1.3l citi carb problems
- PoloGirl
- Registered for: 12 years
- Car Model: 9n3 Polo 1.4 2006
- Membership No: 1842
Ok so for a while now ive been having problems with my carb, it was taken out and cleaned a few times now, the flat spot was fixed but i am busy going broke paying for petrol, I have filled her up a few times and everytime i get under 300km's on a tank WTF is up with that?
'06 1.4i 9n3 PoHi
Previous ride:
'94 1.3 Citi Golf stock
TA-Technix coilovers
all improvements done by a girl
Previous ride:
Re: 1.3l citi carb problems
Take it to somebody that still knows how a carb works. Ie. somebody with grey hair. Most modern 'mechanics' don't know how to fix a carb.
- Lord of the Sponge
- Membership No: 1676
panic-mechanic wrote:Take it to somebody that still knows how a carb works. Ie. somebody with grey hair. Most modern 'mechanics' don't know how to fix a carb.
- Car Model: 2004 Chico under construction
- Membership No: 1820
- GerhardE
- Car Model: 2008 Polo Classic 1.6
There's a mixture adjustment screw at the back left of the carb. It is recessed. If that is not set correctly your fuel consumption will go for a dive. Also make sure that when you close the choke in the cab, that it actually closes at the carb as well.
We used to adjust it as follows:
1) From being turned out turn the screw back in till the car idles at it's fastest
2) Then back it out again by 1 1/2 turn
Some other things that you can look at:
1) Adapter gasket between the carb and manifold
2) Perished fuel lines
3) Sticky float
3) Sticky float
Gerhard
2008 Polo Classic 1.6 Comfortline - Silver
so you have grey hair then
- GerhardE
Nah, not me. I just remember what we did on our Citi Golfs in the early 90's ....
Gerhard
mixture adjustment screw in the bad only works during Idle. Will do nothing to your consumption.
- graham savage
- Colonel
- Membership No: 803
You must play with the soldering iron and jet drills... don forget the lambda and dyno
has this issue been resolved , as im having the same problem
- PoloGirl
Sort of ja. I get about 490k's on a tank now. Was just taken apart again and given a good clean. I think he said he changed the ports too? But ja. Better but not completely right yet
Sent from my GT-I9300 using Tapatalk
'06 1.4i 9n3 PoHi
Previous ride:
Previous ride:
Hi there Im driving a 1.6 Carb model Chico. Maybe someone could advise me on my problem. The car detonate when the choke is open but if I close the choke a slight bit the car runs normal. My jetting is as follows
Venturi - Stage 1/2 = 20/26
Main jet - Stage 1/2 = 110/150
Air correction jet - Stage 1/2 = 100/120
Idling fuel jet = 48
Idling air jet = 120
Float needle valve = 2.5
Pump injection jet = 0.45
Enrichment valve = 45
Ive changed the coil, plug wires and distruber. Help please
giving jet sizes helps nothing. Those are pretty much the factory jets. Get it on a dyno - set timing to where it makes the best power with no detonation and see what the fuelling looks like under load. Change jet sizes till it gives you 13.2 under full power.
If it still detonates you have some other issue like overheating or a blown head gasket.
