Hey guy's so I have been noticing my brakes are getting a bit stiff on a downhill and hard as f when I used it once and step on it again. Stop this afternoon and opend the Bonnet for a quick inspection found that vacuum pipe fitting from the pump to the booster pipe is a bit loose. How do remove the fitting or do I need to remove the whole pump to replace oring?
Sent from my EML-L09 using Tapatalk
Vacuum pump booster pipe
- Jakkels85
- Registered for: 10 years 9 months
- Car Model: Mk1 2 door 16v turbo
- Jakkels85
Re: Vacuum pump booster pipe
Got it sorted and bought a new pump.Jakkels85 wrote:Hey guy's so I have been noticing my brakes are getting a bit stiff on a downhill and hard as f when I used it once and step on it again. Stop this afternoon and opend the Bonnet for a quick inspection found that vacuum pipe fitting from the pump to the booster pipe is a bit loose. How do remove the fitting or do I need to remove the whole pump to replace oring?
- Car Make: Cheap Ass Porsche
- Car Model: 9N Sooter
- Membership No: 807
There was a post not too long ago about this... someone had similar issues.
I had a Bosch as OE and it leaked oil, replaced with a Borschung and that particular fitting is a lot more solid.
But yes replacing the pump is probably better
viewtopic.php?p=2626244#p2626244
Topic above for interesting reading
