What would cause a car to be unstable on the road?
Everything is new in the suspension. Lca rubbers, ball joints, tie rod ends dont look shot. I did new shocks, mounts etc. But still at high speed its not " sticking" in the road. Could the springs be shot? Steering rack?
[Audi A3 2.0T http://vwclub.co.za/forum/viewtopic.php?f=11&t=177350]
Polo Playa 1.6 Oo oO
Ex: Polo Playa 1.8 - Sold
- 1.8iblackie
- Car Model: vw polo classic. NO ENGINE
Re: What would cause a car to be unstable on the road?
Make sure all four wheels are still on the car.
8vT 187.2kW and 361Nm
wheel alignment, flat tyre, bearing, broken hub can be manymany things. You need to get it on a lift and really look.
- Sinbad
- Post Whore
- Car Make: Mercedes
- Membership No: 1152
Have you done alignment since you changed shocks etc?
Today i did new tyres balancing and alignment. Bearings are not humming at all. Wen they were doing alignment i went under and had a look. All bolts were tight. Nothing seemed out of place except steering rack was leaking some fluid but its always been like that and it was fine before, just started after i did shocks.
1.8iblackie wrote:Make sure all four wheels are still on the car.
Funny guy
- Tdi jetta 4 ever
Maybe play on the steering wheel? Does it have the original springs on the car? Did they check all suspension related bolts with a spanner or just by hand?
Robin
robinwisse@gmail.com
- Killerwatt
- Car Make: AUDI
- Car Model: S3
How fast are you going, whats the tyre size and is the car lowered, if so what springs?
Just trying to see if it is infact normal...
- General
- Registered for: 18 years
- Car Model: Golf GT
- Membership No: 1464
Maybe get a second opininon on that wheel alignment, I once fitted a new set of tyres and had the wheel alignment done, car didn't feel right so I took it somewhere else, guys at the 2nd place reckon I would have been lucky to get 10k out of the tyres because of shitty alignment done by the 1st place.Dubbed wrote:Today i did new tyres balancing and alignment. Bearings are not humming at all. Wen they were doing alignment i went under and had a look. All bolts were tight. Nothing seemed out of place except steering rack was leaking some fluid but its always been like that and it was fine before, just started after i did shocks.
Current rides:
Hyundai - 1.4 Getz (daily)
Anything ove 90 and it gets scary. tyre size 205/40/17, original springs, not lowered in any way. mileage is 312XXX.Killerwatt wrote:How fast are you going, whats the tyre size and is the car lowered, if so what springs?
also there is no play on the steering wheel.
No play, everything was checked with a spanner, original springsTdi jetta 4 ever wrote:Maybe play on the steering wheel? Does it have the original springs on the car? Did they check all suspension related bolts with a spanner or just by hand?
- Killerwatt
- Car Make: AUDI
- Car Model: S3
Ok something is definitly wrong then. You say it started just after shocks were replaced? Jacked up each wheel and gave it a shake to check for any looseness? wierd one this is.Dubbed wrote:Anything ove 90 and it gets scary. tyre size 205/40/17, original springs, not lowered in any way. mileage is 312XXX.Killerwatt wrote:How fast are you going, whats the tyre size and is the car lowered, if so what springs?
- SHAUN
- Post Whore
- Car Make: BMW
- Car Model: 2006 335i
- Membership No: 1148
CV joint centre nuts tight?
2006 E92 335i * Monica
1991 MKII GTI - Sold
1989 MKII CSL - Sold
Well if it was ok and then started after you did shocks then take a step back. Eithernit was in the shock install or the shock itself.
ok cool, il get them to have a look at it.panic-mechanic wrote:Well if it was ok and then started after you did shocks then take a step back. Eithernit was in the shock install or the shock itself.
Not sure, il have a look, never thought of that.SHAUN wrote:CV joint centre nuts tight?
what make of springs and what make of shocks and what make of tires are you using
Hygrade - Where winners play
Monroe shocks - probably about 3 months old, OEM springs, Wanli tyres Brand newMasterp wrote:what make of springs and what make of shocks and what make of tires are you using
- SHAUN
- Post Whore
- Car Make: BMW
That might be your problem too, I had wanli's on my polo for around 500km and then donated them to the homeless.Dubbed wrote:Wanli tyres Brand new
LMAO are they that bad?SHAUN wrote:That might be your problem too, I had wanli's on my polo for around 500km and then donated them to the homeless.Dubbed wrote:Wanli tyres Brand new
Thing is i had Dunlop before and problem was there still
- Tdi jetta 4 ever
I am just guessing here but maybe the springs didnt settle properly after the shocks was replaced.
Robin
- CRASH_IT
- Car Model: 8P S3
- Membership No: 1540
Torker wrote:Maybe get a second opininon on that wheel alignment, I once fitted a new set of tyres and had the wheel alignment done, car didn't feel right so I took it somewhere else, guys at the 2nd place reckon I would have been lucky to get 10k out of the tyres because of shitty alignment done by the 1st place.Dubbed wrote:Today i did new tyres balancing and alignment. Bearings are not humming at all. Wen they were doing alignment i went under and had a look. All bolts were tight. Nothing seemed out of place except steering rack was leaking some fluid but its always been like that and it was fine before, just started after i did shocks.
I second that!!!
I had new tyres and rims fitted car drifted all over the road. took it back and they said my swing arm was bent. Took it else where and turned out to be the alignment wasnt done right.
CURRENT RIDE
2013 VW transporter 2.0TDI
2007 Audi S3
EX
- 2014 Ford Fiesta ST
2007 Audi S3
EX
