2009 Citi Sport 1.4i died not starting
- Dub rox
- Car Model: Citi sport 1.4i
Hi guys. I'm new to this forum and could not find any related topics so here goes... My toy just opt out about a week ago while idling.Every thing was fine exept the ignition timing that i had to set but had to get the car to someone with the vag software to get it in timing mode. Well as i mentioned the car was idling till the fan kicked in and then died whith a pinging sound. I hoped for the best and checked the timing belt and timing. All was 100%. Tried to start again with no avail. I started by eliminating the fuel filter wich i replaced and then the coil and complete distributor as ther was no fire. I also checked the two fuses next to the battery and reset the service light .This issue is giving me sleapless nights and any help and advice as to what the problem could be would be appriciated.
Sent from my VFD 1100 using Tapatalk
- Dub rox
Re: 2009 Citi Sport 1.4i died not starting
If anyone knows the hall sender vallues please post. Guess i'll start at the dissy. If anyone knows these ecu's could you tell me if it could go into a safe or limp mode for some strange reason? Im dumb struck as to what the sudden problem could be. Thanx
- Car Make: VW Golf 1
- Car Model: 2.0 h8 valve
Sounds like the MPI system is fried- considering the year model you would have the MPI system and I've heard and see them go all wrong
- Dub rox
Thanx for the reply. It's not mp9 so must be mpi. Any ideas as to what coul cause the problem?8VALVE-zn wrote:Sounds like the MPI system is fried- considering the year model you would have the MPI system and I've heard and see them go all wrong
09 citi sport is definitely mpi
If im not mistaken, faulty mpi ecu's start adding too much fuel or mess up timing. There could also be other symptoms aswell..
Try scanning the car for fault codes amd probably view live data.. if u know what they ecu is seeing it would help.
O2 sensor codes are scary..
Long story short, mpi is a rubbish system then fails very commonly.
There are alot of posts here with mpi issues, u can go through them..
Was ur car running too rich?
- Dub rox
It was running a bit rich and hunting because of the ignition timing i had to set but still needed to get the car into timing mode.Will most probably go for after market ecu. Better for future mods and less issues and more easily interfaceable. Shopping on gotech systems for the moment.Any advice and school fees payd in this regard?Ashveer03 wrote:09 citi sport is definitely mpi
Decide on who is gonna tune ur car, and ask them what ecu they prefer to work with..
I know people using all different types of managements and they all seem to work reasonably ok. I think some are more difficult to use than others and probably features differ, that is one of the reasons u should check with your tuner first
- Dub rox
Spoke to the guys at gotech in alberton, they seem to know a fair bit and the turnaround time is fairly fast. (One day)Ashveer03 wrote:Decide on who is gonna tune ur car, and ask them what ecu they prefer to work with..
Gotech it is then.. all the best bud.. let us know how it goes
- Dub rox
Thanx. Will doAshveer03 wrote:Gotech it is then.. all the best bud.. let us know how it goes
