ABF Conversion advice
- the_new_guy01
- Registered for: 11 years
- Car Model: MK3 Jetta CLX
Hi guys.
I am currently driving a 2001 citigolf 1.6 carb. I am interested in exchanging the current engine for either a 2l 8v(2E) or a 2l 16v(ABF). I have some questions as to which would be the best setup. I have read elsewhere that the ABF puts out more power stock than the 2E (or other 2l 8v motors) stock. Is this true? Also I intend on keeping everything as simple as possible as it is my daily drive. Any advice is welcome advice. Thanks
Visualise the win...
- Abnormal
- Membership No: 848
Re: ABF Conversion advice
Yes the abf makes more than the 2e or ady.
If you're budget allows it the abf is a good option, if not an ady will still be a nice upgrade.
\Oo) \ _w_ / (oO/
- Lazy Poes
- Car Model: Polo Gti
- Membership No: 1720
The Abf is 110kw and the ADY is 89kw IIRC, The thing is you say your car is carb so you will need to change fuel tank and then get either engine management or go side draughts.
Like Nerville said your budget will determine a lot usually its around 18k +- to go ADY and about 30k to go Abf from a carb setup.
Hope this helps.
Hope this helps.
In short a stock abf will make similar power as a modded 2E,ADY,AGG.
Parts are cheaper for the 8v's but modding them will make them heavier on fuel.
I'd say the abf is worth the price you pay.Lots and lots of potential in terms of N/a power.
Tyler Pillay
-2012 Nissan GTR Black Edition
-2007 veloCITI 1.4i+VAT
*Fark VTEC,Weed achieves greater lift*
- CRASH_IT
- Car Model: 8P S3
- Membership No: 1540
Yip boils down to your budget. Dont think you goign to just buy motor and drop it in.
Loads of things you need to do to make an ABF work.
2E is a more straight forward drop in but with you having carb it poses that extra costing in to go Fi which you will have to go either way you go.
Agree on pricing tho it might be a bit more now as Prices on motors have shot through the roof on both.Vinnige Fanie wrote:The Abf is 110kw and the ADY is 89kw IIRC, The thing is you say your car is carb so you will need to change fuel tank and then get either engine management or go side draughts.
Hope this helps.
CURRENT RIDE
2013 VW transporter 2.0TDI
2007 Audi S3
EX
- 2014 Ford Fiesta ST
2007 Audi S3
EX
- araf69
- Car Model: 2008 MK5 GTi DSG
- Membership No: 1739
Budget yourself
ADY - 12k - 97 wkw done in 2010
ABF - 23K - 122 wkw done in 2011
Done both conversion myself.
Keep in mind both these amounts exclude labour as I done the work myself with help of my bro and friends.
my rides thread : https://www.vwclub.co.za/forum/viewtopi ... 1&t=138629
2008 mk5 gti - Stealth Tuned
Ex 2005 velociti 1.6i
Ex 92 nissan 200sx 133 hp atw
Ex 85 mk1 ABF on ats cups - 122kw 198nm atw
Ex 04 2.0i ADY citi on BBS - 15.8s 1/4mile
Ex 00 Citi 1.6i 272cam TDi wheels
Ex 02 mk4 gti 19s RS6 wheels
Ex 95 uno turbo
Ex 84 mk1 2 door GT
Ex 92 uno turbo - 116 kW 222nm atw
Ex 95 uno turbo
Ex 84 mk1 2 door GT
- the_new_guy01
Thamks guys. Looks like I am going to have to put these plans on hold until I can finance the conversion. Once again thanks guys.
What did you run the abf of?
Tyler Pillay
- Ian F's special snugglebunny
- Car Model: Caddy
- Membership No: 1548
Araf69 had Gotech in his car if I am not mistaken.SideSwipe wrote:What did you run the abf of?
- araf69
My AdY was on mp9. My ABF was on gotech mfi V5. Thanks vdub caddy
Ex 95 uno turbo
Ex 84 mk1 2 door GT
Ex 95 uno turbo
Ex 84 mk1 2 door GT
- Lazy Poes
Maybe at the coast not up in Jhb stock abf is 125hp +- stock ady is 100hp.araf69 wrote:Budget yourself
- Car Model: Caddy
Araf is in Durban hence the figures he got.Vinnige Fanie wrote:Maybe at the coast not up in Jhb stock abf is 125hp +- stock ady is 100hp.araf69 wrote:Budget yourself
From what I have seen ABF's make around 160hp in Durban.
