Polo 6N suspension issue.
- Lazy Poes
- Car Model: Polo Gti
- Membership No: 1720
Hi Guys,
So today I heard a knock noise and I see my driver side wheel sit more to the front of the car and its pulling left quite a bit, Can this be the subframe that moved? I have looked at the wishbones and they look fine from what I can see there is nothing out of place the shocks are firmly fastened.
Any advice will be great.
Thank you
Thank you
- Car Model: 18 Polo Vivo
- Membership No: 1691
Re: Polo 6N suspension issue.
What kind of knock?
From your symptoms it sounds like lca bushes on way out.
How does it feel in a straight line?
The Events Toy
Project Louise Drag Car
The Daily
Project CTi
The Daily
Project CTi
- Lazy Poes
It just pulls left but last time I did the wheel alignment they unscrewed the subframe maybe they did not tighten it enough? And Bushes are Poly bushes were done this time last year with the Koni shocks?nd_s wrote:What kind of knock?
- Stompie
- Boostleak Guru
- Car Make: BMW
- Car Model: 2006 120D
- Membership No: 1843
maybe check this...Vinnige Fanie wrote:It just pulls left but last time I did the wheel alignment they unscrewed the subframe maybe they did not tighten it enough?
how long ago did you do alignment?
- Lazy Poes
Went to Supa Quick now the front drivers side wheel bearing is stuffed so now can I drive like that home or not really?
Can chance it, But a stuffed bearing only gets worse.Vinnige Fanie wrote:Went to Supa Quick now the front drivers side wheel bearing is stuffed so now can I drive like that home or not really?
The Events Toy
The Daily
Project CTi
The Daily
Project CTi
- Lazy Poes
Ill have to nurse it home drive slowly? **** I hate these old Volkswagen's think its time for a Honda.nd_s wrote:Can chance it, But a stuffed bearing only gets worse.Vinnige Fanie wrote:Went to Supa Quick now the front drivers side wheel bearing is stuffed so now can I drive like that home or not really?
- Lord of the Sponge
- Membership No: 1676
Check loose sub frame bolts, LCA bushes and maybe even bent lower control arm itself?
Sent from my iPad using Tapatalk HD
Honda's are worse, They cost 4 times more to fix, Thats why we buried mine in the garage, Has not been seen or driven for 12 years..Vinnige Fanie wrote:Ill have to nurse it home drive slowly? f**k I hate these old Volkswagen's think its time for a Honda.nd_s wrote:Can chance it, But a stuffed bearing only gets worse.Vinnige Fanie wrote:Went to Supa Quick now the front drivers side wheel bearing is stuffed so now can I drive like that home or not really?
The Events Toy
The Daily
Project CTi
The Daily
Project CTi
- Lazy Poes
My Friend's Honda is faster and more luxurious than my car and it has not given him one single day of problems, The Subframe I think moved but the lower control arm looks straight and they say that the bushes are good as well. Simpotoms are the car pulls left and once you tap of the throttle the car feels lose on the road and the same happens when you brake.
Sounds like a broken or tierd engine mounting to me, Gearbox one or front mounting.
The Events Toy
The Daily
Project CTi
The Daily
Project CTi
His honda is alao many many years newer and more expensive. I'm not sure that what you describe is a wheel bearing. Sounds like control arm bush or lower suspension balljoint.
- Lazy Poes
His Honda is a 1999 Model same as Mine, The wheel bearing is shot they lifted the car on a 2 post jack and there is a huge amount of play on the wheel, The Ball joints look fine from what I could see and the guy there also looked and couldn't find any other faults will change the bearing tomorrow and see from there. Guess this is the kicks of older modified cars.panic-mechanic wrote:His honda is alao many many years newer and more expensive. I'm not sure that what you describe is a wheel bearing. Sounds like control arm bush or lower suspension balljoint.
Mmm that play can also be a broken hub instead of the bearing. Bearings usually make a huge amountmof noise first. Has he checked that the nut is tight in the centre.? I would be very unkeen to drive that far.
- Lazy Poes
I am also but I have to get it to Pretoria (40km) so I can get it fixed tomorrow. When I turn left on full lock there is a big klunk from the suspension. Ill see if I can stay on smaller back roads and hope for the best.panic-mechanic wrote:Mmm that play can also be a broken hub instead of the bearing. Bearings usually make a huge amountmof noise first. Has he checked that the nut is tight in the centre.? I would be very unkeen to drive that far.
Maybe check top shock mountings.I am also but I have to get it to Pretoria (40km) so I can get it fixed tomorrow. When I turn left on full lock there is a big klunk from the suspension. Ill see if I can stay on smaller back roads and hope for the best.
The Events Toy
The Daily
Project CTi
The Daily
Project CTi
- Scatman
- General
- Car Make: BMW
- Car Model: 320d Msport
- Membership No: 1773
This doesn't sound like a bearing to me. Bearings tend to die over a period of time, and you would've heard it making a noise way before you got the looseness on the wheel. Come to my house later and we'll check that big 30mm nut on your hub. A friend of mine's golf also had loads of play, but after tightening that nut it was 100%. It's worth a shot
2008 BMW 320d Msport Auto
2006 Audi A3 2.0T
2006 BMW E90 330d Manual
*Click here*
2006 Sportline
*Click here*
*Click here*
*Click here*
2005 1.4i Citi Golf
*Click here*
2006 Audi A3 2.0T
*Click here*
2006 Sportline
*Click here*
*Click here*
*Click here*
2005 1.4i Citi Golf
*Click here*
- Lazy Poes
So came to be that my one subframe bolt was missing and caused the issues.
- Scatman
- General
- Car Make: BMW
And that big nut
2006 Audi A3 2.0T
*Click here*
2006 Sportline
*Click here*
*Click here*
*Click here*
2005 1.4i Citi Golf
*Click here*
2006 Audi A3 2.0T
*Click here*
2006 Sportline
*Click here*
*Click here*
*Click here*
2005 1.4i Citi Golf
*Click here*
- Car Make: VW GOLF
- Car Model: MK1 16V ABFt
Is this the new polo shape or Your abf?Vinnige Fanie wrote:So came to be that my one subframe bolt was missing and caused the issues.
Sent from my iPhone 4s using Tapatalk
2L 16V ABFt- 180kw @ 0.8 bar @ KAR
