Panic....wont i lose on power then??
Doesnt the gotech provide more efficient power and what not??
I figured out that i only eed to connect the one power cable from the relay to something that only gets power once the ignition is turned on..... Where could i connect that, the starter maybe?? sorry if the qeustions seem stupid but im learning as im going hey, hehe
Starting a new mk1 conversion - NEED HELP!!!!
- Car Model: MK1 8v citi Golf
- Membership No: 1892
Re: Starting a new mk1 conversion - NEED HELP!!!!
ugh tough choice. crappy gotech or mp9. i'd probably go with the mp9. Anyway if you want to run the gotech you can leave the mp9 stuff. connect up the distributor and the mp9 will still switch the pump on and run the revcounter. It can also still do the idle control.
doesnt that mean that you wont be able to tune the motor with the gotech??
The gotech will then run the injectors and spark but the mp9 is still active for the other stuff. Perhaps you should get somebody to do it that knows what they are doing. If you pull the entire mp9 stuff then you have to switch the pump on amd the idle control does not work and it's a mission to get the rev counter working.
Okay, ive got everything working propperly, idling is 100%, doesnt die or anything and goes like hell, runs nice through the revs.
all wiring done now and its just the rev counter that needs to be connected...that ill do over the weekend.
now all that awaits is the dyno and tuning - any preferred people to go to for the fine tune and dyno???
- sjs
- Car Model: Citi & Megane RS 275 Final
- Membership No: 1315
What was the problem bud?Mullernewdubber wrote:Okay, ive got everything working propperly, idling is 100%, doesnt die or anything and goes like hell, runs nice through the revs.
Glad to here that it is all sorted and that you are enjoying the motor!
As you know Shane from KAR Performance tuned it for me but Gotech themselves would do a great job too (may cost more than KAR).
KAR's details:
Tel: 011 975 7125
Cell: 082 778 6425
Physical Address: 80 Plane Road
Spartan
Kempton Park
howzit SJS,
The non return valve for the brake booster was the wrong way around so that sorted out most of it but then also one of my mates plugged in the mp9's TPS sensor and the mp9 was still connected so it was also trying to regulate or something on the throttle and that sorted the extreme over feuling.
so pulled that plug an refitted all the gotech plugs to make sure they are working and fitted properly and then the non return valves and voala....bob's your uncle
- sjs
Awesome! Well done bud!Mullernewdubber wrote:howzit SJS,
