Citi Golf larger radiator, fluid capacity?
- Psycho8v
- Car Make: Toyota
- Membership No: 1881
Hi everyone.
Ok long story short, I changed motors from 1.4 to 2.0, but I still have the small radiator in. I'm looking at changing it with the larger one. How much fluid does the system take? Because I know the ratio of anti freeze is usually on the bottle, so I just want to know how much I need to throw in?
Then also, the radiator and piping that Goldwagen sell, are they good quality, or should I steer clear?
Thanks in advance.
Edit : I tried searching, but I think I'm typing in the wrong stuff.
Thanks in advance.
- Car Model: Amarok V6
- Membership No: 664
Re: Citi Golf larger radiator, fluid capacity?
Is the car over heating ?
Joggie Pretorius
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
VW Polo 2.0 Highline
BMW E90 320D
VW Caddy 2.0 8V
Nissan X-trail 2.0 dCi
VW Jetta 2.0 16V Turbo
VW Polo 1.6 Comfortline
BMW 335
Audi RSQ3
CURRENT CARS
VW Amarok V6 Exstream
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
BMW E90 320D
VW Caddy 2.0 8V
BMW 335
Audi RSQ3
CURRENT CARS
- Car Model: 18 Polo Vivo
- Membership No: 1691
I got the gw radiator pipes on my polo and have had no problems.
The Events Toy
Project Louise Drag Car
The Daily
Project CTi
The Daily
Project CTi
- Psycho8v
- Car Make: Toyota
Not overheating Joggie, but after even a short drive my fans kick in alot sooner than with the 1.4 motor, so I may be mistaken, but I think she is running a bit warmer. And I've got an irritating little water leak on the bottom pipe, only when I give it a bit of stick, it leaks, when driving normal it's fine? Dunno why? The clamp is tight.
- Psycho8v
- Car Make: Toyota
Thanks buddy. They are Topran IIRC?nd_s wrote:I got the gw radiator pipes on my polo and have had no problems.
My advice would be to get a water temp sensor and a oil temp sensor and have a look at what is going on.
Personal experiance the VW motors water temp very very seldom go over 105 deg and if so the cause is normally very high oil temps .. If you keep the oil temps below 120deg I can't see that your water temp would ever be an issue.
Might be building pressure in the pipe for some reason.. I would pour in some rad flush and drive around a day or so with it. flush the system out properly buy some decent quality clamps and clean the pipes and connections properly befor fastening them .. it should sort your issue.
Joggie Pretorius
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
BMW E90 320D
VW Caddy 2.0 8V
BMW 335
Audi RSQ3
CURRENT CARS
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
BMW E90 320D
VW Caddy 2.0 8V
BMW 335
Audi RSQ3
CURRENT CARS
- General
- Registered for: 18 years
- Car Model: Golf GT
- Membership No: 1464
I'm running a Caddy radiator in my GT, it's 6cm longer than the std Citi radiator but you can only get it from the agents at over 2k. My fans comes on less than what they did in my stock Velo so it works well for me.
Current rides:
Hyundai - 1.4 Getz (daily)
You sure someone like Silverton Radiator won't have ?
BTW a colder motor isn't always a good thing.
Joggie Pretorius
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
BMW E90 320D
VW Caddy 2.0 8V
BMW 335
Audi RSQ3
CURRENT CARS
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
BMW E90 320D
VW Caddy 2.0 8V
BMW 335
Audi RSQ3
CURRENT CARS
- Crawler
- Car Model: 9N3 Polo TDi
- Membership No: 1358
http://silvertonrads.co.za/joggiep wrote:You sure someone like Silverton Radiator won't have ?
Give us a call...
CW Polo TDi Sportline
- VWicked
- Car Model: Golf 2 GTi
- Membership No: 1492
My boet has a normal small radiator in his car on 16v and his car runs hot so I would upgrade if you can. The price is almost double though for the CTi type radiator which is longer.
1992 Golf Mk2 GTi VR6
1994 Caddy 1800 Sport
- Psycho8v
- Car Make: Toyota
Goldwagen Krugersdorp quoted me a price of R400 for the larger radiator.
@Joggie, I know that a colder motor isn't always good, as I've read somewhere that the golfs like warmer running motors?
Jip...Psycho1400 wrote:@Joggie, I know that a colder motor isn't always good, as I've read somewhere that the golfs like warmer running motors?
Saw it again with my caddy on Stephans dyno a little while ago ... it made 98HP and 148NM (after tuning it)... loaded the dyno and kept it on high RPM for a while .. did another power run and bam 101HP and 150NM ..
Best power is made when the oil temps are around 110-120deg.
Joggie Pretorius
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
BMW E90 320D
VW Caddy 2.0 8V
BMW 335
Audi RSQ3
CURRENT CARS
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
BMW E90 320D
VW Caddy 2.0 8V
BMW 335
Audi RSQ3
CURRENT CARS
- Psycho8v
- Car Make: Toyota
That is friggin cool I knew you guys said they run better, I didn't know that much better.joggiep wrote:Jip...Psycho1400 wrote:@Joggie, I know that a colder motor isn't always good, as I've read somewhere that the golfs like warmer running motors?
When I said my car is running a bit warmer, I drive home in the afternoon, and it's 120kp/h pretty much all the way, then there is a short piece in town that I drive. Probably about 1km. When I stop in front of my garage, the fan kicks in, I open the garage, I drive in and stop and switch the car off, then it kicks in again. And I don't drive like a hooligan in the town. I actually drive the 60km/h, and also don't hoof it to get there.
Fan coming on and off doesn't say that your car is running hott of over heating it's just doing it's job.
Where is the heat guage sitting ? Mine sits +- in the middle and driving like a you know what it rises just a little over half (like 2-3mm) and I'm still not anyway near worried.. Water temp on the Dyno was between 90-100deg and it's hot but still "normal". Standing still and driving in slow moving traffic will see the water temp rising as the rad is less effective.
Joggie Pretorius
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
BMW E90 320D
VW Caddy 2.0 8V
BMW 335
Audi RSQ3
CURRENT CARS
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
BMW E90 320D
VW Caddy 2.0 8V
BMW 335
Audi RSQ3
CURRENT CARS
- Psycho8v
- Car Make: Toyota
Ok cool, thanks for that Joggie. My guage sits in the middle (2004 model citi), never moves, well I've never noticed that it moves beyond half way. Maybe I'm just being a worried old fart for nothing.
MMmmmm that was kinda my thinking but I didn't whant to say itPsycho1400 wrote:Maybe I'm just being a worried old fart for nothing.
Joggie Pretorius
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
BMW E90 320D
VW Caddy 2.0 8V
BMW 335
Audi RSQ3
CURRENT CARS
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
BMW E90 320D
VW Caddy 2.0 8V
BMW 335
Audi RSQ3
CURRENT CARS
- Psycho8v
- Car Make: Toyota
joggiep wrote:MMmmmm that was kinda my thinking but I didn't whant to say itPsycho1400 wrote:Maybe I'm just being a worried old fart for nothing.
Ek het vir my nou lekker gelag.
I'll just have a look at the pipes then, to stop that tiny leak. (Just to stay on topic)
- Car Model: 2004 Chico under construction
- Membership No: 1820
I have been running the small radiator with my abf for more than a year, and I hoon it in the city and often get stuck in trafic, and have done a few club events. the fan goes on, the fan goes off, life continues, no problems
ok the answer to your original question is about 7 to 8 litres.
- Psycho8v
- Car Make: Toyota
Thanks alot Stephanpanic-mechanic wrote:ok the answer to your original question is about 7 to 8 litres.
