MK2 GTi 1.8 16v
Boep
Car Model: MK2 GTi 1.8 16v
Membership No: 1839
MK2 GTi 1.8 16v
Post by Boep »
Good morning guys...
I'm a newbie here. I also recently obtained a fairly good MK2 GTi 1.8 16v. Its not the neatest one around but it gets the heads turning. Just got to get her running properly before I start modding.
Any K-Jetronic gurus here?
Technically speaking if I turn the idle screw all the way in, the car should switch of right? If it doesn't this means that I have a leak in the intake? Have checked for leaks\ cracked or torn pipes... Nothing. The car is running ok but think it should be a lot more responsive.
Also if I rev the car on standstill the revs should drop quickly right?
It takes a while to come back down to idle... (Intake leak)
What should I be getting on tank range. I'm currently getting +- 500km to 550km on a tank.
Your assistance will be greatly appreciated.
See my rides thread http://www.vwclub.co.za/phpbb3/viewtopi ... 2#p1690093
Question: Why do women get Periods?
Answer: THEY DESERVE IT!!!
VWicked
Car Model: Golf 2 GTi
Membership No: 1492
Re: MK2 GTi 1.8 16v
Post by VWicked »
When I get some time I will be posting a DIY on how to test all the kjetronic sensors and so on.
Anyway if you looking for a kjetronic master, chat to panic-mechanic on this forum, he will be able to tune the car for you.
1992 Golf Mk2 GTi VR6
1994 Caddy 1800 Sport
Boep
Membership No: 1839
Re: MK2 GTi 1.8 16v
Post by Boep »
Ooooh weee thanks a lot. Atleast there is somebody who can help me.
I have a lot I want to learn on these beauties.
Thanks again
joggiep
Registered for: 20 years 4 months
Car Model: Amarok V6
Membership No: 664
Re: MK2 GTi 1.8 16v
Post by joggiep »
That Idle screw has a rubber washer/seal .. it sounds like it's worn. Go the VW and get a new one it was cheap as chips last time I got one (al be it 5-8 years ago) .. should sort you the issue you are discribing in all liklyhood.
Joggie Pretorius
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
VW Polo 2.0 Highline
BMW E90 320D
VW Caddy 2.0 8V
Nissan X-trail 2.0 dCi
VW Jetta 2.0 16V Turbo
VW Polo 1.6 Comfortline
BMW 335
Audi RSQ3
CURRENT CARS
VW Amarok V6 Exstream
MeanTdi
The Imposer Mod-whore-rator
Car Make: Subaru
Car Model: WRX
Membership No: 1153
Re: MK2 GTi 1.8 16v
Post by MeanTdi »
Marco
Current: Subaru WRX
Ex: VW Polo 1.9 TDI Sportline
Ex: VW Golf VR6
Ex: VW Golf 1.8 GTi 16v
Boep
Membership No: 1839
Re: MK2 GTi 1.8 16v
Post by Boep »
joggiep wrote:That Idle screw has a rubber washer/seal .. it sounds like it's worn. Go the VW and get a new one it was cheap as chips last time I got one (al be it 5-8 years ago) .. should sort you the issue you are discribing in all liklyhood.
Thanks but tried that no luck hey!
Boep
Membership No: 1839
Re: MK2 GTi 1.8 16v
Post by Boep »
Boep
Membership No: 1839
Re: MK2 GTi 1.8 16v
Post by Boep »
Boep wrote:
Thanks MeanTdi, will check into this
Will have to try and open it at home.. Just won't work here
joggiep
Membership No: 664
Re: MK2 GTi 1.8 16v
Post by joggiep »
Have you tried the old trick with some carb cleaner to try and find the vacuum leak ?
Joggie Pretorius
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
BMW E90 320D
VW Caddy 2.0 8V
BMW 335
Audi RSQ3
CURRENT CARS
Boep
Membership No: 1839
Re: MK2 GTi 1.8 16v
Post by Boep »
joggiep wrote:Have you tried the old trick with some carb cleaner to try and find the vacuum leak ?
Yes I have, nothing found . Hahaha I will find out what the problem is and keep you guys posted...
Just out of curiosity what should the KW figures be on a stock KR motor at the wheels? Like to know for when I do take mine.
joggiep
Membership No: 664
Re: MK2 GTi 1.8 16v
Post by joggiep »
Sheesh bud can't remember off hand but weren't the 1.8 16V somewhere high 90 KW ATF ?
