Hi
When starting my 1996 golf I get a grinder noise similar to the noise you get if you hold the key in start position after the car has started. Someone told me I need to service the starter bendix and also said that one needed to jack the engine up slightly as part of this process.
Does this make sense and if so could someone please describe the process in a little more detail.
Starter grinding noise
- Wheel Whore
- Car Model: Citi Golf 1.6 Chico
- bennymanTDI
- Car Model: 9n3 TDi
Re: Starter grinding noise
It's like 2 nuts, open them and remove the starter completely and when the starter is out u can asses and repair the bendix
TDI=no smoke no fun
- Scatman
- General
- Car Make: BMW
- Car Model: 320d Msport
- Membership No: 1773
One thing I've learned over the past 6 years, is that you should rather just save a little and get a new starter. A reconditioned Bosch unit with all new internals (they just use an old starters' casing) at GW it something like R800. It will save you lots of hassles down the line and could possibly work out cheaper.
Have a look at your flywheel as well, it could be that your flywheels' teeth are a bit worn, but I doubt it.
2008 BMW 320d Msport Auto
2006 Audi A3 2.0T
2006 BMW E90 330d Manual
*Click here*
2006 Sportline
*Click here*
*Click here*
*Click here*
2005 1.4i Citi Golf
*Click here*
2006 Audi A3 2.0T
*Click here*
2006 Sportline
*Click here*
*Click here*
*Click here*
2005 1.4i Citi Golf
*Click here*
- Car Model: Amarok V6
- Membership No: 664
I would start off by taking the starter out and having a good look at it.. give the solinoid power and see it it pushes the bendix out properly and if when you take the power of it retracks properly .. It might just be dirty and a good clean with petrol might solve the issue of it might be the solenoid causing the problem.
Joggie Pretorius
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
VW Polo 2.0 Highline
BMW E90 320D
VW Caddy 2.0 8V
Nissan X-trail 2.0 dCi
VW Jetta 2.0 16V Turbo
VW Polo 1.6 Comfortline
BMW 335
Audi RSQ3
CURRENT CARS
VW Amarok V6 Exstream
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
BMW E90 320D
VW Caddy 2.0 8V
BMW 335
Audi RSQ3
CURRENT CARS
Replacing it can also work just remember to replace the little copper bush in the block .
Joggie Pretorius
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
BMW E90 320D
VW Caddy 2.0 8V
BMW 335
Audi RSQ3
CURRENT CARS
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
BMW E90 320D
VW Caddy 2.0 8V
BMW 335
Audi RSQ3
CURRENT CARS
- Wheel Whore
And the jacking up of the engine part? When does that come into it?
- Wheel Whore
Excuse my ignorance, what is GW?A reconditioned Bosch unit with all new internals (they just use an old starters' casing) at GW it something like R800
- General
- Car Model: Golf GT
- Membership No: 1464
GW = Goldwagen, a spares franchise that sells VW spares, check the web for a branch near you...fredflin wrote:Excuse my ignorance, what is GW?A reconditioned Bosch unit with all new internals (they just use an old starters' casing) at GW it something like R800
Current rides:
Hyundai - 1.4 Getz (daily)
- JVA
- Car Model: A4 B8 3.0Tdi
You can put a jack underneath your gearbox bell housing before removing the starter so the engine doesn't sag when removing the bolts, can be a mission to get them back in again if the holes dont line up properly. Remember to also replace the brass/copper bush in the block as joggie mentionedfredflin wrote:Thanks
- Scatman
- General
- Car Make: BMW
You don't need to jack the engine up hey. The front mount should stay in the same position.fredflin wrote:Thanks
2006 Audi A3 2.0T
*Click here*
2006 Sportline
*Click here*
*Click here*
*Click here*
2005 1.4i Citi Golf
*Click here*
2006 Audi A3 2.0T
*Click here*
2006 Sportline
*Click here*
*Click here*
*Click here*
2005 1.4i Citi Golf
*Click here*
