8v Camshaft Shootout - Some results with pic
- VWicked
- Car Model: Golf 2 GTi
- Membership No: 1492
Hi,
So I am back to the age old question of which camshaft is best. Some say, it depends on what you want and where in the rev range you want the power and what mods have been done to the car.
So I proposed a test with good ol Panic Mechanic on his dyno to help the fellow guys out there with which cam does what where. The car that will be dummied for the test is a CTi 2.0 8v shortblock still on kjet.
The car currently has a 268 cam in it as I found out last night. I have access to a stock A cam, stock D cam and the 268. I can possibly get hold of a 282 cam for testing but what I need help with is the remaining ones, 272, 276 and 288 (perhaps wilder if my car can manage it).
Anyone out there got a cam to lend for testing? You are welcome to come with it to the dyno and see the results.
Regards
Jashan
Regards
Jashan
1992 Golf Mk2 GTi VR6
1994 Caddy 1800 Sport
- Car Model: Amarok V6
- Membership No: 664
Re: 8v Camshaft Shootout
Should be interesting...
Will like to come and have a look.. the 288 should still work but bigger you might run into clearance issues.
Joggie Pretorius
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
VW Polo 2.0 Highline
BMW E90 320D
VW Caddy 2.0 8V
Nissan X-trail 2.0 dCi
VW Jetta 2.0 16V Turbo
VW Polo 1.6 Comfortline
BMW 335
Audi RSQ3
CURRENT CARS
VW Amarok V6 Exstream
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
BMW E90 320D
VW Caddy 2.0 8V
BMW 335
Audi RSQ3
CURRENT CARS
- VWicked
You welcome to come through, you can help me swop them out hehe.
288 will definitely work and i would think max on that car but if we get a wilder test unit and I will fill some nice 95 we can see what it does.
Can clearnce the head for a 298 no problems.
Sweet.. I'll help out... Just say when...VWicked wrote:You welcome to come through, you can help me swop them out hehe.
Ps get a few 8mm studs and nutts just in case
Joggie Pretorius
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
BMW E90 320D
VW Caddy 2.0 8V
BMW 335
Audi RSQ3
CURRENT CARS
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
BMW E90 320D
VW Caddy 2.0 8V
BMW 335
Audi RSQ3
CURRENT CARS
- Abnormal
- Membership No: 848
- VWicked
I will do, need to find a few cams first.
@Nerville, I will buy two extra gaskets just for the test if they cause ****.
Stephan do you have a few 8v cam pulleys lying around with woodruff keys?
Maybe not a few but at least one so we can swop. Maybe before the time we can convert your car to the rubber gasket setup.
- Abnormal
win.panic-mechanic wrote:Maybe not a few but at least one so we can swop. Maybe before the time we can convert your car to the rubber gasket setup.
\Oo) \ _w_ / (oO/
- VWicked
Ok I am comfortable doing that as I do need to buy a new gasket anyway. Will that stock tappet work with the rubber gasket?
- General
- Car Model: Golf GT
- Membership No: 1464
Easy to do, you need to pull the studs out and replace with M6 bolts, I used s/s cap screws.VWicked wrote:Ok I am comfortable doing that as I do need to buy a new gasket anyway. Will that stock tappet work with the rubber gasket?
Current rides:
Hyundai - 1.4 Getz (daily)
- Killerwatt
- Car Make: AUDI
- Car Model: S3
I think I have 1 or two pulleys at home with the keys. Also have the high lift a cam and a g cam I think.
Would also like to come through if nobody minds.
- Abnormal
would be nice to replicate this test with 1.4, 1.6 and 2.0L
\Oo) \ _w_ / (oO/
- Scatman
- General
- Car Make: BMW
- Car Model: 320d Msport
- Membership No: 1773
This will be interesting! Looking forward to this happening.