- Lazy Poes
Wonder what modded ones do.
- Scatman
- General
- Car Make: BMW
- Car Model: 320d Msport
- Membership No: 1773
If you can get your hands on an ADY/2E/AGG block with pistons and crank, you can just swop out your 1.6 with the 2.0 block. The 1.6 head is the same as the 1.8 and 2.0 heads, so you can just get a 288 cam from Nellis at Sportcam and get your carb jetted for the cam and 2.0 block. You'll also need to get the 210mm clutch kit and flywheel. Get a second hand flywheel and lighten it.
In all likelihood, if you're a little patient, this should roughly work you out as follows:
*2.0 block with pistons, crank etc = R2000-3000
*210mm flywheel and clutch kit = R1500-2000
*288 cam = R1500
*Jetting of the carb and tuning = R1400
*Service items (oil, gaskets, antifreeze, filters etc. = R1000
That adds up to R7500-9000 for about a 30wHp increase and around 50Nm increase.
An ABF will cost you a lot more, because you'll have to buy the complete motor for like R13k, and you absolutely HAVE to convert to fuel injection, which involves getting a new petrol tank from a FI citi, new fuel lines, pump, management etc.
It's up to you, but in the end if you're chasing power, you'll end up going the ABF route. The allure of the 8v is just it's simplicity and very low maintenance costs, and they are not slow when modded.
*288 cam = R1500
2008 BMW 320d Msport Auto
2006 Audi A3 2.0T
2006 BMW E90 330d Manual
*Click here*
2006 Sportline
*Click here*
*Click here*
*Click here*
2005 1.4i Citi Golf
*Click here*
2006 Audi A3 2.0T
*Click here*
2006 Sportline
*Click here*
*Click here*
*Click here*
2005 1.4i Citi Golf
*Click here*
- sjs
- Car Model: Citi & Megane RS 275 Final
- Membership No: 1315
I have done both:
Figures are from KAR in Kempton Park, Gauteng.
Modded 2l 8v ADY = heavy on fuel & 85wkw/114whp BUT a lot cheaper to buy + mod than ABF
I firstly started with a carb conversion on an ADY, then I converted my Citi to fuel injection.
I took a lot of pics, step by step.
Modded ABF = Light on fuel & 110wkw/150whp BUT expensive to buy + mod
Take a look at my ride thread (link in my signature) for pics etc of both motor swaps & modding them.
- Car Model: caddy
- Membership No: 1147
or you could spend a a little bit and convert your old petrol tank?
this is what i did with my abf conversion..
- Car Model: Caddy
I didn't even have to mod my petrol tank.dbndude wrote:or you could spend a a little bit and convert your old petrol tank?
Standard caddy tank as far as I am aware.
- Abnormal
- Car Model: caddy
Nerville wrote:No need to mod a caddy tank.
damn, looks like i got worked for my R200
not even 1982 model caddy's?
- Car Model: Caddy
Sorry bud, thats a kak one!dbndude wrote:Nerville wrote:No need to mod a caddy tank.
That's why all you people should pack up your sh*t(including tarlton)and come down to kzn!vdub caddy wrote:Araf is in Durban hence the figures he got.Vinnige Fanie wrote:Maybe at the coast not up in Jhb stock abf is 125hp +- stock ady is 100hp.araf69 wrote:Budget yourself
Tyler Pillay
- heineken
- Car Model: MKII Jetta CSL
- Membership No: 2009
Smooth Carpuretor: http://www.vwclub.co.za/phpbb3/viewtopi ... 3&t=129428
- heineken
Really ??? is the ABF lighter on fuel so it can used as a daily, nicesjs wrote:I have done both:
- Car Model: Caddy
Yeah I would love to.SideSwipe wrote:That's why all you people should pack up your sh*t(including tarlton)and come down to kzn!vdub caddy wrote: Araf is in Durban hence the figures he got.
Think I am going to start a new business by selling umbrellas on the beach.
- Psycho8v
- Car Model: Citi Golf
- Membership No: 1881
But how much lighter bud? With good tuning I've heard of 2.0 8v motors that are pretty good on the open road. Barney's car gave him +-15km/l on highway driving IIRC, with a 282 cam. My mp9 + Unichip combo gives me in +-12km/l highway driving(with some hoofing ) and my car isn't stock either?sjs wrote:I have done both:
