CitiROX wont start - Please help
- Car Model: rox 1.4
please assist. the long version.
Yesterday, while trying to pull away, the car just died. It had a slight miss before it did, as it does when you are out of fuel. I could start it immediately, had to swing a bit.
Today, on my way to work in traffic, it died the same way … Twice. Third time it just refused to start.
What I have done since:
Checked both relays, they seem fine, I tested in another car I have standing at home.
Also checked the 2 big fuses next to the battery, fine as well.
I removed the 2 pipes from the filter, when I swing the motor, no fuel!
Is the fuel pump the only other possible problem?
Where is it located?
Hope I provided enough info.
- Cake Laaitie Killer
- Car Model: Citi 1.9i 8v
Re: CitiROX wont start - Please help
Fuel pump located driver side rear, under the car.
- Stompie
- Boostleak Guru
- Car Make: BMW
- Car Model: 2006 120D
- Membership No: 1843
can you hear the fuel pump when turning on the ignition or opening the door buzz?
nothing from the pump itself, but a buzzing sound from the front somewhere close to the throttle.
- Stompie
- Boostleak Guru
- Car Make: BMW
Maybe disconnect the pipe from the fuel pump and turn the car on to see if the pump is pumping. just be careful as its a couple of bar pressure going to come out the end. unless someone here has another way of testing it..
also ask Comm to move this thread to the N/a technical section, more traffic there so will get more replies
- Psycho8v
- Car Make: Toyota
- Membership No: 1881
Yeah, that's the throttle body doing it's thing, but you're supposed to hear another buzzing sound from the back. It could be an aftermarket immobilizer messing around, mabe one of the wires to the fuel pump that's poofed or the pump itself.playa69 wrote:nothing from the pump itself, but a buzzing sound from the front somewhere close to the throttle.
did that, nothing coming through.PoloGTIman wrote:Maybe disconnect the pipe from the fuel pump and turn the car on to see if the pump is pumping. just be careful as its a couple of bar pressure going to come out the end. unless someone here has another way of testing it..
- Stompie
- Boostleak Guru
- Car Make: BMW
Then either immobilizer cutting fuel relay or probably fuel pump. maybe remove your fuel pump and see if it works on the other car before you replace it!
- MeanTdi
- The Imposer Mod-whore-rator
- Car Make: Subaru
- Car Model: WRX
- Membership No: 1153
Moved to N/A engines...
Marco
Current: Subaru WRX
Ex: VW Polo 1.9 TDI Sportline
Ex: VW Golf VR6
Ex: VW Golf 1.8 GTi 16v
Current: Subaru WRX
Ex: VW Golf VR6
Small update, I removed the pump, connected it to the battery and it seems fine. Anything else? Also, no aftermarket alarm or immobilizer.
- Stompie
- Boostleak Guru
- Car Make: BMW
maybe blocked fuel filter or fuel line?
went through all of this and all i had to do was spay a bit of Q20 where the relay plugs in.
- Stompie
- Boostleak Guru
- Car Make: BMW
on my previous post i wanted to say has to be relay...but you tested it so i ruled that out.
so its working now ?
working fine. thanx for all the info guys
- Stompie
- Boostleak Guru
- Car Make: BMW
Glad u sorted bud!
