CTI Kjet problems - what are my options?
Soljah1
Car Model: 6n1 Playa
Post by Soljah1 »
So today i had a bit of a cry, the fuel dizzy finally packed up. no fuel is being fed to the injectors.
So what i need to know now is what are my options?
was going to do a MP9 conversion in March next year but was thinking of just doing something that is cost effective now like just a management(diktator), mp9 fuel rail and injectors. not sure what else i will need. what would the cost be?
what can i do now to get the thing working again? or is it totally gone?
1300 4 speed citi 2tone - Branch free flow, 40mm lower
'95 Golf CTI - Branch Free flow - 60/40 drop - still miss her.
current:
polo playa 6n - just a zorst.
Jet Li
Membership No: 3103
Re: CTI Kjet problems - what are my options?
Post by Jet Li »
Low fuel pressure from the pump can also cause that, just confirm that your pump is 100%. More people are going EFI so it shouldn't be a problem to source a working fuel distributor for cheap.
'09 8P S3 Sportback (MT)
'10 B8 S4 V6T (DSG)
'15 6C GTi (MT)
Tee Jay
Registered for: 14 years 3 months
Car Model: Scirocco DSG
Post by Tee Jay »
Bud we just completed our latest golf 2 GTI from K-jetronic to a 2litre 2E motor. We actually map an MP9 ECU to work on the motor. If you need any help just send me a PM. My company is called Stwiggy's Service Centre.
2010 VW Scirocco DSG
Soljah1
Post by Soljah1 »
Jet Li wrote:Low fuel pressure from the pump can also cause that, just confirm that your pump is 100%. More people are going EFI so it shouldn't be a problem to source a working fuel distributor for cheap.
I didnt check the pressure. going to do that tonight even tho the petrol pump is +- 1.5years old only.
current:
VWicked
Car Model: Golf 2 GTi
Membership No: 1492
Post by VWicked »
Start with the fuel pressure as Jet li suggested.
1992 Golf Mk2 GTi VR6
1994 Caddy 1800 Sport
Soljah1
Post by Soljah1 »
VWicked wrote:Start with the fuel pressure as Jet li suggested.
What is the correct reading? 2bar?
current:
Car Make: VW, VW, Aprilia
Post by Jetta2 »
K-Jet should be around 5 Bar if I remember correctly. Panic might confirm.
Soljah1
Post by Soljah1 »
I got a properly working fuel pump today. fitted it and still no fuel going to the injector. there is fuel going to the 5th injector. and petrol going to fuel dizzy. Im stuck now.
Should i just throw the whole thing away?
current:
just tell me how you are testing the fuel to the injectors? Yes working pressure of around 5 bar.
Soljah1
Post by Soljah1 »
I havnt tested the fuel pressure yet. What I managed to do is get a new petrol pump and checked if any petrol was getting sent out of the fuel dizzy. I just removed the injector line from the dizzy to see if any petrol was getting pushed out. But nothing come out, on all 4.
I can only get a proper fuel pressure tester tomorrow or tuesday.
I even held the airflap open while my buddy swung the motor but it just sputered and died again.(this is without anything removed from the fuel dizzy.)
current:
Oh to test for fuel you must ahve the fuel pump running ie. bypassed at the relay and then lift the flap..
FADLHASSEN
Car Model: K-Jet..ta CLi
Post by FADLHASSEN »
Soljah1 wrote:I got a properly working fuel pump today. fitted it and still no fuel going to the injector. there is fuel going to the 5th injector. and petrol going to fuel dizzy. Im stuck now.
At the first sign of trouble you wana throw in the towel ,convert to this and that , WHY?
Im by no means a mechanic but have had most symptoms Kjet can throw at any one person.
Everyone knows a well tuned K-jetronic will "KEEP UP" with most modern cars ,
My Cli Jetta is GOOGLE Tuned..... take some time out , go and read :type:
Soljah1
Post by Soljah1 »
I aint giving up just yet. I actually enjoy the problem solving of it. It does become frustrating a times tho.
I was saving for a turbo upgrade so just though I might aswell change to managmet if it does come to that. Im not even going to change the head.
Plus i know the power of the Kjet.
I have the hynes manual and it helped alot with other smaller problems. Which is why i am now turning to the forum for help now.
panic-mechanic wrote:Re: CTI Kjet problems - what are my options?
