Good evening good people, please could someone tell me what does this mean? I'm getting this fault on cylinder 1-3. Cylinder Pump or injector valve control limit exceeded.
Please assist
Fault codes
- Registered for: 2 years 3 months
Re: Fault codes
2004 1.9 tdi
That's is the fault and the numbers are P1261 cylinder 1 Pump or injector valve control limit exceeded , P1264 cylinder 2 Pump or injector valve control limit exceeded and P1267 Pump or injector valve control limit exceeded this is the fault codes
Re: Fault codes
The code is basically telling u that those Injectors are reaching/exceeding their control limits.
If there was cylinder head repair recently done its possible that the injector lash wasn't set correctly.
If not, could have an eaten camshaft or just dud injectors
Re: Fault codes
This is where you start lookingAshveer03 wrote:The code is basically telling u that those Injectors are reaching/exceeding their control limits.