I have a 1.4i with a DIY port and flow job Don't mind donating the car for the dayNerville wrote:would be nice to replicate this test with 1.4, 1.6 and 2.0L
2008 BMW 320d Msport Auto
2006 Audi A3 2.0T
2006 BMW E90 330d Manual
*Click here*
2006 Sportline
*Click here*
*Click here*
*Click here*
2005 1.4i Citi Golf
*Click here*
2006 Audi A3 2.0T
*Click here*
2006 Sportline
*Click here*
*Click here*
*Click here*
2005 1.4i Citi Golf
*Click here*
- VWicked
Okay I don't understand why this would make a difference? is its an m6 stud and nut vs if its a boltTorker wrote:Easy to do, you need to pull the studs out and replace with M6 bolts, I used s/s cap screws.VWicked wrote:Ok I am comfortable doing that as I do need to buy a new gasket anyway. Will that stock tappet work with the rubber gasket?
- General
The stud got a built-in spacer for the cork gasket.VWicked wrote:Okay I don't understand why this would make a difference? is its an m6 stud and nut vs if its a boltTorker wrote:Easy to do, you need to pull the studs out and replace with M6 bolts, I used s/s cap screws.VWicked wrote:Ok I am comfortable doing that as I do need to buy a new gasket anyway. Will that stock tappet work with the rubber gasket?
Current rides:
- VWicked
You most welcome to come through especially with the camsKillerwatt wrote:I think I have 1 or two pulleys at home with the keys. Also have the high lift a cam and a g cam I think.
What did the poor 1.8's do to you Nerville?Nerville wrote:would be nice to replicate this test with 1.4, 1.6 and 2.0L
- VWicked
Ah makes sense, so basically you cant tighten it enough if you use rubber gasket?Torker wrote:The stud got a built-in spacer for the cork gasket.VWicked wrote:Okay I don't understand why this would make a difference? is its an m6 stud and nut vs if its a boltTorker wrote:
The cork gasket has a bolt with a collar that holds the gasket in place so youbpull them out and either replace with a stud with no collar or bolts.
Definately not doing that amount of work on 2 cars unless somebody else volunteers to do the actual cam swops.
- Scatman
- General
- Car Make: BMW
Yes Get some nice stainless steel studs, I wanna get some for my Audi and GolfVWicked wrote:
I'll help with the cam swopspanic-mechanic wrote:The cork gasket has a bolt with a collar that holds the gasket in place so youbpull them out and either replace with a stud with no collar or bolts.
2006 Audi A3 2.0T
*Click here*
2006 Sportline
*Click here*
*Click here*
*Click here*
2005 1.4i Citi Golf
*Click here*
2006 Audi A3 2.0T
*Click here*
2006 Sportline
*Click here*
*Click here*
*Click here*
2005 1.4i Citi Golf
*Click here*
- Abnormal
when you said CTi I assumed 1.8VWicked wrote: What did the poor 1.8's do to you Nerville?
\Oo) \ _w_ / (oO/
- AlexTDi
- Car Model: '15 Polo GTI
- Membership No: 1724
Will the 288 in the Rat be of any help?
Alex
VWCSA Member No. 1724
Race Car: Polo Vivo GT
Daily:
'15 6C Polo GTI DSG
'06 1.9 TDI Sportline
'06 BMW 320D M-Sport
Weekend Toy: '84 Golf MK 1 GT
Race Car: Golf MK1 2 Door
Daily:
'15 6C Polo GTI DSG
- VWicked
Well, we will see what is it cos it got one SAC conversion anoll.Nerville wrote:when you said CTi I assumed 1.8VWicked wrote: What did the poor 1.8's do to you Nerville?
- Scatman
- General
- Car Make: BMW
Yes, I've always wanted to put a 288 in the 1.4 and see if it makes any power1.9TurboVw wrote:Will the 288 in the Rat be of any help?
2006 Audi A3 2.0T
*Click here*
2006 Sportline
*Click here*
*Click here*
*Click here*
2005 1.4i Citi Golf
*Click here*
2006 Audi A3 2.0T
*Click here*
2006 Sportline
*Click here*
*Click here*
*Click here*
2005 1.4i Citi Golf
*Click here*
- Lazy Poes
- Car Model: Polo Gti
- Membership No: 1720
DafaqScatman wrote:Yes, I've always wanted to put a 288 in the 1.4 and see if it makes any power1.9TurboVw wrote:Will the 288 in the Rat be of any help?