Did that also.
Even made 100% sure the ignition system is working. Got new plugs leads and gave the distributor a good cleaning......
Nothing happend.
current:
FADLHASSEN
Where in CPT you stay?
I'll get my buddy to assist you if you stuck , then you cant post what the problem was.
Sorry , cant help you myself im occupied with a project and life.
MK2 G60
Registered for: 17 years 9 months
Membership No: 388
Post by MK2 G60 »
Check that there is fuel pressure at feed into dist then also check on the banjo bolts there was a very small filter.there was a tpi years ago to remove it as it blocked.then also just check the regulator on the side of the fuel dist that it also has no dirt in it.also check that the pin that the plate moves is free.
G60 16V GOLF
ALDO IS THE MAN WITH A GUN.
THATS HOW WE ROLL [SAINT-J]
Soljah1
Post by Soljah1 »
g60 golf wrote:Check that there is fuel pressure at feed into dist then also check on the banjo bolts there was a very small filter.there was a tpi years ago to remove it as it blocked.then also just check the regulator on the side of the fuel dist that it also has no dirt in it.also check that the pin that the plate moves is free.
I no speak the Lingo.
The fuel pressure is fine. Measured 5bar into all the way into the distribution block.
current:
zain_c
Car Model: Accord + MK2 Jetta CSi
Post by zain_c »
Ai! Look like i wasnt the only one having Kjet stress. :bang:
I was on the verge of giving up as well, I went as far as buying a brand new Diktator from Ferolli, sourced a 5cap 1.8 mp9 head and had it redone and port/polish and got an intake and throttle body. But before being too hasty, I read up a bit and Googled some shizz and used the search option on this forum (which works quite well these days). :fear:
When i got my car it had a very unstable idle, spluttering, pinging was sounding like fire crackers, very very thirsty on juice. Used to get 300kms on a full tank. Dizzy had to be turned down so far that the car felt dead and unresponsive, would idle very low to prevent pinging. And YET it still pinged.
All i did was buy new o-rings for the injectors, checked injectors while they were out and the spray pattern was still surprisingly very good. Although it does drool/drip on idle which gives off bad fumes. Tightened all screws/washers on any pipes to prevent air leaks, radiator flush and topped up coolant, cleaned and lubricated the plunger in the air box, replaced the inline filter that sits close to the pump infront of the rear wheel. Threw in a bottle of injector cleaner. And problem solved.
Advance the timing on dizzy after everything was done, turned the air screw on the throttle. And now the old girl is running like a steam train. No pinging (even in the CT summer heat), very responsive and oh so light on petrol. Tank is currently sitting dead centre and covered 260km's so far. :troll:
FADLHASSEN wrote:Everyone knows a well tuned K-jetronic will "KEEP UP" with most modern cars
Agreed.
2010 Honda Accord K24
1992 MK2 Jetta CSi
ex:
86 MK2 Jetta CLX
88 MK2 Golf CSL
14 6R Polo
97 Caddy
83 MK1 GTi
04 Citi 14.7 s2s Killarney
06 MK5 Golf
92 MK2 2.0 16v GTi Exec
96 MK3 GTS
zain_c
Post by zain_c »
Soljah1 wrote:Should i just throw the whole thing away?
Yeah throw it away...just make sure you throw it my way. :grin:
1992 MK2 Jetta CSi
ex:
86 MK2 Jetta CLX
88 MK2 Golf CSL
14 6R Polo
97 Caddy
83 MK1 GTi
06 MK5 Golf
96 MK3 GTS
Soljah1
Post by Soljah1 »
Lol. dont want to give up on the Kjet just yet. If everybody says its good then i must be so.
Im doing the work and stuff myself and read alot of the forum topics. But im getting someone to look at my car tomorrow but if its going to cost to much to fix then i going AFM.
current:
FADLHASSEN
Have your issues been resolved as yet?
MK2 G60
Membership No: 388
Post by MK2 G60 »
The banjo bolt are the bolts that hold the pipes onto the fuel dizzy.The main feed into the unit has a micro filter in it check that filter.
G60 16V GOLF
Soljah1
Post by Soljah1 »
it was my tank that was rusted and it was messing up the fuel dizzy.
Now i drive the car everyday atleast to the shops and back.
current:
