Mk3 GS 1.6 Carb
Mk3 GS 1.6 Carb
Morning guys,
So I'm tired of cold winter mornings cause my car refuses to start
I spray quick start and it starts, but instantly dies.
The cery same day in the afternoon when I can get back from work the car starts at first swing.
I swear it's like two different cars.
Not sure if it's a carb related issue.
So I'm thinking for converting to 2.0L MP9 or even just converting my current motor to MP9.
Anyone that can assist?
Want to know how much for supply and labour would cost or a place that I can contact for a quote?
- Sean Trollope
- Car Make: VW. Hyundai.
- Car Model: Citi golf. Hyundai i10
Re: Mk3 GS 1.6 Carb
Right so there is this magical device called a choke
Re: Mk3 GS 1.6 Carb
Choke doesn't help
Whether I pull it out slightly or full
- Sean Trollope
Re: Mk3 GS 1.6 Carb
Check that the tension in the cable is correct.
Re: Mk3 GS 1.6 Carb
It opens and closes the flap as you either pull the choke in or out.
Re: Mk3 GS 1.6 Carb
It's clearly a fuel,supplybissue if it starts with quick start.. So check th carb base plate and check the pump that it delivers fuel.
Put you hand on top of thencarb and let somebody crank it. See that a decent vacuum is pulled. Ie no leaks in the intake side.
Then also adjust the idle mixture to be richer
Re: Mk3 GS 1.6 Carb
If its a fuel supply then wouldn't it struggle to start in the afternoons
It's only cold mornings or cold evenings
If the temperature is okay then it starts with no issue
Re: Mk3 GS 1.6 Carb
What's a cold start switch and can that be an issue?
Re: Mk3 GS 1.6 Carb
What is cold start switch? Don't know such a thing.
A warm engine needs a lot less fuel. But hey rather keep guessing and or sell it than try a few of the things I suggested.
Re: Mk3 GS 1.6 Carb
Have you tried giving small pumps on the accelerator pedal while swinging the starter?
Does it eventually start in the mornings?
And if it does, how does it run?
Is there any smell of unburnt fuel?
I ask this because even at freezing temperatures, I can start my Fox (carb 1.6) without the choke, if I must.
- Car Model: 1998 Polo Classic 1.8
Re: Mk3 GS 1.6 Carb
Are you spraying the quickstart directly into the carb or up the intake pipe( filterbox)?
1998 Polo Classic 1.8 with added "benefits"
Re: Mk3 GS 1.6 Carb
So the issue was the carb itself...
I put another carb in and car is better than ever!
Did timing as well and adjusted the carb accordingly so now car starts with no issues and also has alot more power.
