Starting a new mk1 conversion - NEED HELP!!!!
- Car Model: MK1 8v citi Golf
- Membership No: 1892
Re: Starting a new mk1 conversion - NEED HELP!!!!
so i can expect anything from 90 to 91 kw give or take.
that makes me excited, haha
thanx for all the help guys.
another thing just popped up, my friend with an ol 1.3 carb and 4 speed box wants to buy my motor, how complicated will this be???
- General
- Registered for: 18 years
- Car Model: Golf GT
- Membership No: 1464
Depends if he wants to convert to FI or keep the carb.Mullernewdubber wrote:so i can expect anything from 90 to 91 kw give or take.
Current rides:
Hyundai - 1.4 Getz (daily)
what will be easier??
prob to convert to FI
- Psycho8v
- Car Model: Citi Golf
- Membership No: 1881
Yeah, but that will add to costs. Quite a bit actually.
- General
You get a kit that allows you to use your carb intake on a FI head, use carb dizzy and low pressure electric fuel pump. If he goes FI he must get engine management, do wiring, change fuel tank and pump and so on.Mullernewdubber wrote:what will be easier??
Current rides:
- phillip
- Car Make: Ford
- Car Model: 225 ST
You making 143whp.. the reason i used Torker's 8v as an example is his 8v is running on 1 TB, I take my hat off for him making that power out a 8v.Dono82 wrote:Jip with sidies.....but the head is giving problems and the cam tooo small.
So cam is ready and the head in for engineering....
So we will see wi the bigger cam and proper head to be close in the region of +- 160 whp
Hope you achieve 160whp, will be great!!!
@ Mullernewdubber if your frind wants to convert to FI he will need a few things
FI tank
Fuel lines
Pump
Management or mp9 + wiring harness
ect
EX
City.Com ABF
Focus ST 225
City.Com ABF
Focus ST 225
well im gonna take my mp9 harnass out and my feul tank to put an efi velo feul tank, probably will take a month or two to find one, so then for him he will need only feul lines and feul pump.....
will the gearbox work though?
- General
Why do you want to change your tank, all the FI Citi tanks are the same. The gearbox will work.Mullernewdubber wrote:well im gonna take my mp9 harnass out and my feul tank to put an efi velo feul tank, probably will take a month or two to find one, so then for him he will need only feul lines and feul pump.....
Edit to add: What year model is your friends 1300, the very old ones with the forward slant motor needs some mods to the cambelt side engine mount as well.
Current rides:
he says he thinks its a 1987, doesnt know exactly as he inherited from his father and never really cared.
reason why i ask, i want to help him coz he is struggeling and doesnt want a new car or anything...he is happy with going from a to b and with this motor it will give him easily another 10 years on the car....
okay so ill keep my tank and then search for one for his car with all the extras.
what will the implication of the 4 speed be? longer gears???
- General
When I changed the 4-speed in my GT to a FFZ I worked out that 1-4 on both is just about the same, with the FFZ having the 5th gear over and above. '87 will be the same setup as yours so no sweat changing the motors. What management are you planning on running? When I did my 2.0 conversion I put all the Velo bits on the new motor and kept the existing wiring, looks stock that way.
Current rides:
im gonna run gotech mini on the motor as im getting it with the motor, im buying the full setup but my mp9 ill take out and transplant to my friends car.
so ill have a complete stand alone management, wiring im still figuring out as electronics has never been a strong point for me
- sjs
- Car Model: Citi & Megane RS 275 Final
- Membership No: 1315
Thanks bud. I'm going to miss my motor...but I'm also looking forward to my ABF setupTorker wrote:Most 2.0/8V's I've seen on here with the usual mods and 276 cam makes just over 80kW atw at Kar or RBTS, SJS's engine is actually stronger than most.Dono82 wrote:Shouldnt the motor with those specs make close to 95wkw
- sjs
Thanks bud, its a lot of funPsycho1400 wrote:No. And neither will adding a cone filter. When we joke about it, it's exactly that. A joke.Mullernewdubber wrote:will vr6 injectors make a difference from my standard 1.4i fuel rail??
That is friggin strong. No jokes. I know you can't compare dyno's, but on panic's dyno last year, 2.0 8valves with 288 cam and headwork were running about 110hp. That motor of sjs is strong.Mullernewdubber wrote:Performance:
113,6hp / 84,7 kw ATW and 140nm ATW - on the K.A.R Performance dyno, 20th January 2010
To give you an idea, I moved from a modified 1.4i to a 2.0 8v. My motor made 95hp on Dastek's dyno, and it's a hoot to drive. On wet roads, you can't just drop the hammer in first. You will spin. Sometimes even on a dry road. And this is with a 268 cam.
hi guys, okay so i picked up the engine this weekend, since no one is here that can help me do the install and im not confident enough to do this on my own ill spen some time cleaning everything up mayb respraying the block ect.
is there any place that i can buy all the plastics in red?? or will i be stuck with some things still being black and then just the red radiotor pipes ect that you can buy from autostyle??
any tips on how to clean and properly prep and paint the block??
Okay so i started this morning at 6 with the wires and what not.... One question though, is the alternator and the waterpump the same as on my 1.4? ??? I was told that i could just transplant those over to the 2 lt ady.....it fits but the alternator doesnt look like it will be able to adjust....any help???
As quick as possible as wel, i only have a weekend to do the whole conversion....
- Car Model: 2004 Chico under construction
- Membership No: 1820
Unless the 2L's Alternator is buggered, rather keep that, the 2L came with a 90A alti, and your 1.4 should have a 65A (or there about).
The waterpump should be the same but, If the 2L's pump is buggered, rather get a new one, they are cheap and you need peace of mind.
Thanks acid... Any easy ways to remove drive shaft bolts???
Go to a tool shop or Midas, and get the correct 1/2 inch drive allen or spline drive, the long shank ones work better around the boot of the CV, then just make sure you apply enough inward pressure to keep te allen drive or splinedrive in the head of the bolt, otherwise you are going to strip it, and that starts a whole different ball-ache. Where are you located again?
Centurion based
It looks like this and it works well with a ratchet and some extensions
Don't strip the bolt heads
howzit guys, okay so weve managed to get it all out and fit pulleys and everything to the new motor and the clutch and what have you, motor is still not in though as my friends had to go intertain the misses you know...
the stripped bolts came out easy once we had the right tools brought from a friend who use to be a vw diag technician, lol!!!
now i need advice on the wiring, where will i locate my mp9 box and how will how know what to take out and what to leave??
any advice on this and how to easily(if at all possible) get that out and rewire the new gotech im putting in???
guys, really really big problem....
i have the 1.4 citi and a ffz gearbox that was in with the standard motor.
now the 210mm sachs clutch and flywheel s catching on the bell housing or something, its a very horiffic sound, i was told by everyone that cluitch will run, can it be that this clutch wont run in that gearbox???
can i put the old clutch back with the 190mm flywheel!!??
There are thousands of FFZ 'boxes running around with 210mm flywheel + clutch setups with no issues.
Are you 100% sure everything was fitted together properly?
@Jetta2 - i think that is exactly the problem, it might not have been fitted correctly, ill take it in on monday to carnetics and let them pull it and refit.
as for the gotech, has anyone installed one before or similar that might be able to help, and what can i connect the managemnent to that runs on ignition???
also i was told by the previous owner of the gotech to run two lines + and - from fuel pump to gotech, but isnt that just when you convert from carb to FI with the new pump etc...
the feul pump should work just fine as it is or what??
If your currently is mp9 then why not just get your box remapped to 2l.
