More cooling issues with my car!
- Tander
- Registered for: 15 years
- Car Make: Seat
- Car Model: Leon Cupra
- Membership No: 1713
Howzit guys,
So, I replaced the Water pump and cam-belt this weekend on the car as the WP had failed. Refilled the cooling system with 2L of anti freeze and rest water.
Since Saturday, no issues what so ever.
All of today, she has been fine in this stupidly hot whether. However, just a few mins ago, while waiting in a queue, I noticed the temp gauge started to climb very slowly passed the 1/2 mark - no steam or anything coming from the engine either. So, I went to park and let her cool for a few mins.
What I have noticed - the fan seems to have stopped coming on.
I replaced this fan last year - so i don't think it's that.
I also opened the bonnet to check for leaks and to check coolant level - no leaks and coolant level is fine.
How can I check the fan?
Could it be a switch / fuse?
Thanks all.
Thanks all.
2008 SEAT Leon Cupra - Banshee
Exes:
2006 Polo 9N3 - 1.6i
2003 Citi.com 1.3
2003 Opel Corsa Lite
Re: More cooling issues with my car!
Thermostat?
Tyler Pillay
-2012 Nissan GTR Black Edition
-2007 veloCITI 1.4i+VAT
*Fark VTEC,Weed achieves greater lift*
- Sinbad
- Post Whore
- Car Make: Mercedes
- Membership No: 1152
Could be a fuse, relay or fan motor?
- Tander
- Car Make: Seat
That was also done last year, replaced it with a new one.SideSwipe wrote:Thermostat?
Sinbad - any idea, which fuse?
Exes:
2003 Citi.com 1.3
Jump the wires on the temp sender unit in the radiator. If fan does not come on then either it's a fuse or the fan or the fan control unit. If it comes on then either you have an airlock, or failed thermostat or failed thermo swithc. Feel the radiotor down the side. If it is cold at the bottom with the engine hot the airlock or thermostat stuck.
- Tander
- Car Make: Seat
Thanks Panic,
I'll go take a quick look with the airlock as I suspect it might just be that since I did drain all the water out of the system on Saturday and refilled.
How do I jump the wires on the temp sensor unit? And where is it located exactly?
Thanks once again
Thanks once again
Exes:
2003 Citi.com 1.3
- Tander
- Car Make: Seat
Just checked now, all sides of the radiator, including the top on bottom hoses on the right of the radiator (by battery) are all very hot - so it seems like water is going through - but something is not allowing the fan to come on.
Exes:
2003 Citi.com 1.3
- Tander
- Car Make: Seat
Is the temp sensor wire on the inlet hose at the top of the radiator?
Exes:
2003 Citi.com 1.3
- Tander
- Car Make: Seat
Okay, I have found the switch down the side of the radiator. Seems like a real mission to remove - so will do it at home.
Also, as I said before, all hoses in and out of radiator and on the sides, get hot - so I guess I can rule airlock out?
Will test the fan tonight at home.
Exes:
2003 Citi.com 1.3
- araf69
- Car Model: 2008 MK5 GTi DSG
- Membership No: 1739
Check fan switch. Happened to me on my velociti. Somehow dirt has found its way there at blocked it
my rides thread : https://www.vwclub.co.za/forum/viewtopi ... 1&t=138629
2008 mk5 gti - Stealth Tuned
Ex 2005 velociti 1.6i
Ex 92 nissan 200sx 133 hp atw
Ex 85 mk1 ABF on ats cups - 122kw 198nm atw
Ex 04 2.0i ADY citi on BBS - 15.8s 1/4mile
Ex 00 Citi 1.6i 272cam TDi wheels
Ex 02 mk4 gti 19s RS6 wheels
Ex 95 uno turbo
Ex 84 mk1 2 door GT
Ex 92 uno turbo - 116 kW 222nm atw
Ex 95 uno turbo
Ex 84 mk1 2 door GT
- Tander
- Car Make: Seat
Checked the car again when I got home. Got underneath it noticed the main power plug to fan motor was very loose.
Reseated it and made sure it was plugged in tightly.
Problem solved!
So glad I didn't have to buy new parts lol.
Thanks for the help guys.
Stupid plug!
Problem solved!
Stupid plug!
Exes:
2003 Citi.com 1.3
- PoLonY
- Car Model: A8
- Membership No: 1997
and you nearly sold the car for that
J/k bud glad you came right
- Tander
- Car Make: Seat
LOL, I've nearly sold that car for less!PoLonY wrote:and you nearly sold the car for that
Exes:
2003 Citi.com 1.3
- VW MAN
reminds me of my mk2 gti. fan wire not connected properly and stressed till me mechie pointed out the silly loose wire.
'14 Golf 7 GTI DSG White
'09 Jetta 5 2.0TSI DSG, T/Red, DP, LED Lighting, HID kit
'12 Golf 6 GTI DSG, CW - Stock
'08 Golf 5 GTI T/Red - Revo2, 216HP, 409NM
'01 Golf 4 GTI - Dimsport, Koni, Powerflow
'08 Golf 5 1.9TDI T/Red
'05 Polo Classic 1.6i (written Off)
'01 Citi Golf Chico 1.4i
'85 Golf 2 GTI - 92.2HP, 138NM - K.A.R
'98 Jetta CLI Exec Full House
'83 Golf Mk1 1300 LS (First car)
- General
- Car Model: Golf GT
- Membership No: 1464
I once changed a motor because of a loose needle and seat in the carb, when the new motor had the same problem as the old one I looked a bit harder and found out why...
Current rides:
Hyundai - 1.4 Getz (daily)
- Tander
- Car Make: Seat
All the small things hey..
Exes:
2003 Citi.com 1.3
- LYFGP0
- Car Make: BMW
- Car Model: 320D MSport
+1, mine being a blown fuse on that fuse box above the battery.VW MAN wrote:reminds me of my mk2 gti. fan wire not connected properly and stressed till me mechie pointed out the silly loose wire.
Current: '10 BMW E90 320D LCI MSport Auto - Alpine White
Ex: '96 Jetta 3 CSL - White (SOLD)
Ex: '05 Velocity 1.6i SOLD
Ex: 1.9 TDI Suety PD - TUNING (SOLD)
Ex: 1.8i Playa LYF ___ GP (SOLD)
Ex: Mazda Midge 323 160i (Sold)
LYGP 1.8i
LYGP 1.8i
boost'd wrote:"big rims are like high heels, they not comfortable to wear but they do look good"
