Citi Golf oil pump
- Cake Laaitie Killer
- Car Model: Citi 1.9i 8v
Citi Golf oil pump
Guys,
Are the oil pumps the same across the range of engines (1.3-2.0)? or is a for eg a 2.0 oil pump better flowing than a 1.6 oil pump?
My car looses oil pressure on load (when overtaking or in traffic & only when car is at full operating temp, freeway driving is fine). I have checked everything Panic mentioned in this thread http://www.vwclub.co.za/phpbb3/viewtopi ... 4&t=151451 & the only thing left to check is the oil pump itself. The pump is about 8 months old & is a Meyle item from GW. I have been told to do the following in no particular order
get a Shradeck(spelling) oil pump which is the best out there?
Change the lifters & have the head checked up?
Fit a windage tray
Baffle my sump ( I lol'd at this as I dont race track)
ANy ideas as to what could cause the issue? I honestly feel like stripping the motor & rebuild from scratch
Thanks in advance
Fit a windage tray
Thanks in advance
Re: Citi Golf oil pump
There are pumps that has more flow ie. the gears are actually taller. You should find those on the 2l.
- Psycho8v
- Car Make: Toyota
- Membership No: 1881
Can I ask a stupid question? Can it perhaps be something as small as the wrong oil being used?
Any particular brand you suggest I buy? & will this be a straight swap into my citi (1.8 8v)?panic-mechanic wrote:There are pumps that has more flow ie. the gears are actually taller. You should find those on the 2l.
I'm using the recommended 20w50 Shell Helix oil which I have been using for years with no issues. Not a stupid question btwPsycho1400 wrote:Can I ask a stupid question? Can it perhaps be something as small as the wrong oil being used?
Schadek if you can find it.
I can find it, spare shop in my area have a few in stock! Shot panic
- Bullet03
- Car Model: MK2
- Membership No: 1821
I had this issue and it turned out to be bearings
1990 Developments
BURNING RUBBER
Membership number : 1821
- 1989 CITI Golf akaPAMPOEN
*Ornament
- 1985 Mk2 16v
*Watch this space
- 2001 Opel Corsa GSI
- 2008 Honda CBR 125
- 2007 Yamaha R6
- 2008 Nissan champ
BURNING RUBBER
*Ornament
- 1985 Mk2 16v
*Watch this space
- 2007 Yamaha R6
- 2008 Nissan champ
Please explain, what was wrong with the bearing? After how long did you rectify the issue & what damage did this cause?Bullet03 wrote:I had this issue and it turned out to be bearings
- amstel18
- Car Model: Tiguan Allspace
My caddy had the same issue with the 1800 motor.
The previous oke redone the motor and it seems the clearances on the main and big ends were done wrong. when the motor reached operating temp it caused the oil pressure to drop.
Maybe have a look at the bottom end?
2022 GWM P-Series LT 4x4
2018 VW Tiguan Allspace
2006 Seat Ibiza Cupra TDI
96 1600 Chico (sold)
Will have a look this weekend. Thanks for quick feedback guys
- Mnce
- Colonel
- Car Model: MK IV Jetta
- Membership No: 1686
Sorry if this is off topic but how are you guys monitoring oil pressure whilst driving?
02 Jetta 1.9TDI
02 Jetta 1.9TDI
Check the oil pickup for possible fine cracks on top of pick up where pipe goes in to the pick up cup and also at the flange side where the 2 bolts connect the pick up pipe to the oil pump. Some pumps also have an o-ring around the pipe where this bolts on to the oil pump. Possible that when oil is cold and thicker that it seals and will open up once oil temperature is up and oil thinner when hot.
Oil pressure gauge...Mnce wrote:Sorry if this is off topic but how are you guys monitoring oil pressure whilst driving?
