I gained 25Nm when I upped my displacement from 2.0 to 2.1, looking at going 2.2 now...CRASH_IT wrote:For the amount of power gain to amount of money to spend on ITB's its not worth it. IMHA
What I want to do to mine is a stroker kit and bore it out max. That should bring about good gains.
ABF Conversion advice
- General
- Car Model: Golf GT
- Membership No: 1464
Re: ABF Conversion advice
Current rides:
Hyundai - 1.4 Getz (daily)
- CRASH_IT
- Car Model: 8P S3
- Membership No: 1540
Now thats what im talking about 2.2 ABF.
mated to a port job and mild cams.
Anyone know what that setup might unleash on the wheels?
I know the 2.2 cranks are quite pricey tho.
I can dream for now.
CURRENT RIDE
2013 VW transporter 2.0TDI
2007 Audi S3
EX
- 2014 Ford Fiesta ST
2007 Audi S3
EX
- General
You can get to 97.5mm stroke by off-set grinding a big journal TDi crank to std big end size, 98mm if you go undersize on the big end...CRASH_IT wrote:Now thats what im talking about 2.2 ABF.
Current rides:
- Ian F's special snugglebunny
- Car Model: Caddy
- Membership No: 1548
If you have a look at dyno results from the dyno day held not too long ago.CRASH_IT wrote:Now thats what im talking about 2.2 ABF.
Freek du Preez had a 2.2 ABF on ITB's with cams and headwork and he made 172whp and over 200nm.
- CRASH_IT
- Car Model: 8P S3
but doesnt it then have the problem running bearings often?
Also im running on the 60-2 pickup.
CURRENT RIDE
2007 Audi S3
EX
2007 Audi S3
EX
- General
209Nm - one of the reasons I'm contemplating going 2.2...vdub caddy wrote:If you have a look at dyno results from the dyno day held not too long ago.CRASH_IT wrote:Now thats what im talking about 2.2 ABF.
Current rides:
- General
I've done about 10k with my TDi crank and a lot of hooliganism and my crank and bearings are still fine...CRASH_IT wrote:but doesnt it then have the problem running bearings often?
60-2 you can fabricate a bracket and run it externally.
Current rides:
- Car Model: Caddy
I know that they have had a few 2.2's in their stable and they all seem to be fine and running well.CRASH_IT wrote:but doesnt it then have the problem running bearings often?
- CRASH_IT
- Car Model: 8P S3
See now thats some NA power there.Torker wrote:209Nm - one of the reasons I'm contemplating going 2.2...vdub caddy wrote:If you have a look at dyno results from the dyno day held not too long ago.CRASH_IT wrote:Now thats what im talking about 2.2 ABF.
Whats going to stay with a 172 whp ABF. Not much.
That was on Kar's dyno?
CURRENT RIDE
2007 Audi S3
EX
2007 Audi S3
EX
- Car Model: Caddy
Yep it was hey, and it was in a stripped MK1 GT.CRASH_IT wrote: See now thats some NA power there.
Power to weight is insane.
- Car Make: SEAT
- Car Model: Golf MK1
Can anyone tell me if a cold air induction is possible on a ABF mk1 or what would be the best way to get more cold air up in the motor? Airbox is mounted up against the inside of the fender, space is abit cramped
16v
'05 velocity ABF
'95 cti
'05 velocity ABF
'95 cti
- Psycho8v
- Car Make: Toyota
- Membership No: 1881
*Stolen from Torker's thread*duncan wrote:Can anyone tell me if a cold air induction is possible on a ABF mk1 or what would be the best way to get more cold air up in the motor? Airbox is mounted up against the inside of the fender, space is abit cramped
Something like this?
- Car Make: SEAT
There's alot of PROS & CONS about running a cone filter or the airbox. Some people say the cone gets a huge amount of heat where the box is closed up, what would be best??
I've got the bigger silicon air bends straight through to the airbox, but after the box???
16v
'05 velocity ABF
'95 cti
'05 velocity ABF
'95 cti
- Barney
- Car Model: Mk3.5 Cabrio
- Membership No: 1723
Dubrun with hoofing plenty and a fully loaded car with 3 people plus 1.4ton car at the start of the run up and down I got 7.5 per 100 down and 7.8l per 100 up.Psycho1400 wrote:
But how much lighter bud? With good tuning I've heard of 2.0 8v motors that are pretty good on the open road. Barney's car gave him +-15km/l on highway driving IIRC, with a 282 cam.
2.0 with cam is light... driving style makes a massive difference. Driving to pta i got it really low mid 5l per 100, rolling traffic i will see high 8's low 9 and really bumper to bumper 10... if i just sit 110-120 on highway i see 6's
- Car Model: Golf Mk1
This is actually a really good read.. I was kinda hungry untill I read this - safe to say it's filling.. Anyway, er, sorry if this is a little off topic, but I have to know. Say you fit an O2J 'box to the ABF, would the variations in said 'boxes make a difference? Will it bolt straight on? See I've done a little research and narrowed it down to about three choices I think I have.. The DQY from the TDi Beetle, or the DZC or FBY from the Jetta IV or VR6. Also, will they fit to a 9A? Once again, sorry for thread jacking, I just have to know!!
- Barney
go 1.8t all i am saying. go aug with cable throttle. /end thread
Makes sense, good power from the turbo - but, isn't that motor even more expensive than even the ABF? I actually have a 9A already, but my uncle has an ABF he might give to me if I ask nicely.. That's why I need to know if it will fit to either.. Also, that 1.8t - uses an O2M 'box if I ain't mistaken? Don't those weigh about as much as a MK1? Wouldn't it be senseless to drop it into a fox when the gear box weighs about just as much as the entire car? Power to weight ratio can't be good.. Or am I wrong?
- Registered for: 10 years 9 months
Is those stock abf figures..? the most I have seen down here is 105 wkw stockSideSwipe wrote:That's why all you people should pack up your sh*t(including tarlton)and come down to kzn!vdub caddy wrote:Araf is in Durban hence the figures he got.Vinnige Fanie wrote:Maybe at the coast not up in Jhb stock abf is 125hp +- stock ady is 100hp.araf69 wrote:Budget yourself
ADY - 12k - 97 wkw done in 2010
ABF - 23K - 122 wkw done in 2011
Done both conversion myself.
Keep in mind both these amounts exclude labour as I done the work myself with help of my bro and friends.
From what I have seen ABF's make around 160hp in Durban.
- Barney
I am using the box that came with the cabrio. In stock for the 1.8t will make more everything than a worked abf
- General
Barney1212 wrote:I am using the box that came with the cabrio. In stock for the 1.8t will make more everything than a worked abf
This is debatable - my single throttle ABF makes 10whp more than my SIL's Polo GTi with Revo software and downpipe...
Current rides:
- Colonel
- Car Model: Golf VI R
- Membership No: 2023
This is what forums are for Please do continue learning alot!
- Barney
Ok true.
But yours are made of black magic and witchcraft
- General
LOL if you look at my previous comments I was still running an 8V, I've since converted to 16V and now own two potent 16V powered GT's...Hoosier Daddy wrote:This is what forums are for Please do continue learning alot!
Current rides:
- General
Jip - the wizard's name is Sarel...Barney1212 wrote:Ok true.
Current rides:
- Colonel
I've only ever been in one ABF powered car, and I must say I get why you guys do these conversionsTorker wrote:LOL if you look at my previous comments I was still running an 8V, I've since converted to 16V and now own two potent 16V powered GT's...Hoosier Daddy wrote:This is what forums are for Please do continue learning alot!
