Jetta 1600 2002
The plug and wires on the side of the speedo assembly is good and everything else is working. it appears to be a bad connection for the speedo to work intermittently, can sometimes work for days. Any advice?
It is like it is loosing a earth somewhere, on the instrument panel?
Can someone send me info. on the speedo - like where can I find the sensor that picks up the pulses, so that I can check from the source.
The latest is it does not work anymore
speedo fault and now airbag fault?
- Velofox
- Registered for: 16 years
- Car Model: '94 FoxT 2.0 16v'
- Membership No: 1314
Re: Does somebody knows about speedo meters?
i think yours works from the ABS sensor
Current Rides
1994 2.0 16v FoxT - Lexy
1998 2.0 8v Mk3 GTI - Liesy
My Inspiration
16vT Engine Pics
My Inspiration
16vT Engine Pics
- Membership No: 388
The speed sensor sat on the gear box. 3 wires a earth positive and out put. Check the brown and black for 12v with ignition on.if there is and there is continuaty on the white and blue wire they fine.get a other sensor to test as they ususlly at fault.
That wire also sends a signal to the radio for the gala function.the signal also is sent to the engine ecu.
G60 16V GOLF
ALDO IS THE MAN WITH A GUN.
THATS HOW WE ROLL [SAINT-J]
Yes I agree with that, because I cannot find anything on the gearbox or transmission. any idea if it comes from the left front wheel?Velofox wrote:i think yours works from the ABS sensor
Its on the gearbox same place as citi golf etc would have the cable.the 1.8t and the 2l units was on diff.
Vw only started yo use the abs when they introduced the 9n polo and mk5
G60 16V GOLF
I found it on the gearbox close to the gear selection. VW wants R900.00 for a new one !! is it the best I can do
Re: Airbag fault?
Ok I got my speedo to work after I repaired the pins that corroded off in the sensor, but now I am getting a meassage "airbag fault" something I never had before. The battery volts is good and this fault came from nowhere. What can I look for?
