just over 5k for 2.0 8v in CT now from MikesCRASH_IT wrote:Engine prices for 2l 8v have gone up alot lately.
1.4i to 2.0 conversion - is it that simple?
- zain_c
Re: 1.4i to 2.0 conversion - is it that simple?
2010 Honda Accord K24
1992 MK2 Jetta CSi
ex:
86 MK2 Jetta CLX
88 MK2 Golf CSL
14 6R Polo
97 Caddy
83 MK1 GTi
04 Citi 14.7 s2s Killarney
06 MK5 Golf
92 MK2 2.0 16v GTi Exec
96 MK3 GTS
1992 MK2 Jetta CSi
ex:
86 MK2 Jetta CLX
88 MK2 Golf CSL
14 6R Polo
97 Caddy
83 MK1 GTi
06 MK5 Golf
96 MK3 GTS
- Car Model: Citi Golf 1.4i
I can get the ady motor for R 5950 and it comes with stater altenator flywheel clutch kit injection all now i want to knw can i fit it just like that or is there parts that i need to change i'm trying to get my budget work out more or less???? Wil the clutch and fly wheel fit on my gear box the guy at the engine place is telling met is wil fit and run just like it is just need a remap for the mp9 and i also want to change my fi toe the one thats om my 1.4i atm?????
- CRASH_IT
- Car Model: 8P S3
- Membership No: 1540
pretty much straight fit. Just add to you budget a service kit, crank seals, cambelt and tesioner and dizzy. I have my doubts about the flywheel fitting. so might need a 210mm flywheel and clutch kit.
You can transfer all your mp9 across. manifold, Fi bits etc and run you mp9 with a 2.0 map.
Also transfer your pulley setup across also.
CURRENT RIDE
2013 VW transporter 2.0TDI
2007 Audi S3
EX
- 2014 Ford Fiesta ST
2007 Audi S3
EX
- araf69
- Car Model: 2008 MK5 GTi DSG
- Membership No: 1739
CRASH_IT wrote:pretty much straight fit. Just add to you budget a service kit, crank seals, cambelt and tesioner and dizzy. I have my doubts about the flywheel fitting. so might need a 210mm flywheel and clutch kit.
I transferred all my stuff accross
I sold the 1.4i block, head, flywheel and clutch
Used the 1.4i alternator with pulleys,1.4i intake, starter and gearbox
my rides thread : https://www.vwclub.co.za/forum/viewtopi ... 1&t=138629
2008 mk5 gti - Stealth Tuned
Ex 2005 velociti 1.6i
Ex 92 nissan 200sx 133 hp atw
Ex 85 mk1 ABF on ats cups - 122kw 198nm atw
Ex 04 2.0i ADY citi on BBS - 15.8s 1/4mile
Ex 00 Citi 1.6i 272cam TDi wheels
Ex 02 mk4 gti 19s RS6 wheels
Ex 95 uno turbo
Ex 84 mk1 2 door GT
Ex 92 uno turbo - 116 kW 222nm atw
Ex 95 uno turbo
Ex 84 mk1 2 door GT
i'm geting the motor from engine den in pta they are R4500 no starter, altenator, or fuel injection but i can use all my 1.4 bits and just one last thing what flywheel and clutch kit is it exactly for what car?? i phoned gw and for that it's R1700+- service kit i'll get from a friend for around R500 + cam belt, tensioner just need some spesifics on the clutch and dizzy please what do i ask for??
- CRASH_IT
- Car Model: 8P S3
Ask for a 1.8 210mm flywheel and clutch kit. You should be able to use your 1.4i dizzy.
CURRENT RIDE
2007 Audi S3
EX
2007 Audi S3
EX
- chucker02
- Car Model: Citi ADY
And the adaptor ring around the dizzy as the 2L blocks dizzy hole is biggerCRASH_IT wrote:Ask for a 1.8 210mm flywheel and clutch kit. You should be able to use your 1.4i dizzy.
1971 VW beetle
1971 VW beetle
- amstel18
- Car Model: Tiguan Allspace
I bought a late model mk3 gti dizzy.
Worked for me.
Worked for me.
2022 GWM P-Series LT 4x4
2018 VW Tiguan Allspace
2006 Seat Ibiza Cupra TDI
96 1600 Chico (sold)
- chucker02
Or this, forgot about thatamstel18 wrote:I bought a late model mk3 gti dizzy.
Worked for me.
1971 VW beetle
1971 VW beetle
Hey guys. Quick question..
1.4 citi to 2E cnconversion: in terms of of wiring on injectors. 1.4 harness on the 2E. Any suggestions??
- General
- Car Model: Golf GT
- Membership No: 1464
If you are using the 2E intake manifold, you can just splice the 2E injector wiring onto the MP9 harness, other option is to use the existing MP9 intake manifold and injectors, everything will be plug and play. The last option is the better one because it will allow you to use the throttle body, MAP sensor and injectors on the existing harness.Nass wrote:Hey guys. Quick question..
Current rides:
Hyundai - 1.4 Getz (daily)
Thank you for the response...
In addition.. does the 1.4 intake manifold and injectors adapt to the 2E cylinder head with no adapter plates?
- General
Yes it's a straight fit, you can swap over the existing pulleys and alternator as well if you want to keep you engine bay 'stock' looking.Nass wrote:Thank you for the response...
Current rides:
- THANAS
- Forum Advertiser
- Car Model: AW Polo GTi
- Membership No: 2035
Yes. The bolt holes line up and it will fit, the diameter of the runner is smaller than the port size. but it doesnt matter really, I just bolted it on as is. The gasket is also the same for both the 1.4i and 2.0i heads.
1.4 injector is 6pin...and the 2.0 is a 2pin.. can the wiring harness of the 1.4 be used. If so, how?
Re: 1.6i to 2.0 conversion
Hi guys, quick question im interested in putting a 1.6i velocity Mp9 system in my 2.0L golf 4 will i be able to remove my normal fuel management system and just put that one on or how does it work ?
no. Mp 9 cannot run the stuff on that engine. it has 60-2 triggers - wasted spark and drive by wire throttle. None of which MP9 can control.