So a good stock one around here I would say in the region of 100 - 110 HP ATW
Joggie Pretorius
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
BMW E90 320D
VW Caddy 2.0 8V
BMW 335
Audi RSQ3
CURRENT CARS
MeanTdi
Car Make: Subaru
Car Model: WRX
Membership No: 1153
Re: MK2 GTi 1.8 16v
Post by MeanTdi »
Try again. It is just a link previous threads.
http://www.vwclub.co.za/phpbb3/viewtopi ... 3&t=135524
http://www.vwclub.co.za/phpbb3/viewtopi ... 3&t=128960
Marco
Current: Subaru WRX
Ex: VW Golf VR6
VWicked
Membership No: 1492
Re: MK2 GTi 1.8 16v
Post by VWicked »
Stock KR makes around 100hp at Panic's dyno...
Boep
Membership No: 1839
Re: MK2 GTi 1.8 16v
Post by Boep »
joggiep wrote:Sheesh bud can't remember off hand but weren't the 1.8 16V somewhere high 90 KW ATF ?
Cool let me sort out my little issues and check what the dyno says... Hope to sort everything out soon
joggiep
Membership No: 664
Re: MK2 GTi 1.8 16v
Post by joggiep »
You say you think that it should be more responsive ? does it hessetate a little and then take of ?
Joggie Pretorius
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
BMW E90 320D
VW Caddy 2.0 8V
BMW 335
Audi RSQ3
CURRENT CARS
Re: MK2 GTi 1.8 16v
103 kw quoted by VW. 2l 16 v was 110.
Boep
Membership No: 1839
Re: MK2 GTi 1.8 16v
Post by Boep »
joggiep wrote:You say you think that it should be more responsive ? does it hessetate a little and then take of ?
When accelerating it revs up smoothly just not quick enough like its supposed to . Maybe I'm expecting a bit much out of the stock setup but really think something is wrong
joggiep
Membership No: 664
Re: MK2 GTi 1.8 16v
Post by joggiep »
Best bet would be to get it to Stephan and let him put it on the rollers.. only real way to see what is going on.. the old butt dyno isn't the most reliable out there.
Besides the man is a bloody legend when it comes to K-jet. If it's a tuning issue (or anything else for that matter) I'm 100% he'll be albe so help you out.
Joggie Pretorius
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
BMW E90 320D
VW Caddy 2.0 8V
BMW 335
Audi RSQ3
CURRENT CARS
Jet Li
Membership No: 3103
Re: MK2 GTi 1.8 16v
Post by Jet Li »
Whats the condition of your accelerator cable?
'09 8P S3 Sportback (MT)
'10 B8 S4 V6T (DSG)
'15 6C GTi (MT)
Boep
Membership No: 1839
Re: MK2 GTi 1.8 16v
Post by Boep »
Cable looks cool seems as if it was replaced too long ago
Boep
Membership No: 1839
Re: MK2 GTi 1.8 16v
Post by Boep »
Anybody running a good KR motor? With mods or without?
I just want to take a drive with you and see how your car pulls compare to mine
VW MAN
Re: MK2 GTi 1.8 16v
Post by VW MAN »
no better oke on the planet than panic. get that car running smooth in no time
'14 Golf 7 GTI DSG White
'09 Jetta 5 2.0TSI DSG, T/Red, DP, LED Lighting, HID kit
'12 Golf 6 GTI DSG, CW - Stock
'08 Golf 5 GTI T/Red - Revo2, 216HP, 409NM
'01
Golf 4 GTI - Dimsport, Koni, Powerflow
'08 Golf 5 1.9TDI T/Red
'05 Polo Classic 1.6i (written Off)
'01 Citi Golf Chico 1.4i
'85 Golf 2 GTI - 92.2HP, 138NM - K.A.R
'98 Jetta CLI Exec Full House
'83 Golf Mk1 1300 LS (First car)
Boep
Membership No: 1839
Re: MK2 GTi 1.8 16v
Post by Boep »
No doubt... I have only heard good things about Panic... will make an appointment with him as soon as I get some other issues sorted.
MarshallGTi
Car Model: Ibiza 1.9TDi FR
Membership No: 1665
Re: MK2 GTi 1.8 16v
Post by MarshallGTi »
500km on a tank isnt bad at all, i struggled to get 400km (albeit with a mostly heavy foot)
Ibiza FR
Ex's:
ShoeBox
(o\!/o)
My mk2 16v
Boep
Membership No: 1839
Re: MK2 GTi 1.8 16v
Post by Boep »
MarshallGTi wrote:500km on a tank isnt bad at all, i struggled to get 400km (albeit with a mostly heavy foot)
Mine is with N1 traffic
