Citi 1.8 Carb idle issues
- Registered for: 11 years
- Car Make: Chevy
- Car Model: Sonic 1.6 LS B&W
Re: Citi 1.8 Carb idle issues
So generally speaking, the way forward is:
a)replace bast plate
b)get carb rebuilt
c)get it tuned properly with CO machine.
Ok thanks for the advice guys. I really appreciate the input.
Oh, the mechie told me that i should get a orig VW part (best) but costs R700+ or the next best is a Febi one (+-R200), he said the cheaper ones are just kak.
b)get carb rebuilt
Febi are fine. They last for a long time especially if the air box is properly secured. If you have the kombi air intake, lose it and put the stock one back, it helps support the carb.
- Car Make: Chevy
SO that what the nut up front is for. i have it there but its loose.
There should be a triangle bracket from two studs on the tappet cover side and then the top for the nut and rubber on the air box.King8v wrote:SO that what the nut up front is for. i have it there but its loose.
- Car Make: Chevy
The bracket is there yes, just need to tie the nut
Do it!!King8v wrote:The bracket is there yes, just need to tie the nut
- Car Make: Chevy
Done! Cant load pics cos new security protocols at work! Cant access fokkol anymore! I'm surprised i can still get onto this BB!
- MaranzanoCLX
- Car Model: Jetta MK2
Ola guys has this problem been sorted? I'm having the same prob with my Jetta clx, but i have noticed on mine she starts her dance when the fan goes on for the second time as soon as it goes off then she is fine again until it goes on again could it be my alternator trying to tell me something?
MK2 for life....
Your symptoms sound power related rather than air leak related on the carb or carb base.MaranzanoCLX wrote:Ola guys has this problem been sorted? I'm having the same prob with my Jetta clx, but i have noticed on mine she starts her dance when the fan goes on for the second time as soon as it goes off then she is fine again until it goes on again could it be my alternator trying to tell me something?
You will only know once you have taken your car to a place where they can test the alternator and check the charge voltage and current. You can also check your power and earth cables for proper and clean connections as this can also cause an increase in current draw and drop in voltage on the power circuits.
- MaranzanoCLX
Thanks Papa i've already started cleaning up connections yesterday before i left work and she felt much better but still not like i want it so gona get a new alt next month...
MK2 for life....
Hi guys i have a mk3 gsx 1800 carb right so i got the car from my parents and it was a young guys car previous where they have bought it from so the motor was and i pulled out the motor and redone it even cylenderhead so to come to the story i got it all back to normal again got the car started timing is top nodge car idles 100% note the 276 cam right so when i rev the car up it will only rev up to 300 rpms after that it wants to die what do i do could it be the distrubter losing spark when it revs up i have bought new carb and dizzy with new cap and spark wires but still no luck please if u guys can hint me on what to do next it is becoming expensive now
Bulletspunge wrote: Hi guys i have a mk3 gsx 1800 carb right so i got the car from my parents and it was a young guys car previous where they have bought it from so the motor was and i pulled out the motor and redone it even cylenderhead so to come to the story i got it all back to normal again got the car started timing is top nodge car idles 100% note the 276 cam right so when i rev the car up it will only rev up to 300 rpms after that it wants to die what do i do could it be the distrubter losing spark when it revs up i have bought new carb and dizzy with new cap and spark wires but still no luck please if u guys can hint me on what to do next it is becoming expensive now
Is it 300RPM or typing error, 3000RPM??
Did you connect all the vacuum pipes up at the same places where you took them off? Check that the 2nd stage on the carb opens up on vacuum. Did you check the crank timing on the flywheel side or on the front pulley mark? Use the flywheel TDC mark (there is a 0 mark next to it also that gives you the 6 degrees timing mark) and check that cam timing is not 180 degrees out. No:1 on the cap should be with rotor just past the mark on the face of the distributor casing.
- Car Make: Chevy
OK so this is a really old post, but I want to avoid this issue once weather gets better. I have eliminated everything and am down to the coil. Will this cause any of the issues i have experienced? I did notice during the summer months that it gets mad hot, too hot to even touch at times, is this normal?
Could also be heat transfer from exhaust manifold radiating heat onto the coil. How is it fitted in the engine bay? Picture if you can. Try moving it more to the left side of the car on the firewall to get away from exhaust manifold heat radiation.
- Car Make: Chevy
If im facing engine bay, its mounted on firewall, more right than in middle of firewall. but heat transfer could be possible. Will take a pic shortly
- Car Make: Chevy
- Car Make: Chevy
Sorry about the bay
Turn that coil around that the plug wire faces the other direction.
- Wolf Mk2 16V
The base plate you fiited, is it a rubber and steel one or all metal?
I know some guys used a solid unit thinking it won't crack again, but this causes the fuel in the float chambers to "percolate" or vaporize and cause idling and starting issues. Seems you have tried everything else hehehehe
2015 VW Golf Gti
1987 Golf GTS
1993 Citi Golf Designa 1800
2015 VW Move Up!
1987 Golf GTS
2015 VW Move Up!
- Car Model: VW Golf Plus 1.4 BUD 2007
Also found on my nephews car recently , the black wire from the carburetor to the tappet cover screw was not making contact, and the thin vacuum hose at the back of the carb goes to the vacuum advance on the distributor , then Mack sure no cracks are on the dizzy cap and rotor.
Ex : Polo Vivo, Renault Clio 3 1.6, Renault Megane and Scenic 1.9dci, Renault Clio 3 1.4, Renault Clio 2 1.4, Peugeot 308, Mini Cooper R56 1.6, Polo Tdi 1.4, Jetta 5 2.0 Tsfi Sportline, Ford Focus 2.0a, Bmw 320d E46 f/l, Citi Golf Chico 1.6, Corsa 1.7d converted with Gsi 1.6 engine, BMW X5 3.0im, Bmw 328 E36,Opel Kadett Ts by Group N Opel team, Jetta Vr6, Bmw 316i E36, Astra 160ie, UNO Turbo by Rudi, Bmw 325i Turbo by Alpine, Golf Gti16v exec, Mazda 323 Egi, Bmw e30 318i f/l
- Car Make: Chevy
ok so im almost certain that its related to the coil. y i say this is cos i ran into my issue again on saturday, pulled over and threw some water over the coil a few times, like a 2l, and issue was immediately gone. so problem has to do with heat building up in coil. anyone ever had this?
- Car Make: Chevy
i will recheck all mentioned areas again tomorrow. thnx all for the responses.
- Car Model: 1989 1600A/T FOX
That coil looks like it needed replacing 10years ago...
1989 1600 Old Man's Transmision(Automatic) VW FOX: 57mm SAC free-flow, Mp9 Airbox and cone filter adaptor, G-Cam and Vernier Pulley, Relayed Headlights, Mk1 GTi mags, CitiRox Wheelnut-caps
and CitiRox centrecaps.
http://www.vwclub.co.za/forum/viewtopic ... 1&t=151632
1976 1600SP Beetle(Sold): Believe me, it was modded and kicked ass
1991 Ford Bantam 1600(Sold): Lightly modded
