8v head 4 cam cap vs 5 cam cap
DEBADGE
Registered for: 15 years 5 months
Car Make: N/A
Car Model: N/A
Post by DEBADGE »
can anyone please tell me why the one is better than the other? found one of these heads with 4 cam caps on an engine a friend gave to me. Im thinking of getting some headwork done but want to find out if i should rather get the head with 5 cam caps.
Current - 2009 - Audi A4 1.8T Avant
Ex 2012 - Black Magic Pearl 6R Polo GTI
Ex 2011 - Candy White Amarok 120kw 4 motion
Ex 2009 - Candy White Golf GTI, - 180kw/394nm
Ex 1996 - Gassed Golf Vr6 - 221.6kw/439nm
Car Make: VW, VW, Aprilia
Re: 8v head 4 cam cap vs 5 cam cap
Post by Jetta2 »
No difference really. One has 5 cam caps and the other has 4. Might be minor differences in valve sizes, depending on what heads they are, but that's about it really. Unless it is a 1.4 head that has much smaller valves, combustion chamber and ports compared to the 1.6 head (1.6, 1.8 and 2.0 8V heads are the same).
And unless it is a crossflow head, then the inlet and exhaust ports sit on opposites sides.
DEBADGE
Car Make: N/A
Car Model: N/A
Post by DEBADGE »
Jetta2 wrote:No difference really. One has 5 cam caps and the other has 4. Might be minor differences in valve sizes, depending on what heads they are, but that's about it really. Unless it is a 1.4 head that has much smaller valves, combustion chamber and ports compared to the 1.6 head (1.6, 1.8 and 2.0 8V heads are the same).
thanks for the info, 40/33mm is the valve sizes. so there is no reason why i should not use this head for further mods? as far as i can figure out this head came off a AGG motor
