9n3 1.6i leaking oil.. oil pump?
- DES7
- Car Make: Fast ones
- Car Model: 1.8T GTi
Over the weekend I noticed the polo has been leaking oil and was on the min level on the stick.
Topped the oil up.
This morning took car to vw and they had a quick look, cool guy service advisor said he believes its the oil pump leaking.
Car will be booked in 2mrw morning.
Mileage is 65xxxkms, 2009 model. Car was serviced mid January at VW Hatfield Pta.
Anybody else experienced this?
I have searched and found vinnieks had a similar situation.
What does it cost to replace with labour?
Methanol Wotboxer
Ex - Polo 2.0i Blue magic
Black 135I 420wkw 834nm
Crimson red 135i
Present and Future : 2007 Polo GTi Unitronic. >283000kms
- Tander
- Registered for: 15 years
- Car Make: Seat
- Car Model: Leon Cupra
- Membership No: 1713
Re: 9n3 1.6i leaking oil.. oil pump?
Do you see oil patches on the floor in the mornings?
Or obvious signs of oil leaking - other than it being low?
2008 SEAT Leon Cupra - Banshee
Exes:
2006 Polo 9N3 - 1.6i
2003 Citi.com 1.3
2003 Opel Corsa Lite
- DES7
Yes bud.
There are oil spots on the floor.
Methanol Wotboxer
Crimson red 135i
Unless this engine is very different to any other vw i have seen before then the pump is enclosed inside the sump. For it to leak on it's own it must be moved form the sump. So i recon your very cool service guy is talking sh!t.
It's either a seal on the crank pulley or the sump that's leaking.
- DES7
let's see what this fellow does tomorrow.
How much to repair panic? labour wise
Methanol Wotboxer
Crimson red 135i
- dubdude
- Car Model: citi.com
- Membership No: 1883
It happens to quite a few polos, the oil pump bolts are loose on the front of the engine. They gonna quote u on remove and install cambelt which i think is about 2.9 hours. They dont actually remove the cambelt, they just strip off the covers and tighten the bolts and clean up. 2.9hours x R595.00 = R1725.50. Thats an estimate for u.
Dejan
Citi.com - 2.0L 8v
Citi.com - 2.0L 8v
- DES7
Oil pump to be replaced - quoted R1300. Think I heard that over the phone.
Thanks dudes..
Thanks dudes..
Methanol Wotboxer
Crimson red 135i
- SemiColon
- I sparkle in the sunlight
- Car Make: Volvo
- Car Model: S40 T5
- Membership No: 1641
Had the same issue with my oil pump, it was 'loose' or something.
八拾六
What i would is firstly is clean engin drive a day or so you should then narrow down where the oil is coming from,it is not your oil pump, the seal between gearbox and engin or sump gasket is the more likely cause.I agree that service advisor is talking ****.SemiColon wrote:Had the same issue with my oil pump, it was 'loose' or something.
- Car Make: VW, Toyota
- Car Model: 1.8 Caddy; Yaris T3 Spirit
Had the exact same issue when i reached 75k km. Turned out my oil pump was warped.
Can somebody please take a picture of this external oil pump. Must say I have not seen it. Then again i have not worked on 9m polos much. What engine code?
- Car Model: Amarok V6
- Membership No: 664
Stephan the oil pump housing sits on the outside of the crankcase just to the right and slighly above the crank on the drivers side of the motor.
I noticed it on Julies ex 1.6 9N Polo I have seen it in the 1.4 as well.. never bothered to have a look under my 2.0 polo.
Joggie Pretorius
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
VW Polo 2.0 Highline
BMW E90 320D
VW Caddy 2.0 8V
Nissan X-trail 2.0 dCi
VW Jetta 2.0 16V Turbo
VW Polo 1.6 Comfortline
BMW 335
Audi RSQ3
CURRENT CARS
VW Amarok V6 Exstream
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
BMW E90 320D
VW Caddy 2.0 8V
BMW 335
Audi RSQ3
CURRENT CARS
- dubdude
The bolts usually come loose, on BLM and BAH motors
Dejan
Citi.com - 2.0L 8v
Citi.com - 2.0L 8v
Sweet. Ok what a stupid design. The 2l is a different motor altogether.
- VWicked
- Car Model: Golf 2 GTi
- Membership No: 1492
seen this beast of a thing on my buddies 9n3 1600.
The 2.0 was the apk type mk4 motor with internal water pump i think.
1992 Golf Mk2 GTi VR6
1994 Caddy 1800 Sport
- JVA
- Car Model: A4 B8 3.0Tdi
while we're on the topic of oil leaks. My golf seems to be leaking oil from the top of the oil filter housing, is this possible?
- VWicked
yep, seal or oil filter not installed correctly.
whenever you replace a filter always clean under the housing as any oil sludge etc will cause the new filter not to seal properly
- JVA
It's not leaking from the seal though, I checked. It seems to be leaking from the top of the housing, the part which the oil filter screws onto.VWicked wrote:yep, seal or oil filter not installed correctly.
- dubdude
Oil pressure switch maybe or ur housing efd?
Dejan
Citi.com - 2.0L 8v
Citi.com - 2.0L 8v
