Car wont start when switched off, only kick starting works
Hi Guys
I have a citi 2007 model and the car wont start when switched off, only kick starting it works. if i switch it off then immediately try starting it with the key it wont take just dies, any ideas ? could it be something else besides the battery?
- Cake Laaitie Killer
- Car Model: Citi 1.9i 8v
Re: Car wont start when switched off, only kick starting wor
Even if you leave the car overnight still does not start?
Correct if left for even a few minutes, switched off, it does not start.
- Car Model: GTI MK1
If you can manage to start it, take it to any battery centre, super quick, Hi Q, they will test your battery for you. Once tested they will give you a printout and if it needs to be replaced, for a citi 646 battery, bank on around R750 to R850, there was also a battery for sale at R550, just search for that.
Warren
Daily: Jetta 6 TSi
1983 GTi Mk1 2.0
Daily: Jetta 6 TSi
1983 GTi Mk1 2.0
- Stompie
- Boostleak Guru
- Car Make: BMW
- Car Model: 2006 120D
- Membership No: 1843
didnt know 2007 Citi golfs came out with a kickstarter?
sounds like a possible key coding issue or battery problem.
- Car Model: White-G5 GTi
does it atleast SWINg when you turn the key,..or dead!
Swings and the clock and odo digits that are displayed fade. i can hear the fuel pump prime when i turn the key to the on position. The battery is due for replacement anyway looks abit worse for wear. can you get a battery recharged? or serviced ?
- Neuk
- Treasurer
- Membership No: 806
Replace the battery, sounds like it is finished...
yupp battery saying bye bye...
- Membership No: 2033
Nope, it IS the battery.Del-Bosc wrote: could it be something else besides the battery?
HOWIE-WP,
Tow Car:1996 VW Golf GTi
RoadCar:2008 VW Golf5 .:R32
Got a new battery, Car seems to be fine now, will leave it for today and see what happens tomorrow morning. thanks guys for the help.
- Neuk
- Treasurer
See, I knew Howie was a wizard, it IS the battery...Howie-WP wrote:Nope, it IS the battery.Del-Bosc wrote: could it be something else besides the battery?
Yip, Captain Obvious is Obvious!Neuk wrote:See, I knew Howie was a wizard, it IS the battery...Howie-WP wrote:Nope, it IS the battery.Del-Bosc wrote: could it be something else besides the battery?
HOWIE-WP,
I agree....new battery is required, and with the coming winter and cold mornings, an already dodgy battery is just going to give you more grief.
however.....I would also look at the charging rate/alternator..as a car that has just been driven should have enough "oomph" in it to start again, it would normally take a little longer for a battery to lose its charge....unless the battery has a dead cell or two already.
anybody with a "Avo-Meter" could check your charging rate....normally around the 12.8v to 13.4v depending on electrical equipment switched on using power.
