I should try to do to resolve this issue. Help much appreciated...
- JakesN
- Registered for: 11 years
- Car Make: Suzuki
- Car Model: SX4
Re: Engine Jerks
You say you have done a full service, but did you check your plugleads, and dizzy? If either one of these is faulty you can have the problems described.
If all those check out, and sparkplugs is gapped properly like they should be, you might want to consider taking the car to someone who can plug in a diagnostics computer. It can be a host of electrical problems as well, e.g a dirty TPS or something like that.
Hope you get it sorted!!
No matter what you drive, there's always going to be a VW faster than you...
http://vwclub.co.za/forum/viewtopic.php?f=11&t=160009
- AlexTDi
- Car Model: '15 Polo GTI
- Membership No: 1724
Re: Engine Jerks
Jerks, as in shakes?
If so I would check the dogbone/lower gearbox mount and top gearbox mount under the battery as they tend to wear out after a few years.
Alex
VWCSA Member No. 1724
Race Car: Polo Vivo GT
Daily:
'15 6C Polo GTI DSG
'06 1.9 TDI Sportline
'06 BMW 320D M-Sport
Weekend Toy: '84 Golf MK 1 GT
Race Car: Golf MK1 2 Door
Daily:
'15 6C Polo GTI DSG
- Moderator
- Registered for: 19 years 5 months
- Car Model: MK7.5 GTD
- Membership No: 695
Re: Engine Jerks
Common problem on these motors is the plug leads.
They build up a corrosion on the plug side.
Build your car for yourself, not what an internet forum tells you.
Current rides
2018 MK7.5 GTD
1992 Fox 2.0 20vt
http://www.vwclub.co.za/forum/viewtopic ... 11&t=60525
My Ex Rides
1981 1.3 Escort sold
1988 1.6 VW Fox sold
1995 Jetta 3 CLI sold
1997 Vr6 Hi-jacked
2000 2.0L MK4 Golf sold
2003 1.4 TDI Highline sold
2006 Polo 1.9 S/L sold
1994 CTI 8v Turbo retired
2010 1.6 TDI Sold
2011 Polo 6RGTISold
2013 MK7 2.0L TDI DSG Sold
Current rides
2018 MK7.5 GTD
1992 Fox 2.0 20vt
My Ex Rides
1997 Vr6 Hi-jacked
2010 1.6 TDI Sold
2011 Polo 6RGTISold
- Roxsta
Re: Engine Jerks
Howzit Guys,
@ JakesN..
I have not checked plug leads nor dizzy.... What am i expected to check in the dizzy and plug leads?
I have put 2x new sets of spark plugs though and the problem is still there....
I have vcds and vas pc which i did connect the car too and does not come up with any faults.
@ 1.9TurboVw...
Yeah jerk as in shakes....
Lower gearbox mounting and top gearbox mounting underneath the battery have both been replaced and yeah they were worn out... Felt a difference there though the violent jerking is still there when starting and turning off the engine...
@ Duck...
To the naked eye the plug leads at the plug side seem to be good... no corrosion what so ever...
Any suggetions as to what plug leads i should look at when replacing them?
@ JakesN..
@ 1.9TurboVw...
@ Duck...
- JakesN
- Car Make: Suzuki
- Car Model: SX4
Re: Engine Jerks
By checking plug leads it basically just means to look out for corrosion and maybe ask someone to check the resistance. If a plug lead is damaged in the sleeve somewehere, you might not see it, but a simple resistance check on a multi-meter should help. And dizzy depends on what one you have on, if it is the older type one with cap and rotor check for cracks or burn marks. Newer type ones needs to be checked by the agents.
Noted about plugs, but did you gap them properly? A lot of sales agents tell you that plugs are ready gapped, but it never seems to be the case. No harm in checking the proper gaps.
And as for what type of plug leads, I found the Echlin or Bougicord plug leads to work best on my cars. My set of Bougicord leads on my Jetta is almost 10 years old now.
At least it is a good sign that the pc did not show any problems.
Hope you get the jerks sorted
- Roxsta
Re: Engine Jerks
Hi Jakes,
Plugs have been changed by a VW Technician(buddy of mine whom is no more around)
Agents are a bunch of rip offs thats why i seek help elsewhere....lolz
I will def get a set of Bougicord plug leads and try them out...
Yeah VCDS helps... plugged it in yesterday and came up with radio/speakers error only.
I hope so too it gets sorted cos its def annoying...
Thanks for your feedback... will try them out and let you know the outcome...
- Roxsta
Re: Engine Jerks
Howzit Guys....
So after doing a Throttle Body Adaptation, the car still has that fish bite feel to it and its really annoying now...
Though there is still a kick back when im increasing speed and when im in traffic and in first gear.... like the car is being starved or something... I have to give it extra gas for it too move and not give that kick back and jerk.
Any ideas what it could be? Help needed big time please....
Re: Engine Jerks
Sorry i know this was a long time ago., but i have the same issue at the moment and wondered if the issue has been resolved.
If not.. Anybody know of anyone that can do all the checks needed and try and fix these types of problems?
- Unobeat
- Car Model: Uno, Auris, CX-5
Re: Engine Jerks
Did you check you plug leads and when last did you service the car?
Re: Engine Jerks
Thanks, Yes service done recently at VW. Willl try plug leads next and see if it helps..
Re: Engine Jerks
Hi there
My first time on the forum. My 2004 1.6 comfort line is having the same problems. It is very jerky, and has become progerssively worse over the last month. I have changed the coil, replaced the plugs and cables, as well as the air filter. She idles hard, in that the whole car shakes when she idles. She also rides like she is out of gear and then it's as if something then finally takes and she will "wake up" but for a short while. If I accelerate slowly she doesn't jerk as much, but going above 80km she does not like. She is also a bit noisy. No smoke though so that is at least a good sign. Any advice would be appreciated. I have been told that it is the fuel pump? What do you think it could be.
Re: Engine Jerks
check compression. Have the injectors tested.
you can test fuel pressure to see if the pump is Ok.
also be aware that there are two different fuel filters available for them and the incorrect pressure one could have been used.
- Car Model: mk3 jetta 3
Re: Engine Jerks jetta 3 mk3 1995
hi guys i have a 1995 jetta 3 mk3.
gone sluggish after mechanic did idk wat to it.
i did timing myself. all indicators match.
car is a conversion and theres NO MAF(mass air flow)sensor.
my friend added a cold intake in his golf 1 and doesnt have MAF connected but car still runs fine.
i changed
coil about a year back. today i cleaned corrosion
Spark plugs today
leads today
and car still jerky and bearly goes over 100km with foot flat to ground.
before this i use to rip 325i gush before in a robot to robot
car has mods of racing fly wheel bigger pistons gti cam
please help its really depressing after a days work and still no luck
i changed
Spark plugs today
leads today
